Question about AOpen MX4LR (91.89Y10.002) Motherboard
Memory Can I fit A 2 Gb Memory card in 1 slot only, Leaving the other slot not used.
  • 6,487 Answers
Yes you can use 1 stick of 2 GIG of RAM for this motherboard, because your motherboard supports up to 2 GIG RAM...
Hope that helps..........
Posted on Aug 11, 2008
4 gb memory card placed into camera. Camera says card error. Why?
The SD630 is designed to work with SD cards. Your 4GB card is actually an SDHC card. While SDHC cards will fit into the slot, they are electronically incompatible and will not work in SD devices.
You need to use SD cards, 2GB and smaller.
Nov 21, 2010 | Canon PowerShot SD630 Digital ELPH / IXUS...
I upgraded my RAM to 1 Gig but it's still showing only 256 meg. Why?
Hi this model sopport 2Gig Memory Ram.
RAM Technology DDR SDRAM Installed RAM 512 MB Max Supported RAM 2 GB Number of Memory Slots 2 x DIMMs Supported RAM Speeds 400 MHz • 333 MHz Installed Cache Memory 256 KB
Please check in to your Bios system maybe share memory Video or capacity is setting
Nov 03, 2010 | Dell Dimension B110 PC Desktop
Where to install memory card
Depending on your model of Blackberry the memory card will either fit in a slot on the side of your phone (under a cover) or if you remove the battery you will see a slot for the card. The full size adapter is so that you can read the card in a standard memory card reader plugged into your PC.
Jul 28, 2010 | SanDisk 2GB microSD Memory Card
Fitting RAM
Here are some instructions that should work for all 3000 series laptops.
http://support.gateway.com/s/Manuals/Mobile/8512061_Apache_RPL.pdf
Mar 31, 2010 | Computers & Internet
How much of GB micro SD card does htc tytn-2 support ?
THe MicroSD card slot which can handle cards up to 32GB to satisfy your thirst for videos/music/photos/applications. MicroSD cards are now pretty cheap, I saw an 8GB card recently for $18.
http://theonbutton.wordpress.com/tag/htc-tytn-ii/
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Apr 02, 2009 | HTC TyTN II Smartphone
RAM NOT DETECTING
I had the same issue on this board where it came with a Samsung 512 MB 533 MHz PC2-4200 DDR2 DIMM. I put in a 1 GB Kingston with the same specs (533 MHz PC2-4200 DDR2) and it would not recongize the Samsung anymore with the system reading as 1 GB of RAM instead of 1.5 GB. Tried every configuration and would only see the Kingston. It would only see the Samsung if I pulled out the Kingston regarless of the slots I use. So, I just bought the exact same make/model of Kingston and it recognized that fine and the system now has 2 GB of memory (max this board allows). And, I had already installed the latest BIOS for this board from Intel before doing all this so wasn't an old BIOS. I'm figuring the board didn't like something about the Samsung memory (speed, module configuration, etc.) that made it not play nice with the Kingston. If interested I bought the DM8400A/1G Kingston modules. And, this board appears not to support dual channel memory. Only has channel A, slots 0 and 1, and I read need two channels to support dual channel (seems obvious). Boards that supports dual channel memory normally have 4 memory slots, two for channel A and two for channel B, then put in matching modules in slot 0 for channel A and B and have dual channel memory access. And if want more ram, then matching modules in slot 1 for channel A and B.
Jun 25, 2008 | Intel D102GGC2 Motherboard
RAM Memory upgrade: 1gb modeles recognized as 512mb
You may have incompatible memory. double check your order and use only recomended name brand memory such as Kingston, you can look up the correct memory on their website, or on newegg.com
Apr 23, 2008 | Dell OptiPlex GX270 PC Desktop
AOpen MX4LR (91.89Y10.002) Motherboard Logo
89 people viewed this question
Top AOpen Computers & Internet Experts
Michael Galve
Michael Galve
David
David
Alun Cox
Are you an AOpen Computer and Internet Expert? Answer questions, earn points and help others
