Question about Acer Computers & Internet
My Monitor al1916w the color is all purple or blue. No other color appears including white,yellow or red. please help.
    Champion:
  • 232 Answers
TRY MONITOR ON ANOTHER SYSTEM TO MAKE SURE ITS NOT THE VIDEO CARD . IF IT DOES THIS ON ANOTHER SYSTEM REPLACE THE MONITOR, IF IT WORKS FINE REPLACE THE VIDEO CARD IN THE COMPUTER
Posted on Aug 11, 2008
SOURCE:
I have a 3 ton Bryant split unit I'M trying to rewire.
what colors are landed where on the tstat? and does the tstat wire that goes BOTH inside and outside have the same colors. also why are you in this situation, has everything been unhooked?
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Feb 09, 2018 | Heating & Cooling
Don't know radio connector color code
This should help.
1987-88 Plymouth Voyager Stereo Wiring
Constant 12V+
Red
Switched 12V+
Red/White
Ground
Ground/Back Strap
Illumination
n/a
Dimmer
Orange/White
Antenna Trigger
Yellow
Antenna
Right Front
Front Speakers
5 1/4" Dash
Left Front (+)
Green
Left Front (-)
Green/Yellow
Right Front (+)
Purple
Right Front (-)
Purple/Yellow
Rear Speakers
6" x 9" Tail Gate
Left Rear (+)
Brown
Left Rear (-)
Brown/Yellow
Right Rear (+)
Blue/Red
Right Rear (-)
Blue/White
Sep 20, 2011 | 1987 Plymouth Voyager
What does the stereo colors stand for on an 1992 crown victoria Red, black, Grey/blue, yellow/black, white/purple, green/black ,blue/red, orange/green, white/green, blue/white, brown/yellow,...
Red = ground
black = ground
Grey/blue = Left rear (+)
yellow/black = ignition 12v
white/purple = right rear (-)
green/black = (could this be green / violet?) than it is 12v constant
blue/red = illumination
orange/green = left front (+)
white/green = right front (-)
blue/white = left front (-)
brown/yellow = left rear (tan / yellow) (-)
green/orange = right front (+)
orange/red = right rear (+)
blue = not used
Nov 10, 2010 | Ford Car Audio & Video
Colour codes for 83 corona, wiring stereo the colours are grey/black grey/red Brown Purple/green Grey Blue/yellow blue white/black any help would be great thanks!
Hello! I'm having a hard time reading your colors...So, I'll give you the 1983 Corona wiring...
POWER
Constant +12= Blue/Yellow Switched +12= Gray
Ground= Brown Antenna= Black/Red
Illumination= Green
SPEAKERS
FR+ Light Green
FR- Blue
FL+ Pink
FL- Purple
RR+ Red
RR- White
RL+ Black
RL- Yellow
Guru...........Saailer
I’m happy to help further over the phone at https://www.6ya.com/expert/david_6df67de3b14de867
May 30, 2010 | Pioneer AVH-P5700DVD Car DVD Player
Monitor colors are not displaying correctly
Hi, At the worst it is a blown monitor, but have hope. 1st try a new or known good lead, between monitor and PC. 2nd put monitor with own lead on good PC. if 1st works = result. if 2nd and monitor is same, suspect monitor, however, if 2nd works ok on other PC, then look at ur vid card. Either way, this test sequence should save you some $. Be lucky.
Aug 15, 2009 | Acer AL1916W 19" LCD Monitor
Suburu radio wire harness. trying to match up with a new soni deck
Hello uze7, Here is the wiring match up for a 2009 Subaru Forester using the Metra 70-7552 wiring harness: NOTE: The actual harness will be listed as a Nissan harness, but has been used by Subaru since 2007. Also, I'm assuming that your Sony deck uses the standard color code. If not, you should have a manual that lists the function along with the colors. Match the wiring by function, not by color (although the colors may be the same). 2009 Subaru Forester Radio Wiring Color Code: Battery BLUE/RED (+) RADIO HARNESS Accessory YELLOW/RED (+) RADIO HARNESS Ground BLACK (-) RADIO HARNESS Illumination VIOLET (+) RADIO HARNESS Dimmer BLACK/WHITE (-) RADIO HARNESS Power Antenna YELLOW/BLACK (+) RADIO HARNESS LF Speaker (+) BROWN LF Speaker (-) BROWN/WHITE RF Speaker (+) BLUE/WHITE RF Speaker (-) BLUE/YELLOW LR Speaker (+) WHITE/BLACK LR Speaker (-) RED/YELLOW RR Speaker (+) GRAY RR Speaker (-) GRAY/RED Metra Harness: Yellow ? 12V Constant Red ? 12V Accessory Black - Ground Orange ? Dash Light Dimmer/Illumination Green ? Left Rear Speaker (+) Green/Black - Left Rear Speaker (-) White ? Left Front Speaker (+) White/Black ? Left Front Speaker (-) Purple ? Right Rear Speaker (+) Purple/Black - Right Rear Speaker (-) Gray ? Right Front Speaker (+) Gray/Black - Right Front Speaker (-) Standard CEA Color Code: Blue - Power Antenna Blue/White - Remote Turn-on Pink/Black - Audio Interrupt In (Phone) Orange - Illumination Red - Ignition (Switched 12V) Yellow - Battery (Constant 12V) Black - Ground Gray - Right Front Speaker (+) Gray/Black - Right Front Speaker (-) White - Left Front Speaker (+) White/Black -Left Front Speaker (-) Violet - Right Rear Speaker (+) Violet/Black - Right Rear Speaker (-) Green - Left Rear Speaker (+) Green/Black - Left Rear Speaker (-) Hope this helps.
Aug 13, 2009 | Car Audio & Video
I need to know what color the ignition wire is so i can install a kill switch on my 06 F250 Powerstroke
hi, hope this will help.....if it does, could you leave a positive feedback for me please...many thanx..........
PART COLOR LOCATION
12 VOLT CONSTANT BLUE/RED (+) IGNITION SWITCH HARNESS
STARTER BLUE/WHITE (+) IGNITION SWITCH HARNESS
STARTER 2 N/A N/A
IGNITION 1 WHITE/ORANGE (+) IGNITION SWITCH HARNESS
IGNITION 2 N/A N/A
IGNITION 3 N/A N/A
ACCESSORY/HEATER BLOWER 1 BROWN/YELLOW (+) IGN SWITCH HARNESS
ACCESSORY/HEATER BLOWER 2 PURPLE/GREEN (+) IGN SWITCH HARNESS
KEYSENSE BLUE/GRAY (+) IGNITION SWITCH HARNESS
PARKING LIGHTS ( - ) GRAY (-) AT HEADLIGHT SWITCH
PARKING LIGHTS ( + ) PURPLE/WHITE (+) SMART JUNCTION BOX IN PASSENGER KICK PANEL
POWER LOCK BLUE/LIGHT GREEN (-) TYPE (B) IN DRIVERS KICK PANEL
POWER UNLOCK YELLOW/PURPLE (-) TYPE (B) IN DRIVERS KICK PANEL
DOOR TRIGGER VIOLET(+) UNDER DRIVERS SILL IN HARNESS COMING FROM PASS SIDE
DOMELIGHT SUPERVISION GREEN/BLUE (-) HEADLIGHT SWITCH
HORN YELLOW/RED (-) AT STEERING COLUMN HARNESS
TACH BLUE(AC) AT HARNESS NEXT TO BRAKE PEDAL
WAIT TO START LIGHT N/A N/A
BRAKE PURPLE/WHITE (+) AT SWITCH ABOVE BRAKE PEDAL
ANTI-THEFT TRANSPONDER ANTI-THEFT TRANSPONDER @ IGNITION SWITCH TUMBLER
Aug 05, 2009 | Ford Super Duty Cars & Trucks
RCA Pearl TH1100A backlight colors
Pp. 16-17 of your user's manual:
http://www.rcapearl.com/pdf/TH11xx_IB.pdf
Settings
Press forward to enter the Settings menu and then
press plus or minus or to highlight an item. Press play
repeatedly to change settings.
Backlight:
• to adjust the time before the display light
turns off (On/10s/20s/30s).
• to adjust the color of the display light
(Red/Blue/Green/Yellow/Cyan/Purple/White).
-Tha Mp3 Doctor
Dec 13, 2008 | RCA TH1101 MP3 Player
Plymouth voyager
Hi Marlon,
Not a whole I can do to help. What I can do is refer you to go get a Chilton, or Haynes manual thac voers your Plymouth Voyager. They have schematics with wire colors labeled.You will have a good shot at figuring out which wire is which.
Nov 24, 2007 | Car Audio & Video
Computers & Internet Logo
27 people viewed this question
Ekse
Alun Cox
Steve Sweetleaf
Steve Sweetleaf
