Question about Acer Aspire 5600 Series 5630-6951 Laptop
No display i have an acer aspire5634N. it has power coming and the fan is working but there was no display. i check the memory and its working.but no beep coming.is it possible that the ccfl have problem.but i put new lcd and still its not working.how can i know that it is the mother board or the cpu that is the problem.thanks and god bless
    Champion:
  • 207 Answers
Remove the memory...if u dont get any beep...then ur mother board is gone..
Posted on Aug 17, 2008
Continuous beep motherboard will not boot
check the battery for the mother board memory. flat battery can make it no startup. also if that is fine remover the hard drive lead and turn on if it comes on then the hard drive is causing the fault. do same with rom's.
Mar 24, 2014 | HP ECS ACER 946GZT-AM V1.0 SOCKET- LGA775...
Dead
Hi
THe most common beeps that you will encounter 95% of the time in repairing PC's are:
1 beep - computer ok
continous beeps / long beeps - memory error
continous short beeps - bios boot block/corrupted bios
1 long beep followed by 3 short beeps - video card error
or this might help
you can check out this list
AMI BIOS
1 short - Computer ok
2 short - RAM failure
3 short - Parity RAM failure
4 short - System timer failure
5 short - Motherboard failure
6 short - Keyboard controller error
7 short - CPU failure
8 short - Video RAM failure
9 short - ROM BIOS error
10 short - CMOS read/write error
11 short - Cache RAM error
1 short, 3 long - Memory failure
1 short, 8 long - Video adapter failure
Check board/chipset makers website for more infomation.
AWARD BIOS
1 long - Memory error
1 long, 2 short - Video error
1 long, 3 short - Video failure
Continuous beeps - Memory or video failure
note that AWARD relies on motherboard manufacturers to develop their own beep codes - the above are only their own internal codes. You will need to refer to your own manual for an explanation of precise codes.
Standard IBM beep codes.
No beep - Power supply or motherboard failure
1 short - System is ok
2 short - POST error (code displayed on screen)
Repeating short - Motherboard failure
1 long, 1 short - Motherboard failure
1 long, 2 short - Video display adapter failure
1 long, 3 short - Video display adapter error
3 long - Keyboard error
Pheonix beep codes
1-1-3 CMOS memory failure
1-1-4 BIOS failure
1-2-1 System timer error
1-2-2 Motherboard error
1-2-3 Motherboard error
1-3-1 Motherboard error
1-4-1 Motherboard error
1-4-2 Memory error
2-x-x Memory failure (any number of other beeps)
3-1-x Chipset error (any number of other beeps)
3-2-4 Keyboard controller error
3-3-4 Video adapter failure
4-2-4 Expansion card failure
4-3-4 Time of day clock failure
4-4-1 Serial port error
4-4-2 Parallel port error
4-4-3 Math co-processor error
pls rate as fixya if it helps. thanks
Jul 04, 2008 | Acer Aspire 5100 Notebook
Every thing is working fine but no display as i changed the display & also checked the same display on another set it is working ok changed display ic but still same problem
Power off your computer and remove the smps 24 pin connector to the motherboard and short the green and black pin and see if the SMPS is working if not replace the smps.
Remove memory from the memory slot and switch on the computer if you hear beeps clean the memory or change it with new one that fixes the memory slot
If no beeps by removing the memory then remove the processor fan and clean it with soft cloth and apply thin layer of heat sink compound and switch on the computer
If you still not hear the beeps then change the processor
If still no beeps take the motherboard to a chip level Technion the secondary power supply or the clock,reset etc in the mother board has gone wrong or not producing them
Apr 01, 2011 | Computers & Internet
My lcd monitor AL1717 has initial blinkig &there is no display,after some times it works properly,what is problem.
Apr 01, 2011 | Acer AL1717 17" LCD Monitor
No monitor display
Remove all data cables and external cards and press RAM than try again
Jul 23, 2009 | Computers & Internet
My acer 5610z won't boot up
possible memory (RAM) problem.
try removing all memory(RAM). reconnect just 1 RAM. if it doesnt work reconnect another RAM.
May 27, 2009 | Computers & Internet
Acer computer wont trun on
My name is ArmyMason, I think I have an answer for you. You seem to have one of two issues, the most likely issue you are experiencing with your Acer is a bad Power Supply. The only fan you are hearing is the Power Supply fan and no beeps its the Power Supply. If its was the fan on the processor you heard it could mean the Processor is bad. If this is a brand new computer I would most likely put my money on it being the Power Supply. A relativity cheap fix.
Thanks,
ArmyMason
Feb 24, 2009 | Acer Aspire T160 (AST160UA3400) PC Desktop
Long beep when power on PC
Usually any kind of clear distinctive beep while booting up is an error code. If you get a long beep with no display then it could be the memory or CPU. Check to make sure all of your cards are pushed in all the way. Just take your hand and push on your memory, cpu, and other cards gently but firmly to make sure they are seated. Also make sure that everything is connected. You may have missed connecting power to something.
Jan 20, 2009 | Foxconn (755A01-6ELRS) (K8S755A6ELRS)...
No beep no display but fan is steel moving
Hi Rajesh_KS
How many beeps did you hear? It matters. Every Bios has a name. (Award, AMI, Phoenix, IBM ect).
You'll need to enter your bios & check the name. It will be at the top of the menue or you can catch it just as your PC starts up.
Once you know the name of your bios & how many beeps you hear, Ex: 1 long 2 short & repeating. You'll know just what the problem is with regaurds to the memory.
I'll post a link for bios beep codes. All you'll need is the name.
Regardless of the error, it's suggested you remove your memory & than re-seat it. You will not get video display if your memory has a problem.
Here's the bios link: http://www.bioscentral.com/beepcodes/awardbeep.htm
On the right side of the page other manufactures bios's are listed & each have their own code system.
Support link for your Acer:
http://support-web.acer-euro.com/app/csd/etkdb.nsf/4b7a708d8dbc41cdc1256bd6003c0165?SearchView&SearchView&Query=Veriton%207700G&start=1&count=10&seq=1
You can also test your memory if re-seating did not help.
Go to this link:
http://www.memtest.org/
Scroll down till you see ** Memtest86+ V2.01 (21/02/2008) **
all typed in red. You can download a bootable CD program to test your memory. File; Download - Pre-Compiled Bootable ISO (.zip)
If you rather use bootable floppy disk, File; Download - Pre-Compiled package for Floppy (DOS - Win)
Good luck & Kind Regards!
please vote ;-}
Mar 09, 2008 | Acer Veriton 7700G PC Desktop
Acer Aspire 5600 Series 5630-6951 Laptop Logo
56 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
