Question about Dell Computers & Internet
PSU OR MOTHERBOARD PROBLEM? PWR BUTTON FLASHES AMBER
I took my computer to an electronics store and they by-passed my PSU and the power button still flashed amber.  From looking up the manual, this means the computer is receiving power, but has an internal power problem.  It says to check the voltage selection.  It was factory set at 115V.  I reset it just incase and still have the problem.
The tech at the store thinks I have a motherboard problem.
Any suggestions or ideas?
Thanks
Hanto,
Thanks for responding. The system is a Dell XPS 410/Dimension 9200. I did some more online research and attempted one last effort to isolate the problem before buying a Dell extended warranty. After disconnecting all the drives and PCI and other cards, I added back the cards one at a time. Each time I would turn on the machine and then turn it off, unplug it, and depower the MOBO before plugging in the next card and re-powering. I was very pleased to see the first time I powered up with the first PCI card, I got a green light on the power button. By this time I was pretty sure I knew what the problem was, one of my video cards. Earlier I found that the fan was prevented from turning by the other video card above it. I believe it caused the lower video card to overheat. When it overheated it may have caused a small piece of wire retension plastic to expand and also obstruct the fan from turning. I plugged this culprit in last and low and behold the computer got the dreaded flashing amber light.
It looks as though the PSU and MOBO are fine and I'll simply have to find another video card if I want my other 2 monitors working. I am not a computer person, but it looks like I was also able to get the system setup to find the right hard drive for boot up. I guess when I disconnected the hard drive it needed me to manually select the drive.
Thanks for responding. If you have any other suggestions or comments, feel free.
Posted on Aug 13, 2008
    Sergeant:
  • 226 Answers
You have left out a whole lot of pertinent information, such as which of Dell you are talking about, however since power supplies are ' usually ' fairly easy to eliminate as the problem especially by a fully equipped computer store who could if they wanted try another power supply on the mother for troubleshooting purposes but not have due to the possibility and fear that the motherboard would a deleterious effect on an otherwise good troubleshooting power supply. Voltage measurements can be taken during operation to test voltage levels and most any technician can do that if they have voltmeters and most any decent technician does. It is very possible that some component on the motherboard has gone bad, often a capacitor that will load down the power supply. I'm having to assume that you are talking about a desktop computer. Assumptions get a man into a lot of trouble, so until you can give better and more thorough information, I would have to conclude that the technician knows much more then I do.
Posted on Aug 12, 2008
Flashing amber light
Hi, on most Dells a flashing amber light on the power button indicates a problem with the PSU or a short on the main power rail, if this is the case you should have 2 flashing lights as well, 1 & 3.
May 05, 2014 | Dell OptiPlex 3010 MT Desktop Computer
My Optiplex 960 flashes amber 3 light when powering on.
Hey, have you ever thought that you ANSWERED YOUR OWN question? If you press the power supply TEST button, then it powers up fully? It's NOT the button.......So...what else could it BE then Mitch?
Nov 25, 2013 | Dell OPTIPLEX 960 MT Desktop Computer...
Amber flashing light GX620
LOL... If you haven't already fried your motherboard by using your modified PSU (And that's a big IF), then you need to buy a new PSU with similar specs and connection plugs (ie. a 24pin main) as the original PSU that came with the PC.
May 31, 2012 | Dell Computers & Internet
Could not power up gx620, tried replacing PS still could not turn on, thought it might be I/O panel but still not on what next
The amber light within the Power Button indicates a PSU or Motherboard fault. If you have changed the PSU and it is a known good unit, please check the plug that connects to the Motherboard again. Assuming that this is ok, it may unfortunately be that the motherboard capacitors have blown (a well documented failiure).
Sep 21, 2017 | Dell OptiPlex GX620 PC Desktop
I can not find the power button on my mother board
There isn't a power button as such on the motherboard. There will be a pin header that should say something like PWR SW beside it. The power button just shorts these two terminals out for a second to tell the PSU to switch on. You can do the same if you are careful. But as always: BE CAREFUL.
Sep 29, 2009 | Dell PowerEdge 2500 Server
Dell optiplex gx150 power button just flashes - help?
System seems to be in hibernate or standby mode and frozen in that state. Hold dosn power button for 5 seconds or until all signs of life shut down. Wait about 30 second and power up the system.
Jul 25, 2009 | Dell Optiplex GX270
Dell GX270 won't boot up with solid amber light on Power button
Check motherboard for bad capacitors. I had the same problem and when i had bad capacitors replaced everything is ok.
Feb 14, 2009 | Dell OptiPlex GX270 PC Desktop
Possible power supply problem
Open your computer case and disconnect/remove any hard drives, cd-rom/dvd drives, take out any extra cards installed (except video card unless you have onboard then take out the video card too) and all but one stick of ram. Turn the computer on
- if it turns on, plug in each item back one at a time turning back on and off each time ( power trip will cause the pc to not turn on)
- if you smell anything weird from the PSU unit DO NOT try anything further, replace the unit.
- if you have overclocked your computer, use the jumper on the board and reset your bios
In the event you need to replace your PSU unit if Antec is an option, go with that. They are very stable.
Jan 21, 2009 | Dell Computers & Internet
Power light on case blinks amber
Your motherbaord is shorted out, replace it, you can get the numbers off it and put in in on the web and you can find out what kind it is. put that in ebay and you can find some new ones with a good price.
Dec 17, 2007 | Dell Dimension 5100 (D51L1) PC Desktop
Computers & Internet Logo
169 people viewed this question
Alun Cox
