Question about Dell 1600n All-In-One Laser Printer
Where to get fuser and rollers
Where did you purchase your fuser for a dell 1600? I called Dell and they said they didnt carry a fuser or rollers, much less a kit.
    Genius:
  • Dell Master
  • 1,056 Answers
Sorry it took me so long to get back to you, I've been out of town for a few days.
The parts you need for the 1600n are from Dell.
Part# N5796 - Fuser
Part# M5512 - ADF pickup arm roller
Posted on Aug 17, 2008
I have a Dell 1320c printer and there is a part that I need to replace but I have n idea what it is called. When you open the front it is on the very top. It is the last roller the paper goes through
the last set of rollers are fuser rollers you have a heat roller and a pressure roller the pressure roller is made of rubber and the heat roller is made of aluminium.from the your question im guessing that the paper is wrapped around the heat roller. if this roller has scratches in the serface it does need replacingalso if the pressure roller is damaged it also will cause a papetr jam.
also you should check that all of the picker fingers are all in place and clean.
Feb 12, 2015 | Dell 1320c Laser Printer
Removal of paper stuck in a dell 3115 fuser?
It's best to remove the fuser to get access to it. This video will show you how to remove it, and which levers to move to release tension in the pinch roller to clear the jam http://www.youtube.com/watch?v=UjyggtF8d1k After you remove the jam make sure to do a close inspection on the internal roller (use a flashlight). You're looking for any scratches or "dents" in the colored roller (sometimes a deep red/brown color sometimes blue) if there are scratches you are probably going to have to replace the fuser. The imperfections on the fuser roller will show up on your printed pages. If you do need a new fuser you can find them for $160, or the entire rebuild maintenance kit for $375 http://www.fastprinters.com/productdetails.asp?PRODUCT_ID=DELL-UG190
Dec 19, 2013 | Dell Printers:Dell MFP Color Laser 3115cn
Our Dell 5110cn stopped working and the 'diagnostic' said to replace the transfer roller. I had purchased a Dell Imaging Drum and replaced that. I believe it has a transfer roller as part of the Imaging...
Dell sells the drum & transfer roller a kit, but there are 2 different parts to it, the drum & the transfer roller & they do not look the same. Replacing the drum does NOT replace the transfer roller. We've had a 5110cn for 4 years, I've replace both of these parts & the fuser unit several times.
May 07, 2010 | Dell 5110cn Laser Printer
Printed image repeats later
I have a Dell 5100CN, and believe that this problem is caused by the drum not releasing the full charge which holds the ink in place on the drum until the page is printed. After the image is transfered to the Drum, the 'Fuser' unit heats up the paper and pressure forces the paper against the drum to transfer the toner from the drum to the paper.
Since the Image is printing, and you are getting a ghost, I guess that the problem is most likely the 'Pressure Roller' or 'Heater' in the 'Fuser' unit.
Buying the Fuser unit from Dell could cost you around $200 from Dell, but I just found one on eBay for $129 Got to www.ebay.com and search for item number 190388919845
I highly recommend that you buy a new OEM (original Equipment Manufacturer (Genuine Dell)) 'Fuser Unit'
Good Luck
Apr 23, 2010 | Dell 3010cn Laser Printer
When should the fuser and rollers be replaced on the Dell 3110cn?
Fuser life is 100,000 pages.
Pickup and transport rollers - replace when defective - no 'fixed' life, but if you are replacing fuser, it's worth changing the pickup and transport rollers at the same time.
Note Transfer belt also has a 100,000 page life.
Mar 05, 2010 | Dell 3110cn Laser Printer
Dell 5100cn is printing duplicate text and images..what do we do after vacuuming excess toner has not solved the problem?
Two possibilities.
You may need a new FUSER. The fuser is the hot thing in the back that bonds the toner to the paper. The fuser heat roller is coated with teflon so the toner won't stick to it while it's heating the paper. After a period of time/number of pages (usually 100,000+), the teflon wears out and the toner starts sticking to it and then gets transferred back to the paper after a revolution.
Is the whole image repeating? Chances are good that it's the fuser. If only one color is repeating, it's probably a faulty toner cartridge, as it may have worn out before the toner ran out. Have you changed cartridges yet? If you have not and don't want to buy another just to see if it will work, try a "half-page test. Start printing something. When yoou think the paper is about halfway through the printer, open the cartridge door to stop the printing. Don't worry about the error. Pull out the toner cartridge and see if the repeat defect occurs before the fuser. If it does, try a new cartridge. If it does not, you need a new fuser.
The Dell fuser is not as easy to change as an HP fuser, but if you are brave and have a screwdirver, you may be able to do it without calling a technician. Service manuals afor Dell printers are hard to track down. Fusers can be found online for about $200-300. Best bet, if you don't know what you're doing is to call a Dell authorized servicer.
Jul 22, 2009 | Dell 5100cn Laser Printer
I am not being able to use the DELL MFP 1600 Laser
Replace pick up rollers. very easy and very cheap.
Jul 15, 2009 | Dell 1700 Laser Printer
I had a 'clean the ctd sensor' error. Cleaned it now it prints half the page in watercolors.
I had a clean the ctd sensor problem as well, as a problem with toner that I had ordered. The problem for me was that with Dell, when I called for support, the young lady on the other end of the phone although nice, was difficult to understand, and did not clearly define how you get to the ctd sensor.
After much prayer, (seriously!) I finally figured out how to get to the area I needed. With Dells instructions, I took the fuser out, thinking it was the transfer roller. The fuser is NOT the transfer roller, the transfer roller in the item that you see when you open the front entirely and look straight down. The difference is that the fuser is the first item out and has lift up blue tabs, while the transfer roller has blue tabs on each side that must click into place to hold and position the transfer roller properly. Once you get this out the ctd sensor is easily accessible, and can be cleaned. After, getting the ctd cleaned, and then replacing the bad toner cartridge, my machine once again worked.
Sherry McGregor Timberwood Mountain Realty,
Jul 09, 2009 | Dell 5110cn Laser Printer
Over heat messege
Chances are that you are looking for your printer FUSER, not a fuse. The fuser is the rolling element that bonds (via heat) the plastic charged toner particles to your paper. It is located in the rear of the printer. Unplug, remove four screws that secure the back of the printer. Once removed, you will see a circuit board and the fuser. The fuser has two sets of wires (one on each side) that should be unplugged with your hands. Remove the four screws that keep the fuser module in place and replace that module (call Dell parts for replacement).
Mar 10, 2008 | Dell 1600n All-In-One Laser Printer
Dell 1700n Jamming
try "rotating the pick up tires". (dell tech's phrase, not mine). pull the paper tray clear out of cabinet and look up inside the bottom of the printer. you will see a t shaped assembly with 2 large rubber tires (rollers). pull the assembly down (spring loaded) and peel the tires off the plastic mounting rollers. turn the tires inside out and replace them.
Feb 20, 2007 | Dell 1700n Laser Printer
Dell 1600n All-In-One Laser Printer Logo
160 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
