Question about Refrigerators
Cannot install water line
I recently purchased the LG lfc20760 model fridge with French doors and the bottom freezer. My previous fridge had a water line and therefore i rejected installation. When i attempted to install the water line i noted no place for it to be installed. There appears to be one black rubber hose at the rear of the fridge which i believe is for drainage. There then that there are no other placed were a line could be connected. any help?!
Thanks
I too had to scratch my head to locate where to connect the water line for the ice maker. Looking at the rear of the frig on the bottom right you will see a white plastic cover that the black plastic line goes into. There is a screw on the right side. Undo the screw and then pry off the white plastic cover. You will see a black plastic cap over the threaded water line connector. This is where you connect you line as approprite. I hooked up the line and turned the water supply back on and then you have to turn on the ice maker. I works great. Problem is the manual is not clear at all. Guess they assumed that the installler would be hooking it up. Once you know what to do is is a piece of cake. Good Luck. Doug S. in Poland, OH
Posted on Oct 25, 2008
I have an Amana side by side fridge/freezer, I replaced the water line to the ice maker, now appear to have an air lock....if I pour water into the ice maker, it makes ice cubes, but no water comes in on its own.......how do I get this water to flow on its own??
Posted on Jun 14, 2010
Ice tastes bad
If It were me I would change the filter in the fridge, that always worked on mine.
Dec 03, 2013 | LG LRFD22850 Bottom Freezer Refrigerator...
I CANT OPEN THE FRENCH DOOR
My guess it that they are frozen shut which means the little door heaters are not working or you have a bad door gasket. If you have a hair dryer I would blow it around the seams of the doors until they give. Or you can unplug the frige and let it thaw for a bit then try. Or the break between the frige air and the freezer may be frozen closed then the pressure difference can hold the doors shut, in that case you need to unplug it for a bit and try opening the doors periodically
Sep 06, 2012 | LG LFC20760 Bottom Freezer French Door...
How to resolve our "lack of water" issue..within the last few weeks, the water dispenser's water flow lessen with each day-now it does not just doesn't work
there may be a problem with the water lines or bottles in the fridge compartment is frozen raise the temp in the fridges to about 38 for a couple of days and this should unthaw the lines
Apr 13, 2010 | LG LFX25971ST Bottom Freezer French Door...
Error code er ff.how do i fix this? freezer is still freezing but fridge is warm.
The error code appears when there is an abnormality of BLDC FAN Motor for Freezer. It circulates cold air from the freezer to the fridge to allow cooling. Check the motor wiring harness for poor connections. If the motor is not working at all, you need to replace it.
To remove the fan and motor assembly:
  1. Remove the freezer shelf. (If your refrigerator has an
    icemaker, remove the icemaker first).
  2. Remove the plastic guide for slides on left side by
    unscrewing phillips head screws.
  3. Remove the grille by removing one screw and pulling the
    grille forward.
  4. Remove the Fan Motor assembly by loosening 2 screws
    and disassembling the shroud.
  5. Pull out the fan and separate the Fan Motor and Bracket.
  6. Replace fan motor assembly in reverse order.
Oct 27, 2009 | LG LFX25960ST Stainless Steel French Door...
Ice Maker Hookup for LG side by side with freezer on bottom. We connected the water line to the fridge to the connection in back.... both connections, the one up top and the one on the bottom. We are not...
ok...1st there is only one connection to the fridge at the valve.2nd check the filter and see if one is present.3rd make shure the child lock out feature on the dispencer is not activated.
Aug 06, 2009 | LG LFX25971ST Bottom Freezer French Door...
Refrigerators Logo
317 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
