Question about Garmin StreetPilot c550 GPS Receiver
My Garmin C3550 street pilot will power up but screen is only white.
Screen display as blurry...can't see anything..but it talks...able to press on screen blind.
  • 1 more comment
  • sharmart Aug 26, 2008
    My device worked for about a week then the display seemed to become whitewashed.
  • gabilv Oct 11, 2008
    the screen is white, can barely see the screen. recalibrating did not work
  • moreaunpd Nov 04, 2008
    I bought my garmin refurbished from buy.com. the screen is "white washed" sound works, touch screen works. i will try to recalibrate it. I hope that solves the problem.
Try recalibrating the touch screen. Turn on unit while continuing to press the power button for about a minute. You will then be prompt to touch a series of dots on the screen. Once prompt to do so, release the power button and touch the dots. Press OK when calibration is complete. The unit will continue to power on. Good Luck.
Posted on Aug 14, 2008
Street polit c330 stuk up
Remove the frame around the screen and press the reset button
Dec 11, 2009 | Garmin StreetPilot C330 GPS Receiver
HOW TO CALIBRATE GARMIN STREET PILOT 2620
I am assuming you want to calibrate the touch screen. Press MENU, click DISPLAY, Press find, press find, follow instructions on screen. You can also hold MENU and FIND at startup and a diagnostic screen will start up, pressing menu repeatedly while on this screen will give you an opportunity to calibrate the screen. If you are looking for a solution on how to do something else, please post additional information and I will do my best to assist.
Jun 06, 2009 | Garmin StreetPilot 2620 GPS Receiver
After several munutes of on the screen goes to
I have a Garmin Street Pilot c330 which when plugged in and power button pushed, the screen lights up for a few seconds and shuts down. It was giving a low battery warning before shutting down. Where is teh battery in teh unity? and should I replace the fuse?
Apr 22, 2009 | Magellan Maestro 4040 GPS Receiver
My Street Pilot C330 will not navigate pass the where to/view map screen Screen seems to be frozen
I have a c340 and instructions say: if your unit locks up. press the power button to turn off the unit, then press again to turn unit back on. If this does not help, reset by the following: place your thumb nail in the groove located under the Garmin logo on the face plate, gently pull off the face plate, press the reset button, turn the unit back on and it should operate normally
Dec 27, 2008 | Garmin StreetPilot C330 GPS Receiver
Garmin street pilot c340 battery appeared low, used USB cable to hook up pilot with my computer but device doesn't appear to turn on, computer cannot locate device on Drivers, can I rechare steet pilot...
I followed the instructions of the Online manual for the Garmin Street Pilot c-340, I removed the faceplate of the Street Pilot and then using my thumb pressed down on the reset button. I then pressed the power on button on the side of the device- the screen lit up, I then plugged one end of the USB cable into my computer and the other end into the device. The information on the screen of the device indicated the Lithium Battery was charging properly.
Jul 14, 2008 | Garmin GPS
Garmin 340 street pilot
Remove the battery out and put back in after 5 minutes to reset it.
, check also that the in car power cable is working, and the Garmin is not drained. Tru to connect it to power outlet if you have an adapter
Mar 29, 2008 | Garmin StreetPilot c340 GPS Receiver
Garmin street pilot III
Push the power button to turn it on then count to 5 then hit enter. Then count to 5 again then hit enter. Once there hit the power button with a real quick press. The power button is also the screen brightness button. Someone may have turned it all the way down. OR the back light could have gone out.
Aug 16, 2007 | Garmin StreetPilot 2610 GPS Receiver
Garmin StreetPilot c550 GPS Receiver Logo
160 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
