How to Manually program the AT&T Universal Remote Control to your
TV here are the steps.
Factory Reset the AT&T Remote Control:
* Press the ATT button and the OK button at the same time for 2-3 sec. release them at the same time. The ATT button will blink twice then enter the code 922. The ATT button will blink Thrice. If not repeat the step
* Press the ATT button then check all the function of the remote (Volume, Channel, Menu, Guide)
Note: you will see that the max volume is 25. Dont worry its the volume of the receiver
To Program Your TV:
Press the TV button and the OK button at the same time for 2-3 sec.
release them at the same time. The TV button will blink twice then enter
the code. Click Here to see the manufacturers list of codes. After Entering the code TV button will blink thrice. IF not repeat the step
Note:
After you program the tv make sure to press the ATT button. then now
check all the function of the remote. Follow the instruction and it will
work. If you press the power button the TV and ATT Recievier will turn
on and off at the same time
Turn TV on. 2Press the "Code Search" button until the indicator light comes on, then release the button.3Press the "TV" button. After you press and release the TV button on the remote, the light should blink once and then stay lit.4Enter a three-digit code. The remote code for Samsung will be 004, 005, 006, 011, 012, 013, 014, 015, 017, 09, 027, 036, 037, 077, 082, 104, 105, 106, 171, 172, 196, 201 or 204. The indicator light will turn off if the code is input correctly. If the light blinks rapidly, the wrong code was put into the controller. Go back to the Step 2 and repeat.5Point the control at the television and press the "On-Off" button. If your television turns off, you have used the right code. If nothing happens, put in a different code.Read more: How to Program a Samsung Universal Remote ' eHow.com http://www.ehow.com/how_4897139_program-samsung-universal-remote.html#ixzz1LpSdxIG1
