How do I take apart the outer shell to my Kenmore -Series 80 washing machine?
  • 1 more comment
  • spago777 Aug 12, 2008
    I have a Kenmore Ultra Fabric Care Heavy Duty 80 Series Serial Number CF2467934 Model number 92588210. My top agitator is stripped out. How do I take it off to replace it? Thank you.
  • Anonymous Aug 16, 2008
    How do you get the back off the washer? have a pump leak need to check out
  • strbavla Sep 09, 2008
    After the washing cycle is complete and the knob is in the off position, water continues to pour into the machine.
I have Serial # CF2467934 Model # 92588210 Kenmore Ultra Fabric Care Heavy Duty 80 Series. The top agitator is stripped out, how do I take it out to replace it?
Posted on Aug 12, 2008
Mold in Kenmore Series 80 washer
You most likely have mold/crud on the top outer edge of the drum and even the tub it sits in from years of soap and water splashing up and sticking, The cleaners probably cannot reach those areas, You will have to take off the cabinet and clean all that off (should be videos on YT on how to take it apart)
May 03, 2017 | Kenmore Washing Machines
Our 80 series kenmore became unbalanced with a loud klunk. The metal shell came off the machine. It will not spin but will work on wash?
You may be able to find the problem by looking at the illustrated parts breakdown.
Sears maintains such drawing on nearly all of the brand names they sell and many more:
http://www.searspartsdirect.com/partsdirect/
Enter your model number in the provided search window there.
There are also links on how to find the model number if you have trouble locating it.
Jul 02, 2014 | Kenmore 24032\24036 Top Load Washer
I have a Kenmore Series 80 (8543549) top load washer. It will fill, but not agitate or spin or drain or anything else. The knob does not advance except manually. What component is causing this problem?
if its a top load which i believe a series 80 is,then you need to replace the lid switch to make it operate again,its located under the control panel,some can be replaced from the top,but some need to have the outer case removed to replace this switch
Jul 04, 2011 | Kenmore Washing Machines
Kenmore Series 80 washing machine won't drain after wash cycle. The machine just stops.
Check the lid switch under the edge of the top where the lid closes. When you are about 1 inch from closing the lid you should here a little click sound. That is the switch closing. I fyou do not here the click then the switch is bad.
Sep 01, 2009 | Kenmore Washing Machines
Kenmore 80 series
check for corrosion or cracks on the outer tub.that might be the only problem.good luck.
Jan 04, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 80 series leaking
well you can try filling the outer tub separately.with what you mentioned, the problem is certainly not with the drain hose or the pump. fill the tub separately with some water and if the leak is seen then the problem is certainly with the outer tub corrosion or crack on it.
Dec 13, 2008 | Kenmore 24832 Top Load Washer
Kenmore 80 series washer
drum is stationary in wash and moves only in spin
Aug 19, 2008 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
1,206 people viewed this question
Top Washing Machines Experts
