Question about Sony KV-20FV12 20" TV
Sony kv20fv12 The color is way off and the set has started to blink to a black screen a lot...is it worth fixing?
  • Sony Master
  • 5,568 Answers
The two problems are probably not related; color correction (if all are there-RGB) isn't a tough adjustment inside if the provided tint or color controls aren't effective. At least two of the three colors are adjustable and may be located on the CRT board plugged onto the jug. If you decide to try this yourself, be advised that somewhere between 20-25 THOUSAND volts are close by; on the board itself 60-100 volts typically meaning no metal tools allowed. Any electronics store will have a cheap set of plastic 'tuning tools.'
Dropping out completely could be troublesome to find unless it is a matter of a connector that is not contacting any longer.
This might be something you could try; after the set has been off and unplugged at least overnight, you could remove the back (normally ~ half-dozen or fewer screws), carefully pull each connector you see plugged into the board(s), one at a time, including the small board at the CRT base and plug them back in.
If you don't care to try these things or they don't work for you, I hope you know a retired TV repairman who will do it 'for a friend' since labor has become costly and some parts are either not available or expensive if from the manufacturer.
Posted on Aug 12, 2008
What is the code for a 2001 Sony Trinitron?
Search Results
    Sony eSupport - Remote Control Codes & Programming ...
    https://esupport.sony.com/.../select-system.pl?...RCOD...
    Sony CorporationFind the codes you need to program your remote control. ... Television - Accessories; Television - FD Trinitron® & WEGA™; Television - Internet TV & Players ...
    [PDF]Trinitron Color TV - Manuals, Specs & Warranty - Sony
    https://docs.sony.com/release/KV20FV12.PDF Sony CorporationRefer to section 54-300 of Canadian Electrical Code for Antenna Grounding. Lightning .... Congratulations on your purchase of the Sony Trinitron Color TV.
Dec 08, 2015 | Sony Televison & Video
Tv is 10yrs old. Started with color only red and blue, standby blinking, now nothing. Had something like this long time ago is this worth fixing?
propably green not working. due to age its hard decision its worth or not to repair, but i recommend to sell for a few bucks to a hobby-freak and buy a new one...
Nov 13, 2011 | Sony FD Trinitron WEGA KV-32HS500 32" TV
Blue dots increasing on Screen.
Defective light engine. I would start looking into a new set. Most DLP mfg's have stopped production because of new technology and high failure rate of the light engines. It's not worth the investment.....Sorry!
Oct 06, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
Sony Screen keeps Blinking
If the red LED blinks 5 times you have a AKB error. It is caused by the CRTs trying to balance the color, and failing. Its an annoying problem that happens when the CRTs get old. If its just beginning you can balance or slightly turn up the screen voltage to the CRTs to remove the problem, if its in the end stages, the CRTs may need to be replaced. This is however, very expensive. If you are daring and safe around high voltage, pop off the speaker grille, open the front panel up and find the focus block. Don't poke around! those big red wires have 30,000 volts running through them! The focus block is a black square box with six knobs on it. Three are labeled screen, three labeled focus. You will see each row labeled R, G, B for red green and blue. The writing is tiny. Mark all three screen knobs with a colored marker so you know where they started. Then turn each one up slightly. If you have a picture, put it to a black screen or blank input. Turn each knob up just unit you see the color over drive and turn it back down to black. You want to set it just below retrace to maintain black level but drive the CRT fully. Setting this is hard but may fix an AKB issue.
Dec 02, 2008 | Sony KP-61S65 61" Rear Projection...
Sony Wega Triniton KV-32FS100 TV For the last week my TV has been going to a black screen for 10 secondsor so then the picture returns. It has been continual. Last night itstopped going to black screen,...
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Jun 01, 2017 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Sony FD Trinitron Wega model KV-34BR800
For the last week my TV has been going to a black screen for 10 seconds or so then the picture returns. It has been continual. Last night it stopped going to black screen, but now the standby light flashes 5 consecutive times and the color went haywire. A lot of red and everything that is suppose to be black is green.
I did a soft and hard reset with no success. What's wrong and is it worth fixing? Bought new in November 2002.
Aug 01, 2008 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Green screen
sounds like your green crt is shorting let me know if you need more assitance or if you would like to know where you can purchase a crt at.
Apr 10, 2008 | Sony KP-57HW40 57" Rear Projection...
KP-53HS10 Red blinking light/screen turns on and off
When a Sony does what you explain it usually only needs it's screen controls adjusted. This would be the first thing before replacing parts or any other trouble shooting, To do this you have to remove the speaker grill, there usually are two screws down low that are covered by plastic covers, once these are out the bottom pulls forward and slightly down. Then there will be another cover, remove that. Now you should see the inside of the TV. Near the front there will be a control ruffly the size of a pack of cigarettes and have six controls on it, Three are for focus and three for screens, Next find a video source that has no input, this simply means change to a input that has no signal, and gives you a black screen. Next simply turn the screens clockwise till a faint glow and retrace lines appear, then turn it back down till the color just disappears. Do this to all three, then you can re-glue them with fingernail polish if you want to.
Thats the simple way to set the levels on the CRT's, Sony's have a circuit that mutes the video until all the voltages are within a certain range, if the voltages are too far off it will give you the five blink error code, now if does not fix the problem there are other problems, This can be any thing from a weak CRT to a capacitor failing. And on a final note it is best to let the set run for at least 20 minute before doing this adjustment to let the voltages stabilize, and it is best to check it after another twenty minute to make sure it stayed
Mar 03, 2008 | Sony KP-53HS10 TV
Sony Trinitron KV35V35 picture blinks off and on
Classic bad CRT = sorry, not worth fixing.......T
Nov 06, 2007 | Televison & Video
Sony KV-20FV12 20" TV Logo
64 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
