Question about Sony Televison & Video
I have a Sony Handycam DCR-PC100 that is now flashing an error code C:31:23 in the display when I try to play back the DV cassette in the video camera. Please advise what this code means and if the footage on my DV cassette is in danger. Thanks.
  • WDWDuncan Aug 11, 2008
    Tried that and now I am getting error code C:31:40 instead. Do you know what these error codes mean?
    Much thanks.
    Master:
  • 521 Answers
, giveit a bash canmake it work. Not too hard, just a few sharp smacks on the side.
It's something in the cassette carrier mechanism.
or
it could be the memory stick. you have to remove it, then, again place it properly it may work check it out.
or
The error message is related to one of the reels,
the black rubber one .
open up the cassette compartment, and the black rubber thing
comes out .... you put it back and cam would work again,
The reason for the alarm is because the "s-reel" is not fit in
same location. There must be a "locker" for it, put on top of
the pin, which apparently have fallen off my cam.
you can use the bis pen .you break the BIC pen, and the ink-pipe had exactly
the same dimension as the silver pin (approx 1.5 mills)
you cut it to a good length (not sticking out), put the black reel
in place again, and the BIC-pipe as a "new" lock on the pin.
Posted on Aug 11, 2008
  • 319 Answers
Please check out this discussion that addresses your problem!
Brian
  • Sony Master
  • 13,434 Answers
  1. Remove the battery or disconnect the AC power adapter for 60 seconds.
  2. Insert the battery or reconnect the AC adapter.
  3. Turn on the camcorder.
  4. If the error message appears, service may be required.
If your camcorder still shows the same error code, then you'll have to send in your camcorder for service.
Try playing the dv casette on another player, it should be fine.
  • Ekse Aug 11, 2008
    sorry, can you say which expert of us 3 are you responding to?
SOURCE:
Sony Handycam DCR-PC109 NTSC minicam--"Reinsert
The C31 indicates that there is a motor movement problem. I don't have the manual handy at the moment, but the :23 will indicate which movement is having the problem. This is not typically a DIY repair. I woul d strongly suggest that you check the fixed repair cost from a Sony authorized service center. This will not only repair the unit, but also reset it back to factory specifications.
I'll look up the error code tonight and try to update this.
Dan
May 26, 2011 | Sony Handycam DCR-HC42 Mini DV Digital...
Using Windows 7 virtual machine (via Parallels Desktop 5). When I plug in my sony DCR-PC100 mini-DV camcorder Windows doesn't see it.
Windows 7 sucks. Try "downgrading" to Win XP. I've had many problems with my new computer which had Windows 7, which have all been solved after I made the downgrading.
Feb 08, 2010 | Sony Handycam DCR-PC100 Mini DV Digital...
Sony DCR-hc42 video camera problems
Buy a Sony-make head cleaning cassette and play it in the camera for 10 seconds. Do not play for more time, neither forward or reverse the cleaning cassette, otherwise you will damage the head of the camera. This cleaning cassette is to be thrown when it is fully played (and not rewound!).
Nov 30, 2009 | Sony Handycam DCR-HC42 Mini DV Digital...
When I insert the cassette into the camera it won't close.
Try the following link to troubleshoot this issue:
http://www.kb.sony.com/selfservice/microsites/search.do?cmd=displayKC&docType=kc&externalId=C190805
Aug 08, 2009 | Sony Handycam DCR-HC42 Mini DV Digital...
I need a USB cable 4-pin Mini I-Link
Check your computer user’s manual, if your computer doesn’t have a Firewire port, you need to buy an IEEE1394 card to install in your computer and a firewire cable to connect your Mini DV. Check with your local computer store
Jun 03, 2009 | Sony Handycam DCR-PC100 Mini DV Digital...
"SONY 'InfoLITHIUM' SYSTEM" Error
when I opened up the camera, the tape part of the cassette was hanging out. I tightened the tape and reinserted the cassette. this seems to have fixed the problem. hope this helps.
May 07, 2009 | Sony Handycam DCR-TRV19 Mini DV Digital...
Error display C31.23
code indicates that you should remove the cassette and insert again, then operate camera.
disconnect power cord and battery pack. after reconnecting operate camera,
Oct 13, 2008 | Sony Handycam DCR-TRV30E Mini DV Digital...
Sony 2100 video camera
Sony.com says call 1-800-222-7669 Mon-Fri 8am - Midnight or Sat-Sun 9am - 8pm EDT. This is Sony Camcorder Tech Support, if that doesn't work visit sony.com support and look for the repair link.
Jul 08, 2008 | Sony Handycam DCR-VX2100 Mini DV Digital...
Sony Handycam DCR-TRV19E Pal do not eject tape
I think, your camera requires new DV Mechanism replacement.
May 08, 2008 | Sony Handycam DCR-TRV33 Mini DV Digital...
Televison & Video Logo
60 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
