Question about Panasonic NN-T990SA Microwave Oven
Microwave My microwave stopped with a sound and it's not working now. Is there a way to reset it?
Well you should problee buy a new one i hope you arent to old
Posted on Aug 11, 2008
SOURCE: Danby Designer microwave (with exhaust
Its a bad magnetron
Posted on Jul 18, 2008
garing
  • 998 Answers
SOURCE: Microwave Totally stopped - nothing turns on HELP Needed
check fuse
Posted on Aug 08, 2009
SOURCE: loud pop and microwave doesn't heat anymore
I have a GE Profile Spacemaker model JVM3670WF001, purchased I think in 2003. Pop sound, no Heat. Light goes on, carousel goes around,
Repair or new microwave
Posted on Sep 08, 2009
SOURCE: LG Microwave LMVM2055ST Just stopped working!
It has probably had an overhesat problem and the repair is quite simple. First you must remove the cover. This will require the removal of alot of scres on top, bottom and rear of machine. Once done, looking down at the top of the microwave all the way to the left about half way from the front to the rear you will see a round senso with two black wires going to it. This issimilar to a fuse and when you remove it, you can test it with a continuity testor. Electric should flow through it with no resitance. If it does not, it must nbe replaced. It's about ten bucks.
Posted on Nov 20, 2009
  • 176 Answers
SOURCE: My sharp microwave just stopped working. It
IT IS POSIBLE TO HAVE A BURNED FUSE ON THEI Main boARD OF THE OVEN
Posted on Feb 14, 2010
My Frigidaire microwave model PLMV169DCB turn table stop working & wont heat up
Thank you for your inquiry, Justin!
From the information you have provided your Frigidaire microwave is not turning and it has stopped heating up. It sounds like the motor, magnetron, or control panel may need to be replaced inside of your microwave. This could also be a miscommunication within your microwave and a reset could help clear it out. You can reset your microwave by flipping the household circuit breaker off for at least ten minutes. If that does not help correct your issue I would suggest contacting a professional technician for proper diagnosis and repair. I hope this information is helpful. -Matt
Apr 06, 2015 | Frigidaire Microwave Ovens
Ge microwave jvm1740 start and clear/off button not working
Sounds like a bad keypad. You will need the full model number off the microwave to look up the correct control panel part number. Sometimes these type of parts can be really expensive & it may make more sense to replace the microwave depending on the age and condition.
Sep 05, 2014 | GE Spacemaker JVM1740 Microwave Oven
Just stopped heating, making a louder than normal sound as well is there a reset button or something I can do. all else works, pad, clock timer etc, just not heating?
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Jan 13, 2011 | Maytag MMV5156AAS Microwave Oven
Unit stopped heating. sounds like it is working but will not heat food on any setting . I reset the filter timer, but still will not heat.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Basic Microwave Oven TroubleshootingTips
heatman101
Feb 24, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
During cooking, the microwave will work for about 3 minutes then completely shut down.There appears to be a complete power failure.After the units sits for about 5 minutes,it resets itself and you can cook...
sounds like the cooling fan has came adrift or stopped working , this will cause the magnatron ( the microwave generator ) to overheat tripping the over temperature stat ,so fix the cooling , but be sooooooooooooo carefull in there , microwaves + really high voltages , not really a job for a non electrician/microwave tech
Oct 20, 2009 | Samsung SMH7178STD Microwave Oven
Ge spacemaker microwave when i plug it in comes up with PF on the screen and does not work at all,it has power and the light inside is on,i can press the 3 minute button and the microwave will wor but that...
ther should be instrustions manual sound like mocro is working suspect control panel it needs 2 be reset how read manul panosonic push stop 1 at same time menu comes up push reset this is a minor problem hopes this help u
Jul 27, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Has no power
If your microwave oven doesn't seem to work at all, check these: Fuses Usually, when your microwave oven doesn't work it all, the internal fuse (thermal fuse) is blown. This fuse protects both you and the oven. When it blows, you need to have a qualified appliance repair technician replace it. Door switch If the fuse isn't the problem, check the door hooks and the door-release button. When these are broken, the door switch doesn't activate, so the oven can't work.
thanks
Mar 18, 2009 | Panasonic NN-SN657SMicrowave Oven
Whirlpool(GH7145XF2-0) does not work occasionally
That's how it would sound if you were cooking on a power level less than full power.
If you enter the cooking time and hit Start, it should cook at full power by default and not cycle like you describe.
If you are using some sensor cook setting or automatic type cooking setting, it may cycle like that normally.
The first thing to try is a "hard reset". Unplug it from the power line for a minute, plug it back in, set the clock, then try again.
Let us know if the hard reset doesn't fix it.
If you don't have your manual, you can download it free here. Check the lower right area to enter your model. number.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jul 17, 2008 | Whirlpool GH6177XP Microwave Oven
Microwave stops working
sorry to say the control panel sounds like it is defective.There is a microwave guy here that repairs these panels, look him up and contact him for the panel repair information. Good Luck
Apr 29, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Panasonic NN-T990SA Microwave Oven Logo
55 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
