Posted on May 02, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My printer canon ir 2022 prints faints and blank pages, what can be a problem and how to fix it?
Anonymous
Level 3:
  • Master 1,219 Answers
  • Posted on May 02, 2011
Anonymous
Master
Level 3:
Answers
1219
Questions
Helped
673466
Points
2880
first You must check, if the image is on the drum. To do these, start print and when you hear that paper is in drum section open the left door and look at the drum surface for the toner image on it.
i.e.
If the image is on it and it looks solid, check the transfer roller or replace him. Also clean the laser unit ( lenses and polygon mirror ) and change the drum unit. It can also be the problem with toner station.
i.e. the cylinder doesn't turns or the there isn't toner on cylinder.
It can be a bunch of things, so without seeing the machine it is difficult to say what is the problem... but, in most cases, the problem is in dirty laser unit or in transfer roller.
My canon ir 2520 prints faint copies after replacing a fuser unit. the toner cartridge is new
Canon printer printing faint or printing black when your printer print head issue. In that situation, you need to do:
1.Reset Canon printer
2.Clean printer print head
3.Replace damaged or improper installed print head
4.Check internal problems of your printer
Follow more steps to fix the issue canon printer printing faint andclean the printer print head error.
2answers
Canon ir-c2220i Faint Print
A feint print is usually caused by a blocked or empty toner.
I have canon iR2022 someone help me for setting A4 paper.when i m printing its taking A3 by itself.
You must adjust your paper size in casset .in canon 2022 look to your machin casset left . You see how to adjust
How to configure the printer on network printing
Print a configuration page. Look for the IP address under Network. Type that IP address in your web browser address and press enter. That should bring you to the printers internal web server settings.
2answers
My canon printer ir 2022 prints faint and blank pages, what can be a problem and how can i fix it?
Possible Problems:
1)Out of / Low on Ink.
Solution : replace the ink
2)Printer Setting
Solution : Check to make sure the lighter/darker slider is somewhere near the middle. This will be in the configuration screen on your printer.
Canon iR C6800 prints leading and trailing blank pages
There is an option in the print driver to print a separation page (typically just a blank page unless you specify otherwise) so that each person's print jobs can be differentiated easily.
This option probably got enabled somehow on her PC. Have her go into the print driver's properties (right click on the Canon in the list of printers and select Properties) and look for the option that says separation page or separator page and deselect it. Then click Apply or OK, and it should be good.
Ir 2022n fixing gear number
Problem for Canon iR 2022 Printer Ir 2022n fixing gear number
24helpful
4answers
Canon IR 2020 showing system Error E007 printer
my canon ir2020 is displaying system error E007
Prints and photocopies blank pages
a bet your problem is the drum cartridge,on it´s back exists a lever,rod, or something like that ,if it´s bent will not open the laser and give blank pages ,open the left door and check if it´s straight.
k24674
ADMIN Andrew
ADMIN Andrew
