Question about Cuisinart ICE-20 Automatic Frozen Yogurt 1.5 Quart Ice Cream Maker
Put the ice cream bowl in the dishwasher
I put the part of the ice cream maker in our dishwasher. This is the part of the machine that you put in the freezer, that is where you pour in all the ingredients and rotates as the ice cream is made...I saw where you shouldn't expose it to heat or the dishwasher. Is it completely ruined now?
  • 8,596 Answers
The only way to tell is by putting it in the freezer for 24 hours, and then trying to make a batch of ice cream. If it doesn't freeze or make the ice cream properly, then you will need to get a replacement bowl from Cuisinart - they are available.
-Tha Mp3 Doctor
Posted on Mar 20, 2009
Discovery kids ice cream maker instructions
Usually with these cheaper ice cream makers you put the bowl in the freezer for 12 hours and then put it on the machine and turn it on . Very important point turn it on so it is churning. Why so that what ever you pour in doesn't freeze solid and stop the agitator from churning. Most ice cream is Cream and sweeten condensed milk and flavouring. I do not have this exact ice cream maker but the one I do have has made three different ice creams in it so far. Add 1000 mL of cream to 250 mL sweeten condensed cream. Watch it for about 20 minutes till ice cream is solidifying then transfer to an plastic icecream container and put in freezer for at least 4 hours.
Aug 19, 2015 | Ice Cream Makers
I need to down load a manual for ge ice cream maker model 106765
  • 1
    Place the mixer bowl in the freezer. The amount of time required depends on the temperature of your freezer, but you should expect to leave it in the freezer for about one day prior to use. To check if the bowl is frozen, shake it gently. If you don't hear any liquid sloshing around inside, it's ready to use.
  • 2
    Place the mixer bowl onto the motor base when you're ready to make ice cream. Insert the mixing paddle into the bowl and place the cover over the bowl.
  • 3
    Turn on the ice cream maker and pour the ice cream mixture into the hole at the center of the appliance until it reaches the fill line. Do not exceed the fill line, as the ice cream will increase in volume as it freezes. Use the low setting if you want a firm ice cream and the High setting if you want a softer consistency. Do not add nuts, candy or chocolate chips at this stage as they can become hung up in the mixing paddle and stop the machine.
  • 4
    Cover the center hole with the cap and allow the ice cream maker to run for 30 to 45 minutes.
  • 5
    Add mix-in ingredients such as nuts and candies two minutes before shutting down the machine.
  • 6
    Turn off and unplug the machine prior to removing the ice cream from the bowl. GE recommends using plastic or rubber utensils to avoid scratching the inside of the mixer bowl.
  • Read more: GE Ice Cream Maker Instructions '
    Sep 09, 2011 | Gel Canister 106765 1.5 Quart Ice Cream...
    I purchased the Gelato 2500 for my father-in-law and he shipped it to South America. They are saying that they put the product in the bowl and close the cover and nothing happens. The compressor is...
    MANY of these require using alcohol to transfer the heat between the bowl and the bowl that is refrigerated in the machine. They usually use gin. This is an absolute must for operation in those that require it.
    Nov 12, 2009 | Nemox Chef 2500 2.5 Quart Ice Cream Maker
    Ice cream maker instructions
    I have the booklet for this machine.
    1) you can use any IC recipe as long as it does not exceed 1 quart. This is for vanilla:
    1/2 c sugar
    1 1/4 c half&half
    1 1/2 c heavy whipping cream
    2 eggs 2 tsp vanilla
    with mixer beat eggs and sugar until thincl and cream colored. Addthe cream and vanilla mix well.
    the machine:
    you want to put the freezer cylinder in a plastic bag (to prevent freezer burn) and then put it in the back of your freezer until completely frozen 6 to 22 hours. You should not be able to hear liquid slosh when you shake it. For making stuff quick they recommend keeping it in the freezer in the bag.
    step one: Put maker on flat surface.
    two: Put the mixer bowl on the base.
    three: Place frozen cylinder into to the mixer bowl (the big one) do this when you are ready to start the IC because the cylinder begins defrosting right away.
    four: set the paddle on top of the cylinder, placing the peg on the freezer cylinder inside the peg hole on the paddle
    five: Place the cover over the mixer bowl, locking the grooves on the motor base. Plug in, turn on, the bowl and cylinder will begin to turn.
    six: Pour the recipe into the feeder hole of the cover then put the lid on.
    You will need 20 to 40 minutes or until mixture is frozen. Don't stop the machine until done. If you want hard ice cream spoon the soft serve into an airtight bowl and put it in the freezer till it is like you want it.
    Hope this helps, Elizabeth
    May 17, 2009 | Ultrex Double Canister 2 Quart Ice Cream...
    How does this ice cream maker work? I forgot!
    Just freeze the bowl, add the ingredients for your favorite recipe & dasher, put on the top and turn it on.
    May 06, 2009 | Deni Automatic Ice Cream Maker 1.5 Quart
    Ice cream is soupy & when I freeze it it becomes icy
    Freeze the bowl for at least 24 hrs, rather than the 12 hrs the manual suggests - it will make all the difference in the world. For really thick ice cream, freeze the bowl for a day, and then put the ingredients in the freezer until the outer rim becomes frozen. Very delicious!
    -Tha Mp3 Doctor
    Dec 10, 2008 | Cuisinart (ICE-20) 1.5 Quart Ice Cream...
    I have the automatic frozen yogurt-ice cream & sorbet maker ICE-20 series made bby CUISINART. The first few times the icecream came out perfect & great. I made ice cream yesterday and it was soupy. I put...
    I would actually let the freezer bowl thaw out on a level surface. Then place perfectly level back in the freezer for 24 hours. Should work again. Enjoy!
    -Tha Mp3 Doctor
    Ultrex ice cream machine
    Put the metal canister into the freezer overnight. This replaces the ice and salt in the old bucket style ice makers. After the canister is frozen use any ice cream, yogurt, or sherbet reciepe. Ben and Jerry's have a good website for receipes.
    Sep 01, 2008 | Ultrex Double Canister 2 Quart Ice Cream...
    Salton hand crank big chill ice cream maker
    I bought one new, and it had a great recipe for Kiwi fruit ice cream, using kiwi fruit and oranges. I can't find the recipe book. You make just over 1 l of fluid ice cream mixture, the bowl must be pre=frozen for at least 15 hours, just put the liquid in the machine and crank the handle in quarter turns (the square outer box helps measure this!) every 5 min for the first 30 min, and then half turns every half hour or so.
    Jul 06, 2008 | Salton ICM15 BIG CHILL 1.5 Quart Ice Cream...
    Cuisinart ICE-20 Automatic Frozen Yogurt 1.5 Quart Ice Cream Maker Logo
    212 people viewed this question
    Top Cuisinart Ice Cream Makers Experts
    Greg Cann
    Greg Cann
    Jay Finke
    Jay Finke
    Oloyede Monsuru
    Are you a Cuisinart Ice Cream Maker Expert? Answer questions, earn points and help others
