Question about Eureka Vacuums
Eureka the Boss Smart Vac. Hose has suction, but still isn't picking up. Weird.
    Novelist:
  • 97 Answers
Your belt is probably broken. Check your belt and make sure your brushroll has not seized. If both of those check out ok, (because the smartvac belt doesn't stretch,) the belt tensioner assembly may have gone bad.
-R
Posted on Aug 11, 2008
My eureka boss 5856 has suction through the hose, but the cyclone isn't spinning and it will not pick up anything. I have tried using it normally and with just the hose and it will not pick up.
Is the suction strong or weak?
Have you cleaned or replaced the filter?
A plugged filter will restrict air flow and cause vacuums to lose the ability to work properly.
Mar 10, 2017 | Eureka Vacuums
Where is the reset button the eureka the boss smart vac
There are many different models of Boss Smart vac so I can't say for sure without your model number but it most likely does not have a reset button. It may have a reset switch built into the motor.
Feb 26, 2017 | Eureka Vacuums
Eureka Smart Vac The Boss no suction from either setting. I have taken it apart trying to see if it was clogged but it isn't. Checked the hose it is not sliced.
Remove the bag cover and feel for suction above the motor. If their is suction there then check the bag compartment is sealed. You can drop a coin down the hose to check for blockages all the way to where the bag attaches.
Aug 16, 2013 | Eureka Smartvac 4870 Bagged Upright Vacuum
I replaced the belt in our Eureka Boss Smart Vac, it still seems loose, it uses a type R belt. The beater belt still doesn't seem to turn properly and seems that it doesn't pick up very well when I use it...
Check to see that the beater brush is not frozen up. Pull the brush and clean it, spraying some WD40 on each end piece that holds the brush in place. Also be sure the belt is properly installed so that the brush turns in the correct direction. If the brush is not turning or not turning in the correct direction, it will not beat the dirt from the carpet so that it can be picked up by the vacuum's suction.
Oct 01, 2010 | Eureka Vacuums
Why does my vacuum leave a trail of hair on my floors when it's being pulled backward but suction up fine when it's going forward?
It is because the belt is worn and stretched. when you go forward there isn' t as much resistance and the brush can turn and pick up, but when you go back there is more resistance and doesn't pick up. You simply need to replace the belt. Here is the belt you need:
Eureka Boss 5849 Belts
May 20, 2010 | Eureka 5849A Boss Bagless Upright Cyclonic...
I have a Eureka 'The Boss Smart Vac'. The beater
Yes, you need to replace the belt. You should actually change this belt every year. Here is a link to the belt you need and the manual which has instructions:
Eureka The Boss Smart Replacement Belts
Owner's Guide (3,666K download)
Dec 09, 2009 | Eureka Smartvac 4870 Bagged Upright Vacuum
I have a eureka the boss smart vac petlover vacuum and I cannot find the book on how to replace the belt. I have opened it up, but there is a silver roller that is confusing me.
Either go directly to the Eureka internet site, or GOOGLE "eureka boss smart pet lover manual". Several options should be displayed to download the needed manual.
Oct 10, 2009 | Vacuums
No suction on my eureka boss smart vac. The belt is fine and the roller moves. I just changed the bag but no dice. any insight?
I know this is an old question but this is a good vac and maybe I can help somebody else some day, wish I'd figured this out a couple months ago when this problem first started. :} Anywho, this is another option from an amateur; I don't know the right terms but here goes: Right below the yellow flow knob (Floor/Hose) are the tops of two hoses, one to floor beater, one leading to hose. There is a sort of black clip holding these in place. Open it up, it hinges toward the front of the vacuum. On the back of the vacuum to the right of the lower cord wrap is a gray screw-looking thing, with little pix of locks imprinted above - one locked, one unlocked. Turn the screw toward unlock. Take the top of the black tube that leads to the hose and maneuver it out of the hole it's in, and you may find your clog in the top there. I found just a handful of dog hair, leaves and sticks stuffed in that tube but it was dense enough to stop flow to the hose. Removing it fixed the problem completely.
Aug 15, 2009 | Eureka Smartvac 4870 Bagged Upright Vacuum
Hose has no suction
Most uprights need to be in the up-right locked position to enable the hose pickup.
Jul 25, 2008 | Eureka 4874 Bagged Upright Vacuum
Vacuums Logo
334 people viewed this question
Top Eureka Vacuums Experts
charlesjo336
Level 1 Expert
JoeVacs
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
