Question about Sears 61301 Gas Kitchen Range
Galaxy model# 790-61081892
Hi.  the above number is what is says on the sears sticker.  I have asked sears for a conversion kit for the orifices from nat gas to lp and they say they don't have one in their parts computer.  I noted that you said for another galaxy range, that you simply turn the orifices over.  is that the case for all of the galaxy ranges?  Thank you.
  • 3,248 Answers
Hi try direct energy they might stock these parts or know some one who might
Posted on Jan 28, 2010
Is there a conversion kit for magic chef CPR1100ADW
Yes, there is an LP conversion kit for the CPR1100ADW. Sears Parts Direct lists it here: http://www.searspartsdirect.com/model-number/cpr1100adw/1429/0124002.html . Select the Gas Control drawing. The direct link to the LP orifice kit, part number 74009923, is http://www.searspartsdirect.com/part-number/74009923/0022/464.html?modelNumber=CPR1100ADW&categoryName=Free%20Standing,%20Gas&brandName=MAGIC%20CHEF . Note: the Magic Chef range uses the same parts as a Whirlpool or Maytag range.
The gas regulator also has to be adjusted. Most ranges with converter kits available just require the regulator to be removed and turned 180 degrees before replacing it. It's recommended that a LP service person do the work. The air flow may need to be adjusted and any mistakes could be dangerous.
I hope this helps.
May 06, 2017 | Magic Chef Kitchen Ranges
I am looking to convert my kenmore 970-c92062 ng dryer to lp.
The supplier of the LP gas can supply the needed parts for conversion.
Aug 09, 2017 | Amana Dryers
Instuctions on how to change a pitco fryer from nat gas to propane
Hi there!
You need to order a gas valve conversion kit (from nat to propane), propane pilot orifice and propane burner orifice,
Gas valve conversion kit consists of a replacement spring thicker than of natural gas valve spring, gas valve cap and a sticker.
Pilot orifice for propane has smaller bore than of natural.
Burner orifice for propane has also smaller bore than of natural burner orifice (one for each burner).
You will be able to find these parts on the list of Pitco Distributor when you visit http://www.pitco.com
Regards.
Jul 08, 2012 | Pitco Frialator E24 Deep Fryer
I need to convert from gas to propane and I need a owners manual
Which model of range do you have? Maytag has owner's manuals for many of their appliances here: https://www.maytag.com/webapp/wcs/stores/servlet/OCManualsLiteratureSearchView?catalogId=10562&langId=-1&storeId=10212&krypto=5QgxQhneFliXuEuX564wSQ%3D%3D&ddkey=http:OCManualsLiteratureSearchView . Enter the model number and click Search. Most ranges will have the serial number on a plaque below the display, on the frame of the oven (behind the oven door), on the frame of the storage drawer (visible when the drawer is open) or near the legs of the unit.
Often the conversion kit is sold with the range and is attached to the back of the range near the regulator. The instructions are in the kit. (Note this should be done by a professional. Your propane company may have a person available to do the conversion.) If the conversion kit is not supplied with the range, you should be able to order it from the manufacturer. (Some manufacturers will only ship the kit to the service person who will do the swap.)
Please add a comment with your model of range for additional information. (There are some manufacturers who do not supply conversion kits and you must order the correct range from the factory.)
The conversion is usually straight forward. Swap the regulator from NG to LP by turning over the part (it's labeled clearly) in the regulator. Using a small nut driver, swap the orifices for the cooktop. Do one at a time and check the labels. (My range conversion kit has a different set of letters on the NG orifices (A-G) and the LP orifices (L-R). Others use different colors for each orifice.) Then open the oven and swap the broiler orifice and the bake orifice. Rotate the air flow valve appropriately.
I hope this helps.
Sep 02, 2011 | Maytag Kitchen Ranges
WE HAVE A BRINKMAN GRILL AND BOUGHT THE LP TO NG CONVERSION KIT THAT IS RECOMMENDED FOR THIS GRILL ...KIT HAS TOTAL OF 6 ORFICES AND THE GRILL IS A 5 BURNER, WITH SEAR AND SIDE GRILL SO THAT MAKES 7..NOT...
Some Brinkman grills have the LP orifice installed on the NG orifice directly from the factory.
If that is true, you remove the LP orifice and the NG orifice is already there. Check instructions in the conversion kit and look for this detail carefully. I just did a Brinkman conversion and instructions were very confusing. The orifices in the kit are not used (on my unit).
Gary
Aug 21, 2011 | Garden
I like to know how to change from natural gas to propipe
You must buy first the appropriate conversion kit for your fryer, you can check and order only with the authorized parts dealer. Conversion kit consists of burner and pilot orifice and gas valve spring and stickers (propane) and installation manual. Propane orifice has smaller bore than natural and gas valve spring is for propane is thicker than natural gas valve spring.
Jun 03, 2011 | Welbilt Kitchen Appliances - Others
I bought a Char Broil 2 burner model 463243911 with the natural gas conversion kit. This kit provide just one orifice, thus my question is: where I need change the orifice considered that this model has...
The conversion kit has one orifice for the side burner. The two maim burners are sized for natural gas once the LP orifices are removed. Joe
May 01, 2011 | Garden
Hi I am trying to convert my Dacor stove/oven from NG to Propane. We can't find the conversion kit anywhere. Any ideas?
Hi, to convert from NG to LP is easier in some ways but harder in others. The pressure part is easy because LP runs at the same pressure that comes into the house so the regulator is normally locked wide open to allow a direct by-pass. You could just as easily remove the regulator and plumb straight in from the houseline. You don't say what model but usually the sealed cooktop burners will need smaller orifices and the oven and broiler orifices are adjustable. If that is the case, the oven and broiler orifices can be tightened until they bottom out which be the correct output for LP. You would need to remove the cooktop orifices and find replacements which are correct for LP, these are non-brand specific. Honestly, if you go to repairclinic.com and enter the brand and model number, I'd be surprised if you couldn't find the conversion kit. Even the Dacor site should be helpful. I found many different kits available at the repairclinic.com site even without a model number. Best of luck.
Jan 29, 2010 | Dacor Preference SGM365SS Gas Cooktop
Lg dryer - gas
If you do not have the original orifice you will have to order a natural gas orifice and replace the LP one with it. It is just a small brass threaded part with the correct size hole in it, located right at the end of the burner. For a LG dryer it is probably part number 4948EL4001B but you should get your model number from the sticker just inside the door and order the correct part from your nearest servicing dealer. You can find LG servicer's in the US on line at http://us.lgservice.com/index_b2c.jsp
Nov 02, 2008 | Dryers
HI, I'VE JUST BOUGHT A DCS FREE STANDING RANGE, BUT THIS UNIT IS FOR NATURAL GAS CAN I USE PROAPNE IN THIS UNIT
No,you have to convert it to propane.The regulator,orfices need to be changed.Call sears or where you purchased the oven and ask them for a conversion kit.Its also not difficult to do.
Mar 07, 2008 | Kitchen Ranges
Sears 61301 Gas Kitchen Range Logo
278 people viewed this question
Top Sears Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Sears Kitchen Range Expert? Answer questions, earn points and help others
