My Gameboy Sp got kicked while it was charging. The charging chord was yanked out and now my SP will not charge. The charging chord is not the problem, its the gameboy its self, is there any way to fix it.
I had the same problem. It was a solder connection in the charger socket. I tried to fix it but made it worse. I ended up having to switch the battery with a charged one from another GameBoy. That's how I was able to keep using it.
maybe you have to go to an electronic technician to fix your problem.they have the expertise in opening the gameboy and repair the broken charging port.
you can normally buy a portable charger , it sounds like the pins in the charger have gone ,so it may be a case of buying a new charger these can be picked up on the net quite cheaply
or you could try getting a needle and bending the pins back into the shape they are meant to be , to get an idea look at your other charger
When you sed 'I treid removing and replacing battery ' do you mean you bought another battery because you may need to because it sounds like your battery charger has had it, is your SP old though?
