Question about Kodak EasyShare Z1275 Digital Camera
DIGITAL CAMERA SCREEN FOR KODAK Z1275
Could you please let me know where you purchased your replacement screen from.
I live in the UK and have been on the internet for hours trying to source one.
I have tried KODAK but they do not appear to sell this part.
Thanks...
I DONT KNOW IF KODAK IS THE SAME WORLDWIDE BUT I GOT MY SCREEN DIRECTLY FROM KODAK FOR 30 DOLLARS. TRY KODAK SUPPORT ONLINE.
Posted on Aug 11, 2008
I have kodak easy share z1275 camera, whenever i try to take a click of photo the screen shows friction or some thing like shaky images gets clicks, means the photo which gets clicked shows all blur...
Check your camera settings may be its on Night mode .Make sure you using the Auto ,Landscape ,Portrait etc..NIght mode can use with the help of Tripod.
Sep 27, 2010 | Kodak EasyShare Z1275 Digital Camera
How to replace a cracked screen on a kodak Z1275 camera
http://www.clickondavid.com/LCD7430.pdf
This might help you. Its an illustrated method for Replacing an LCD Screen on a Kodak EasyShare CX7430. This may be applicable 4 your model also.
Feb 05, 2010 | Kodak EasyShare Z1275 Digital Camera
Z1275 view screen partial closed upper left corner shows a small area I
In order to answer your quarry.
Please explain exactly what you see on the LCD and what effect it has on the use of the camera.
Dec 09, 2009 | Kodak EasyShare Z1275 Digital Camera
Screen stays black
dear it has nothing to do with on and off its simply a setting problem
May 05, 2009 | Kodak EasyShare Z1275 Digital Camera
INFO ON REPLACEMENT DIGITAL CAMERA SCREEN
Screens for the Z1275 can be found on Ebay for as little as $20 w/shipping. The rear case of the camera is held in place with 5 screws, one of which is under the left side panel (looking from the rear). Make sure the battery and SD card are removed before starting. Remove the right side panel by removing the two black screws and by opening the battery door it will help give you access to lift it away. Remove one chrome screw on the bottom back and one black screw the bottom left holding the left side panel in place. Slide the left side panel downward and remove the last screw underneath. The rear case is now held in place by several snap-fit points around the edge. Using a small nylon pry tool, strong fingernail, or a small flat screwdriver, work your way around the case and carefully pry the sides and bottom enough to release the rear case. Once the back is removed you can release the LCD from its frame by gently prying the frame around the LCD and lifting it up to gain access to the ribbon cables attaching it to the circuit board. The larger cable is held in place by a locking bar on the socket that has to be lifted to release it. Using care not to break it, pry the bar up so that it pivots 90 degrees. The smaller cable uses a slider that can be released by pushing the two tabs on either side of the socket toward the cable until it stops (only a millimeter or two). At this point the cables should slide out quite easily. Reverse the procedure to install the replacement LCD.
Aug 11, 2008 | Kodak EasyShare Z1275 Digital Camera
BROKEN LCD KODAK Z1275- NEED INSTRUCTIONS ON HOW TO REPLACE
The LCD is pretty east to replace once you remove the case screws the case will separate with a little force make sure you mark down the screw "possion". This can be crucial now once the case is off. be careful the LCD can have 2 wires and a ribbon cable or 2 ribbon cables or just 1 ribbon cable. their will be a latch at the end of the ribbon cable lift it up and remove the ribbon cable if their are 2 do the same to both. if their are soldiered wires make sure you remember witch potion they were in. and put the new LCD in the same way you took the other one out. OH YEAH WATCH OUT FOR THE FLASH COMPOSITOR. It can bit like a starving dog on a steak bone. 300 volts is enough bite to make you through the camera across the room LOL take it from me I know LOL. Well just reverse the steps and you should be ok. Hope this helps.
Apr 22, 2008 | Kodak EasyShare Z1275 Digital Camera
Kodak EasyShare Z1275 Digital Camera Logo
61 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
