Question about Lexmark C510n Laser Printer
Lexmark C500 printer SVC LL ERROR, SVC L1 ERROR
Printer displays SVC L1 ERROR after maintenance exercise, and after further maintenance, the error code says "SVC LL ERROR"
Hi Technicians,
My Lexmark C500 laser printer recently experienced an improper maintenance procedure regarding some spilled toner inside of the equipment. The printer was functioning fine however the pic roller wasn't taking the paper so we decided to give the printer a complete maintenance clean up. Upon disassembly we discovered waste toner blocking the return hose feed that leads out into the toner waste bottle. Rather than using a special vacuum for toner, we used a blower and a large cloud of toner was ejected from the waste line and inside the compartment, I identified this as the mistake. Dangerous and messy. The parts were reassembled according to specification, the printer was turned on and after the test cycle and the warmup, the printer stops and displays an error "SVC L1 ERROR". So the C500 was torn apart again for closer inspection and we discovered many sensors and electrical contacts were invaded by the wasted toner. We cleaned up all of these dirty sensors and cable connection points throughly. After reassembly, the printer shows a new code "SVC LL ERROR".
I checked the motor of the rotational mirror inside the laser assembly and it is functioning. the lenses were cleaned and free of the toner dust.
Please help with a procedure recommendation, we need to keep this printer around a few more months because we just stocked it up with 4 new toner cartridges and it would be a sad wasted to toss out into the garbage heap of our wonderful planet.
Thanks in Advance,
The S.C. Team
  • Patricio Leonardo
    Patricio Leonardo Aug 11, 2008
    Also, if anyone has a digital copy of the service manual to c500 I would love to download and share it with others thanks
  • Patricio Leonardo
    I've used a digital multimeter to test the cable interlink between the driver board and the laser imaging module. So there is not a broken link there. Still the error SVC LL ERROR is occuring. The printer will clear the error and try to warm up again if I open and close the doors, but never passes the warm up phase
  • 300 Answers
As i'm sure you already know the error means - Laser power is lower than the output limit.
It's probably due to a bad contact on the engine board. If you would like the service manual it can be downloaded from the following link free of charge http://www.eserviceinfo.com/equipment_mfg/Lexmark_22.html any problems come back to me.
Posted on Aug 11, 2008
  • wayne churchill Aug 12, 2008
    If the cable is ok the problem is either the engine board or the laser assembly, because you were already gettting the svc l1 error, i would go for a replacement printhead (laser/ scanner assembly) first
My printer will not print and is reading SVC H2 ERROR. How do I resolve this?
According to the Lexmark Manual, SVC H2 ERROR is a fuser temperature error. The Fusing temperature is not reached within the warming-up time period.
Try to remove and re-install the fuser. If the problem still occurs you will need to replace the fuser assembley.
You can find the lexmark manual here for more information
ftp://nice.ics.perm.ru/pub/drivers/printer/Lexmark/CD%20new/%D0%94%D0%B8%D1%81%D0%BA%202007%20%D0%B3%D0%BE%D0%B4/Lexmark%20C500n/b.%20C500n%20Job%20Aids/C500n-5023%20Service%20Manual.pdf.
May 27, 2011 | Lexmark C500n Laser Printer
Lexmark c500 erro svc f4
its a fuser fan its faulty change it the problem solved
Feb 01, 2010 | Lexmark C500n Laser Printer
What is an SUC H2 Error mean on a Lexmark C500 Printer?
What is the mallfunction on a Lex 500c when SVC H2 error is displayed? thank you, johnny_key00@yahoo.com
Nov 09, 2009 | Lexmark C500n Laser Printer
Error SVC l1
It's probably due to a bad contact on the engine board. If you would like the service manual it can be downloaded from the following link free of chargehttp://www.eserviceinfo.com/equipment_mfg/Lexmark_22.html any problems come back to me.
Jul 03, 2009 | Tally T8006e Laser Printer
I have a SVC E9 error what does that mean
SVC E9 is an OPC Marker sensor error. Here is the service manual. See page 64 (or2-4 in the manual) for troubleshooting steps:
http://transfer.barrister-net.com/download/Lexmark/Color%20Laser/Lexmark%E2%84%A2%20C500n%205023-110.pdf
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Jan 03, 2009 | Lexmark C500n Laser Printer
Lexmark C500 LL code
If you're confident all the connections are ok, the fault is either the laser or engine board, i would replace the laser first
Aug 11, 2008 | Lexmark C510n Laser Printer
COLOR LASER PRINTER LEXMARK C500 PROBLEM
Unstable transfer belt rotation–color matching cannot be secured.
Check the transfer belt
Aug 11, 2008 | Lexmark C500n Laser Printer
Lexmark C500 Error light showing,with New ink cartrige inserted showing toner low replace cartrige on machines display? Help!! thanks
Remove the cartridge, take a flashlight and check the right side inside the printer for a RED LED (in the place where the cartidge stays). Take a tape and patch that LED. That's all ! Enjoy
Jul 02, 2008 | Lexmark Office Equipment & Supplies
Lexmark C510n Laser Printer Logo
3,412 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
