Question about GPX PDL805 Portable DVD Player
DVD wont load
When you insert a DVD the screen says loading and after it just says check disk, is happening with all the movies, the menu, settings and everything else seems to be working.
Thanks,
Elsie
  • Anonymous Mar 01, 2009
    I have gpx dvd player it will turn on and spin but freezes after a few seconds of being on can it be fixed
  • 2,071 Answers
If not locked by a region code,then it needs to clean the lens..
Manually cleaning the lens
To locate the laser lens, look around the door or drawer of the DVD player and you will see a small circular disc, which is often called the turntable or disc platter. Right off the edge of the platter you should see a small clear lens. There are some manufacturers that have had problems with the lens, depending on the age of the unit. In these problem players, moving the unit to a different location, turning the unit upside down, or sometimes even without moving the unit, the lens can become detached from the laser assembly and floats around inside the unit. You can re-glue it back with a little crazy glue, BUT it must be perfectly centered, and without getting any glue on it. So, if you don’t see the plastic lens, but instead see the laser pick-up assembly, look around for the lens inside the unit and glue it back on.
To clean the lens you must use very little pressure. Take a cotton swab and barely moisten it with plain, non-scented, or oily type alcohol. In a swirling motion, very gently rub the lens until you’ve covered it entirely. Then repeat using the dry end.
If the cleaning didn’t help, don’t despair just yet. You can see if there’s a problem elsewhere in the unit by using a few simple tricks and tips.
First thing you want to see if the unit’s laser is in good working order. This method isn’t foolproof, but most of the time works admirably. When you insert a disc, see if you can look up underneath where the disc sits on the turntable. Observe the laser lens going up and down. If the lens is trying to focus, that’s good! After a few seconds of the lens trying to focus, the platter should start to spin. On almost every CD/DVD unit I've encountered, the unit won't spin unless the laser has properly focused on the surface of the disc. If the unit spins up and and then shuts down, you should check and make sure the laser pick-up assembly slider mechanism is working without any obstructions and that the small chrome rail that it slides on is slightly greased. Don’t go overboard with the grease though, as too much can cause all sorts of problems.
The slider mechanism, depending on the age of the unit and the manufacturer, consists of the small chrome rail, a drive motor, a small gear assembly, and (in some units) a small belt that drives the slider unit via the motor. This small belt causes all sorts of problems. If the belt is broken or slipping, it can cause skipping, dropouts, or simply no start up at all. Also, if the belt breaks in the middle of the disc, the drive mechanism gets hair or dirt wrapped up into the gears, or the pick-up assembly doesn’t return to the start position (called home), the unit will (99% of the time) refuse to release the disc, causing it to become stuck inside the unit. There’s a little micro or leaf type switch located at home position that sometimes gets dirty or breaks and, causing this problem also.
If the disc starts to spin slowly and doesn’t come up to speed, the spindle motor that’s attached to the turntable platter is a common problem. There could also be a problem with the spindle motor driver controller IC or the power supply regulator that supplies voltage to the driver IC. If the disc starts to spin and then spins really fast, or stops and starts to spin backwards, your problem is the laser pick-up assembly or the servo control circuit. If you continue to have problems after cleaning and checking the other things listed above, you may have a problem with the player's alignment. Of course, one of the problems you'll face checking alignments on a DVD/CD player is that you’re going to need to use an oscilloscope on most of them. If you have the proper tools and equipment, the first thing to look at is the RF pattern of the unit while its playing. It should be a sharp and clear pattern. If it's dull and smeared, then the laser could be weak.
Also, in these units are very critical alignments called the focus/tracking gains and offsets. When these alignments are off, it can often cause intermittent troubles. As the unit ages and parts change value, so do these alignments, and will need to be checked. In my time as service technician repairing DVD/CD players, 65% of the laser pick-up assembles I have tested were good and only needed a small adjustment. Today's technology makes it unfeasible for a shop to hook up a DVD/CD player, and even some recorders, to their equipment and make these adjustments because of the cost involved.
Hope this may help;
Regards,
VOTIT
DON'T TO FORGET TO RATE
Posted on Aug 11, 2008
Model BDP2100 bluray/dvd player. Won't load dvd or main menu. If I've played one movie on it, that's about it. Almost new, still has stickers on it. Basically, it spins the dvd then shuts off output. Is...
Hi, if it happens the same with a bluray disk, the drive mechanism could be faulty, so you could claim your warranty, but if it happens with dvd disk could be a disk region issue but you should see a message on TV screen about wrong region disk to confirm it.
Nov 01, 2013 | Philips Televison & Video
My playstation is unable to read dvd movies do i need some kind of cleaner for it and what type?
dOn wOrRy all u hAv to do is
to turn on uR pS2 witthout puttin a DVD oR aNy diSc........
on mEnu screen gOto [options] by pRessing 'triangle' button.........
a new screen will appear select by pressing 'X' [DISC SPEED]....n sEt it to fAst
.....then insert the DVD movie........tURn off PS2....
press n hold the reset button till the blue light is turned on
......release the button and press it again..............
it wOuld take a little tYm foR uR DVD movie to be loAded........
be patient till the movie plays it self..............
If uR DVd still wont play then you should clean your PS2's lens Watch this video.....!!!
Oct 16, 2009 | Sony PlayStation 2 (PS2) Console
My ps2 won't play dvds anymore but will play ps2 games just fine. What happened and can it be fixed?
This is one of the most common problem faced by old thick pS2..........but dOn wOrRy all u hAv to do is to turn on uR pS2 witthout puttin a DVD oR aNy diSc........on mEnu screen gOto [options] by pRessing 'triangle' button......... a new screen will appear select by pressing 'X' [DISC SPEED]....n sEt it to fAst.....then insert the DVD movie........tURn off PS2....press n hold the reset button till the blue light is turned on......release the button and press it again.............. it wOuld take a little tYm foR uR DVD movie to be loAded........be patient till the movie plays it self..............
Sep 27, 2009 | Sony PlayStation 2 (PS2) Console
Will not load games
I had a similar problem. My PS3 did not load the disk based games. Those disk based games were not visible in the game menu.
I did not have problems with the normal movie DVDs or Movie Blu Rays. Those were working fine. Also downloaded games were working ok.
In case you have the similar problem, you should try the following steps;
The PS3 has a special Recovery Menu, which you can access in the following way;:
1. Turn off Playstation 3.
2. Hold the power button down; the system will turn on and turn off once again.
3. Once the System has been shutdown, re-press you finger until you hear 2 consecutive beeps
4. When you hear the 2 beeps take finger off power button.
5. You will be prompted to plug in your controller via USB and then hit the PS button
6. The Recovery menu will pop up.
The current Recovery Menu supports:
• Restart System: Restarts the PLAYSTATION 3 System.
• Restore Default Settings: Reset all system settings back to default.
• Restore File System: Checks for corrupt/missing system files.
• Rebuild Database: Rebuilds the OS for the PLAYSTATION 3.
• Restore PS3 System: Fresh restore; Deletes everything and starts from Scratch.
• System Update: Update the PLAYSTATION 3 System
Select option "Rebuild Database".
After PS3 has executed the DB rebuilding operation, the disc games will be visible again in the menu and are starting automatically when inserted to PS3.
Mar 24, 2009 | Sony Playstation 3 (PS3) Console
Ps3 wont load games up
I had a similar problem. My PS3 did not start the disk based games. Those disk based games were not visible in the game menu. I did not have problems with the normal movie DVDs or Movie Blu Rays. Those were working fine. Also downloaded games were working ok.
Nov 18, 2008 | Sony Playstation 3 (PS3) Console
Wont play games or movies
my playstation wont play ps3 games but it will play movies and ps2 games.if i put a ps3 game in it frezzes...
Sep 19, 2008 | Sony Playstation 3 (PS3) Console
After i put the dvd the movie does not see anything only the black screen and i let it load for a long time
>Do you hear Sound
>Yes-
>make sure all the connection on the TV and DVD player are secure.
>is your DVD players Menu on screen/visible before U insert a dvd
>check the players menu and the settings
>unplugged the DVD player from the power cord wait and the try it
>plug the dvd into a different tv if possible if that works then your tv was the problem just locate the tv settings to fix that
>still no luck than maybe you DVD players laser just needs to be cleaned
>use a self-cleaning DVD clean kit (really cheap too) and they work great it is just a cd that has a tiny brush on the disk as it spins a passes over the EYE to clean it .
Good Luck
Aug 28, 2008 | Insignia Televison & Video
D1817PKG DVD. Turn on unit - insert cd movie- audiovox loading - does not recognize cd
My dvd player tries to load dvd, then says Cannot Read Disk. Have tried different disks.
Jun 13, 2008 | Televison & Video
Dvd loading
mine kinda has the same problem but it only happens with one movie Hairspray but it doesn't say error it just says loading for hours until i restart this system in order to get the DVD out. Need Help!!
Feb 16, 2008 | Sylvania SRD3900 DVD Player/VCR
"Loading disk" appears on screen during movie viewing
buy a can of "dust remover air" or canned air , open unit and flush dust from the unit with emphaisis on the underside of the disk tray.. the sensor are dirty the sense the disk insert .
cliff
Dec 30, 2007 | Durabrand PDV-709
GPX PDL805 Portable DVD Player Logo
1,322 people viewed this question
Top GPX Televison & Video Experts
Bill T
Level 1 Expert
sonic boom...
sonic boom...
Jaime Hernandez
Are you a GPX Televison and Video Expert? Answer questions, earn points and help others
