Question about Sony PlayStation 2 Slimline Console
Ps2 faulty when disc is inserted game comes up then starts to jump from one section of game to another as thogh it is fast forwarding very quickly,tried different games and it does the same with them all. thanks for any help much appreciated susan
  • 659 Answers
Well there is a few things to try but just from the description of the issue I am going to assume that its a motor hub assembly issue or a laser miss alignment.
but first off please try plugging the unit into another wall outlet and see if it happens again so that we can rule out and spike in the power.
secoundly insert a audio cd if it play 100% fine then we know its the laser assembly that needs to be fixed
if it dosent play fine the drive might need to be replaced
thirdly could just be a dirty laser on your unit.
cleaning this might help.
please list the model number on the back or the bottom of your unit so I can post proper ways for you to go about cleaning the laser assembly.
Posted on Aug 11, 2008
My PS2 is not loading Grand Turirsmo 4!
If your PS2 works fine with most of the games and won’t play a few..Then you should try this trick to play them too on your PS2:
  1. Turn on your PS2 without inserting any disc.
  2. Menu screen will appear like:6e4cb56.jpg
  3. Press the (triangle) Button to enter Version Information Menu that looks like9d90dc8.jpg
  4. Highlight the Play Station Driver as above and again press (triangle).
  6. Highlight the Disc Speed as above and press X button,to enter Disc Speed Menu
  7. And set it from Standard to "Fast".
  8. After you set Disc Speed to Fast, Press and Hold Reset Button to turn off your console.
  9. Then again Press and Hold Reset Button till the Blue Light turns on.
  10. Remove the Reset Button and Press it again.
Be patient and wait till the game loads itself. If your lens is in good condition then it will play game in first go else try again till it PLAY your game. If still your Grand Turismo 4 DVD wont work then you must clean your PS2 lens.Watch following video to learn about cleaning lens:
Thank you and Good Luck!
Dec 16, 2009 | Sony PlayStation 2 (PS2) Console
How to fix my playstation 2 that won t read grand theft auto san adreas
Your console is an old one,and your lens too is probably weak.Try cleaning your PS2 lens Watch Video at end of solution to clean your PS2 at home....
You can also follow these steps to make your PS2 to play GTA San Andreas:
  2. On menu screen go to [options] by pressing 'triangle' button.
  3. A new screen will appear select by pressing 'X' [DISC SPEED]and set it to [FAST]
  4. Then insert the game disc.
  5. Turn off your PS2.
  6. Press and Hold the [Reset Button] till the blue light turns on.Release the Reset button and press it again.
It will take a bit more time to play game,but first i recommend you to clean your PS2 lens,watch this video.
I've got something else to add.......you can follow above steps to play DVD movies if your PS2 dont play any.....!!!
Nov 19, 2009 | Sony PlayStation 2 (PS2) Console
Wont load
Disc read errors are mainly due to worn out lens or dirty PS2 lens.Clean your PS2 lens to get rid of this problem if your lens is dirty.Watch this video it will help you to know how to clean your PS2 lens.Watch it carefully.
Remember to keep your PS2 in Dust free environment if you don't want your PS2 lens to get dirty.
If your PS2 can not play certain games like Rock band try this tip:
  3. Press the ps_b_triangle.gif (triangle) Button to enter Version Information Menu that looks like
  4. Highlight the Play Station Driver as above and again press ps_b_triangle.gif (triangle).
  5. New screen will appear like
  6. Highlight the Disc Speed as above and press ps_b_x.gif button,to enter Disc Speed Menu
And after that wait till your game is loaded.
Click here to view full tip.
Nov 16, 2009 | Sony PlayStation 2 (PS2) Console
Ps 2 not working and will not play discs
click the green button twice fast when disc read error comes
Aug 16, 2009 | Sony PlayStation 2 (PS2) Console
Guitar Hero Metallica Wont play on my Ps2
okay, try this: 1. Start up PS2 with no disc 2. select 'Browser', press triangle. 3. select 'Console', press triangle. 4. select 'Diagnostics', press X, select 'ON'. 5. press 'O' to back out of this menu. 6. select 'Playstation Drive', press triangle. 7. select 'Disc Speed', press X, select 'FAST'. 8. press 'O' to back out of menu. 9. turn off PS2. 10. insert disc. The Diagnostics should run and automatically adjust your PS2 to play the game. I got this "FIX" from someone who had the same problem. Hope this helps :D
Jun 09, 2009 | Sony PlayStation 2 (PS2) Console
What's up with Guitar Hero World Tour disc not loading on the older PS2?
I think maybe that the guitar hero world tour is to new for the old ps2. I think that it only works on new ps2's.
Dec 24, 2008 | Sony PlayStation 2 (PS2) Console
No Data message when inserting a game disc, but unit will play music discs PS2 system, is this a laser problem
yes this is a 100% laser problem.the music cd that you play is not a dvd disc its a normal cd-r.the ps2 laser consist of 2 laser diode reader.the dvd section is already busted.so it needs a replacement
Dec 17, 2008 | Sony PlayStation 2 (PS2) Console
Had ps1 game resurfaced, no longer works on ps2
Sounds like you need to get your money back ..the resurfaceing can also do more bad than good
But a little trick lightly rub a crayon over the disk ,,old pantyhose works great rub it off from center out then try your disk ,,have saved many good games that way
Nov 20, 2008 | Sony PlayStation 2 (PS2) Console
Disc read error
Disc Read Error generally means that the game disk cannot be read by your console.
Reasons for Disc Read Error
1. Disk surface scratched or smudged.
2. Disk surface dirty.
3. Lens surface dirty.
Here is what you can try doing.
1. Check the game disc for any scratches or smudges on the surface of the game disc, try to clean them off by using a non-abrasive cotton cloth.
2. If the PS2 console is lying down, please set the console to on its side or if it's on its side set it to flat position, restart the console and then try game again. Always ensure the PlayStation 2 is in a cool, well ventilated place.
3. Remove and reinsert the Memory card of your PS2, restart the console then try running the game again.
Other troubleshooting that you can try.
Change the Disc speed of the PS2 DVD and then try again.
Start the PS2 with no disc in a drive. Press the "triangle" button on the controller.
Use the up and down buttons on the controller to select "Playstation Driver” and press the "triangle" button on the controller.
Select Disc speed. If it is set to "Fast," select "Standard"; if it is set to "Standard", select "Fast" and press the "X" button on the controller. Press the "O" button on the controller. Insert the game disc and restart the PS2. Try running the game again.
Turn the Diagnosis On for PlayStation2 to auto detect the best settings.
From the Browser and System Configuration menu. Press the triangle button to select Version. Highlight the Console from the list and press the triangle button - this accesses the next menu option. The Diagnosis will be highlighted. Press the X button to access the options available. Highlight "ON" and press the X button to affect the change. Restart the console and try the game again.
If the above steps does do not solve the error then you would probably have to replace the disc.
Note: If you are using the Slim version of PS2 make sure that the console is properly ventilated and that it should always be in the standing position, as the slim version of PS2 no fan or any other cooling unit unlike the normal PS2.
Oct 13, 2008 | Video Game Consoles & Games
The ps2 green light will go green when switched on etc. but if u were playing on your ps2, then stopped then started again and it didnt work then this might solve your problem.
clean out you ps2 the dust build up could have this efect i had this problem cleand it right out and it worked ever since problem free
Apr 04, 2007 | Sony PlayStation 2 Slimline Console
Sony PlayStation 2 Slimline Console Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
