Question about Frigidaire 24 in. FDB1050REC Stainless Steel Built-in Dishwasher
Frigidaire 24 in Stainless dishwasher wont start
I have read the owners manual, and checked the overfill device, checked the cycle, delay start is not selected, elec pwr is on, water supply is on etc. it just wont start!
Pete
  • 868 Answers
Next is to check the door switch for power.You should have 120Volts ,if you do ,then you may have blown the small fuse that attaches to your control board,its attached by a clip and runs to the your door switch.NOTE :Only follow the above if you have at least 1 led that is lit up on your panel.If you don't then you are going to have to check your power supply once more.
Posted on Aug 25, 2008
How to reset
Check manual or contact manufacturer.
Aug 10, 2014 | Frigidaire FFBD2411NS Full Console...
Dishwasher will start on delay start but won't start with start button
Good Morning Friend,
I understand your Frigidaire dishwasher, model# FBD1050REC, will start on delay start but not just by pressing the start button. Please try resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 20-30 minutes. Restore power and start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jul 08, 2014 | Frigidaire 24 in. FDB1050REC Stainless...
Why does my frigidaire fdb510 run for 2 hours
Hello mrsdear77 - The cycle times all depend on the settings chosen. The hotter the water temperature, the longer the cycle. If you add any other features or a delayed start action, this will also make the unit run anywhere from 60-90+ minutes. What settings do you use the most?
Jan 10, 2013 | Frigidaire 24 in. FDB1050REC Stainless...
I have an electrolux edw5505eps dishwasher. The control panel start button does not function, the delay button does noy cycle thru the delay time. Does the panel need to be replaced?
check out my thread on a similar issue. If your power button doesn't light and delay button does not light? Is the LCD screen display anything? check out my post several really good check lists.
Nov 08, 2009 | Electrolux 24 in. EDW5505EPS Stainless...
Wont' turn on
Push the "Heat Dry" button for at least 5 seconds. After that you should be able to start your dishwasher. The owner's manual I have says nothing about this, but this is a "lock panel" feature for the electronic panel design dishwashers. I just had this problem and stumbled upon a service manual online. Saved me $75.00.
May 04, 2009 | Frigidaire 24 in. FDB1050REC Stainless...
Frigidaire PLD4460REC Dishwasher will not start
This is very likely due to a bad main electronic control board but the only way to know for sure is to do some electrical testing with a volt/ohm meter and the wiring diagram located within the appliance. If possible use the meter and the wiring diagram to check input/output voltages looking for discrepancies between the diagram and the actual meter readings.
Go here for Frigidaire Dishwasher Parts: http://www.repairclinic.com/Frigidaire-Dishwasher-Parts
www.RepairClinic.com
Feb 03, 2009 | Frigidaire 24 in. FDB1050REC Stainless...
Dishwasher, flashing lights, frigidaire
The steam has gotten into the keypad display and fried it. Call Fridgidaire and let them know you've seen numerous people on the internet with the same problem and that you need part# 154554401 It worked for me.
Jan 20, 2009 | Frigidaire 24 in. PLD3465REC Stainless...
Soap not Disolving
possibly the water is not hot enough, it needs to be hooked up to a hot water line ONLY. also check to see what cycle the dishwasher is set at, there are three or four different settings. start off by using the pots and pans cycle because that cycle will delay the wash to superheat the water.
remember hot water only and water should be set at 120 degrees.
good luck to ya
Dec 29, 2008 | Frigidaire 24 in. PLD3465REC Stainless...
Experimenting
Try a cycle without filling the dispenser. If it opens, you may be overfilling the dispenser.
Jan 24, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
Open Questions:
See all Frigidaire 24 in. FDB1050REC Stainless Steel Questions
Frigidaire 24 in. FDB1050REC Stainless Steel Built-in Dishwasher Logo
219 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
