Question about Dell 1815dn All-In-One Laser Printer
Dell 1815dn all-in-one-laser
I have a Dell 1815dn all-in-one laser printer and no longer can find the manual. The scanner was working but is not working now. It is locked. How can I unlock it?
  • 4 more comments
  • Roberta Egan Aug 11, 2008
    Thank you for the reply. I found the blue tab but cannot move it to the unlock position. Do I need to do something else first?
  • Roberta Egan Aug 18, 2008
    Thanks for solution. At first I could not move the blue tab but then it worked.
  • TheKropps Sep 02, 2008
    Turning off the printer and waiting less than 5 minutes to slide the switch worked for me. THANK YOU!!!!
  • Anonymous Feb 27, 2009
    Is mine just being stubborn? It won't budge....
  • Anonymous Mar 04, 2009
    how to unlock scanner
  • Anonymous Apr 23, 2009
    How do I unlock the scanner
    Genius:
  • Dell Master
  • 1,056 Answers
There is a little tab that locks the scanner bar.
Open the flatbed cover, and you'll see it in the left corner closest to you.
To unlock it, reach your hand (palm up) into the area the the paper comes out in.
Slide the tab to the unlock position (you'll be able to see it through the flatbed area.
If you need a complete manual for the MFP, you can go to the Dell website, in the support area, and download a copy of it.
Posted on Aug 11, 2008
  • Coss Aug 11, 2008
    It just slides about 1/2" forward or backwards.
    Did you try it with the power off? Or the power on?
    I would suggest off, so that the drive mechnisim is not pulling against it.
    How old is the unit?
  • Coss Aug 18, 2008
    Great!
    It takes a few minutes after the power is off to release the tension on the scanner bar drive. That tension against the lock is enough to make it hard to unlock.
Mettre l'imprimante hors tension et attendre 3 ou 4 minutes avant de pouvoir tirer sur le bouton bleu pour debloquer le scanner.
Posted on Mar 15, 2009
6ya staff
SOURCE:
Dell 1815dn will not scan legal size documents
I had exact same issue, could not scan in any size larger than Letter; changed Scan Default settings for paper size but made no difference. Based on dmf1984's suggestion I did same: went to Start -> Dell -> Dell Printers -> Dell Laser 1815dn -> Network Scan and changed Scan Paper size to Legal hit apply then tried scan again... problem solved92a90e38-52a9-4018-8666-d2da0be7f6f8.jpg
Feb 14, 2012 | Dell 1815dn All-In-One Laser Printer
How to unlock a dell laser MFP 1815dn
You may want to try the following:
There's a little blue toggle switch where the copies/scans come out from.
Pull the blue switch toward you, turn off the printer, wait a few seconds, and turn the printer back o
I hope this helps.
Good luck!!
Mar 01, 2011 | Dell 1815dn All-In-One Laser Printer
Why does my computer say that the scanner for the Dell 1815dn laser is unavailable? When I was installing the drivers, it asked me to connect the scanner in the middle of installation. I have Windows...
hello
go to the link below , download the drivers for your OS Windows 7 (32 or 64 bit versions available)
make sure you know what WIN7 you have . Did you download the correct version , 32 or 64 bit ?
after downloading driver, save to desktop.
disconnect printer from computer
open saved file and install, follow insyructions carefully and be prepared to connect the printer to computer when prompted.. hope this helps !
http://support.dell.com/support/downloads/driverslist.aspx?os=W732&catid=36&dateid=-1&impid=-1&osl=EN&typeid=-1&formatid=-1&servicetag=&SystemID=PRN_ALL_1815DN&hidos=BIOSA&hidlang=en&TabIndex=&scanSupported=True&scanConsent=False
Jan 09, 2011 | Dell 1815dn All-In-One Laser Printer
My Dell 1815dn printer - says the scanner is locked. Makes horrible clicking sound when I try to scan of make a copy. How do I unlock the scanner?
The scanner has a manual lock (a blue sliding switch on the base of the scan bed inside of the printing output slot.)
This prevents the scan head from damage when the printer is moved.
Look and reach inside the paper outlet and pull the latch (located on the left) towards you.
If you have any more questions, just come back here and leave a comment - I'm happy to help.
May 20, 2010 | Dell 1815dn All-In-One Laser Printer
MFP 1815 D Unlock Scanner message
Inside the print tray (where the paper comes out) on the upper right there is a blue lever. Pull it toward you and that will unlock the scanner. I just did this and restarted my printer and it worked! Hope this helps!
Jul 13, 2009 | Dell 1815dn All-In-One Laser Printer
Dell laser mfp 1815 dn "scanner locked" message
When you lift the scanner lid look to the left bottom. you should see a green slider button. If you stick your hand in the output tray and get it rigth under the green slider you will find a lever. Move that thing backwards or forwards, that is your unlocker.
Jul 06, 2009 | Dell 1815dn All-In-One Laser Printer
Scanner locked printer dell laser mfp 1815dn
The lock for the scanner is on the roof of the cavity where the printed paper comes out. Simply flip it to the other position and restart the printer.
Jun 03, 2009 | Dell 1815dn All-In-One Laser Printer
Dell 1815dn All-In-One Laser Printer Logo
3,513 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Ekse
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
