Question about Lands Phones
I have 3 phone jacks in my home and right now on one of them gets a dial tone. The other two are completely dead. What could be the problem?
    Scholar:
  • 108 Answers
There should be a termination point outside your house where the local phone company connects to the wiring inside your home. These are usually wired for at least two phone lines. Sounds like your house was at one time wired for two numbers and the jack that is working was on one number while the other two jacks were on a different number. Best thing to do is connect all three jacks to the working telephone line outside the house. Good Luck. ...Mike
Posted on Aug 12, 2008
SOURCE:
My in house telephones are not working,but the internet is working.WHAT CAN I DO TO MAKE THE TEELEPHONE WORK AGAIN.
Have you paid the phone bill? Are you supposed to have phone service?
Providing that you have a contract with the phone company and it's paid up, take a hardwire telephone out to the grey junction box on the outside of the house. Open the junction box and plug your phone into one of the two phone jacks inside, Try the phone. If you get no dial tone, try the other phone jack.
If you get no dial tone from either phone jack, borrow a hardwire telephone from a neighbor and try both jacks again with the borrowed telephone.
If no dial tone with your phone or your neighbor's phone, then the problem is on the phone company's side of that junction box.
If your neighbor's phone works but yours doesn't, the problem is your phones - lightening strike, maybe?
If your phone works in the junction box but not inside the house, then the wiring from the junction box to your house jacks has a bad connection somewhere. Someone - you or someone else - will have the arduous task of tracking down where that bad connection is.
Jul 29, 2014 | Panasonic Lands Phones
We have tried to hook up majic jack no dial tone please help
Need to get intrnet hook phone jack to modam!
Feb 19, 2012 | Lands Phones
What do you check when the phone lists a message of "Check TEL Line"? The phone cord in plugged in so I'm not sure where to go from here. I have a model DECT1480
Usually this means that the phone isn't detecting a dial tone. For diagnostic purposes, I like an old corded phone.
First try a new telephone cable between the jack and the phone. Then try the old phone and see if you have a dial tone. If you have a dial tone with the old phone but not the cordless, then the Uniden needs service. These phones are not designed to be fixed by the user. If the phone is under warranty, send it in. (see page 28 of the manual www.uniden.com/pdf/DECT1480-3om.pdf )
If neither phone gets a dial tone, check at another jack if you have several to see if the jack is the problem or if it is a more global problem. If the problem is at one jack, you may want to open the jack and check for a loose wire. Some wall plates hold the wires with screws; others use a keystone jack with the wires pressed into slots using a "punch down tool". Keystone jacks do not need the insulator removed from the individual wires. For the screw connectors, you do need strip the individual wires. The punch down tool is available at many hardware stores in the electrical section (for wiring homes for ethernet and other services).
If you do not have a dial tone at another jack, find where your telephone service comes into your home. Open the panel and identify how the connection is set up. Some use RJ-11 jacks. In that case, plug in your test phone and see if there is a dial tone at that point. If there is no dial tone, contact your phone company for service. There is a break in the wires coming into your home. The phone company will fix this for free. (If the service doesn't use an RJ-11 jack, you need a special adapter to test at this point. Your phone company technicians will have this.)
If there is a dial tone at the incoming service, you have a inside wiring problem. Check any visible phone wiring for damage to the insulation. If the problem is with wiring inside a wall past the jack, you will need a professional to track the break. Your phone company will fix this for a fee.
I hope this helps.
Dec 29, 2010 | Uniden Cordless Phone
We have a no line message, and are not recieving phone calls. How do we fix that?
You need to find out where the fault is. I like an old corded phone for this. Check if a different phone gets a dial tone at the jack and other jacks inside the building. If no dial tone inside, find where the phone service comes in. Open that box and if it has a RJ-11 connection, check if you get dial tone at the junction. (If you have an older service, you will need a special line tester to check the service.) If you have no dial tone at the service box, contact your phone company - there is a problem with the service. (It could be some idiot damaged a wire digging or something else.) If there is a dial tone at the service connection, you need to find the break in your inside wiring. Open up the jacks and check any visible wiring for loose wires or damaged wires. If there is no obvious damage, you will need to look at the hidden wiring (a professional to do the work might be best).
Good luck.
(I've had dead phone lines outside the home from lightning (affected the DSL), an idiot road crew and one unknown malfunction. All of these were promptly fixed by the phone company technician.)
Jun 18, 2010 | Vtech DECT 6.0 Cordless Phone with Digital...
Cannot connect to isp using modem (dialup) get error code 680. using vista home premium.
error code 680 means there is no dial tone.
manually attach a phone to the phone jack you are connecting to and check if there is a dial tone. if there is no dial tone on that jack try a diff phone jack. if still fails call your telco.
if there is dial tone to other jacks it means the previous jack is faulty or damage.
Oct 17, 2009 | Computers & Internet
How do I test my phone jacks? I have no dial
There should be a gray box on the exterior of your house called a network interface device(NID). Unscrew the left half (or lower on some) marked customer side. there should be 1 or 2 places that have 2 screw terminals and a small telephone cord that is pluged into a small jack. Unplug the small cord and plug in one of your phones from your house into the jack. If you get dial tone then the problem is either in one of your phones or in the house wiring. If you still dont get dial tone then the line is dead on from the telco side(call the phone company).
Sep 18, 2009 | Lands Phones
No dial tone
Try connecting a regular phone to that jack and see if the phone works. If not, try a different cable. If the phone doesn't work, then the jack is either dead or miss wired.
Jul 10, 2008 | HP Officejet 7210 All-In-One InkJet...
Fax machine wont send or reiceve
Check to see if you have a dial tone. If not, plug a regular home phone into the jack in the wall and see if you can call it or dial out. You might have a dead phone line.
Apr 22, 2008 | Office Equipment & Supplies
Bell phone
is your computer hooked up dsl or dial up? unplug all the phones and computer from the phone jacks.plug a corded phone into the jack and check for dial. if you don't have dial tone, call your phone company. if you do have dial tone, plug everything in one at a time and see if the phone line goes dead.if it does, the last thing you plugged in is the problem.
wg
Feb 10, 2008 | Lands Phones
Lands Phones Logo
104 people viewed this question
Top Lands Phones Experts
Ekse
Marvin
Marvin
Are you a Lands Phone Expert? Answer questions, earn points and help others
