Question about JVC AM FM CD DET FACE CAR STEREO
HELP STEREO CUTS OUT!
I just installed a jvc car stereo. When turning up the volume with the radio or cd at about 15-17 it will cut out and starts making a crackling noise. I can turn it all the way down and then turn it back up again and it's fine, but if I go up over 15-17 it does it again. The stereo I had in the car before this one did not do this, and my daughter had installed this jvc stereo in her car before we put it in mine and it did not do this.
  • 1 more comment
  • domingafoltz Aug 13, 2008
    I checked for a bad connection and everything was all good and I have had a stereo in my car before this one that was 10 times better and did'nt have this prob. and my speakers are aftermarket speakers i installed when I installed the first stereo I had. But thanks for answering and I will double check all connections again.
  • Thrillhouse Aug 18, 2008
    JVC KD-G646 im having similar trouble. It wont play cd's at all. And when im using the USB port, it plays, but soon as i turn it up it cuts out and starts "reading" my jump drive again. The radio works fine , and can be turned up all the way if i want.
  • Anonymous Feb 03, 2009
    just put my new stereo in my and it cuts out when i turn it up to 18 and over
    Problem Solver:
  • 3 Answers
Ok , ive found the problem with mine. I checked the voltage between the earth wire on the head unit and the battery in the car. I found that when i turned the headunit up to around 17-20 there was up to 3volts differance, which is when it would cut out. So ive run a new earth wire and she's all sweet . Even the cd player works now.
Posted on Aug 19, 2008
I have a boat and installed a jvc stereo and a 1000w kenwood amp to run the 10 inch sub jbl and running 4 6by9 3 ways and 2 twitters and the stereo cuts out at 33 volum I am running direct to the battery for the amp. any help with this one
Posted on Aug 28, 2011
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,362 Answers
1-Speakers are too low wattage for stereo
2-bad connection
Posted on Aug 11, 2008
    Problem Solver:
  • 51 Answers
We can help you.Welcome to contact www.playpower.biz
Posted on Aug 22, 2008
Car stereo cuts out
It is possible a self-protect feature may be shutting down output. Check all of your wiring, following the manufacturer's instructions exactly. Faulty wiring is a major cause of poofed audio output devices in car audio. Any short in wiring, or an open (intermittent or otherwise) can cause a problem here. Internally, bad solder connections where the output devices solder to the board could cause problems too.
Jul 03, 2007 | iLO XM-MP3-CD Car Stereo
What wire runs steering wheel controls on a 2500 gmc sierra
This is not a question for JVC but more for GMC. On the JVC radio side, if it can be controlled via steering wheel, you will see a blue with yellow stripe cable that states [STEERING WHEEL]. Not all radios can adapt to steering wheels controls.
Aug 02, 2014 | JVC AM FM CD DET FACE CAR STEREO
Jaguar 1991 XJ6 stereo stops playing when i turn on the headlights help please
Either...
bad stereo or bad installment if its after market. if so they might tapped into the headlight circuit and when you tunr on the lights it deprives the stereo power.
Aug 09, 2012 | 1991 Jaguar XJ6
Jvc car radio
Speakers have a tendency to change characteristics. Take the radio out and carefully disconnect one by one speaker. Don't disconnect all of them if you don't know which wire goes where. Then try increasing volume to the cut off limit. You may be lucky to find the speaker that cause the trouble.Try a different speaker prior to unit repair attempt
Jan 21, 2010 | JVC AM FM CD DET FACE CAR STEREO
1986 NISSAN 300Z THE STEREO WIRE WERE CUT NEED COLOR CODE PLEASE TRYING TO INSTALLED A FTER MARKET STEREO JVC
i have attached the wiring info you requested. be sure to test all wires with a meter before connecting. also a link to metra's website if you need an installation kit
http://www.metraonline.com/fitl.aspx
Battery RED/BLACK (+) RADIO HARNESS Accesory BLUE (+) RADIO HARNESS Ground N/A THIS RADIO GROUNDS THROUGH THE CHASSIS MOUNTING BRACKETS. Illumination RED/YELLOW (+) RADIO HARNESS Dimmer N/A Power Antenna GREEN/BLACK (+) RADIO HARNESS LF Speaker (+) BLUE/WHITE LF Speaker (-) BLUE/YELLOW RF Speaker (+) BROWN RF Speaker (-) BROWN/WHITE LR Speaker (+) RED LR Speaker (-) GREEN RR Speaker (+) BLUE RR Speaker (-) PINK
Sep 02, 2009 | JVC AM FM CD DET FACE CAR STEREO
When i turn up the volume the deck turns off then turns back on
What kind of car do you have the stereo in? It sound exactly like a bad ground wire. To trouble shoot this, simply find a good clean ground point to hook the black wire from the radio to. you can usualy find somewhere behind the dash that the factory has grounded things to. I asked what kind of car, because some fords, and nissans do not have a ground wire in the factory radio harness, even though the adtor harness you may have used will have one. Hope this helps.
Aug 17, 2009 | JVC AM FM CD DET FACE CAR STEREO
The radio/cd player on my 01 yukon loses the sound randomly. Some times it works fine then othertimes it does it a lot. This all started a month ago. Before then I'd had no problems. I talked to a guy at a...
sounds like the amp is over heating and needs to be replaced
and yes there is most likely an amp in the system and it is eithor over powered or over heating
Jul 29, 2009 | Car Audio & Video
Volume on jvc home stereo receiver cuts off at a certain level
I had the same problem and found that when I moved the speakers apart further...It works as well as it always did before my 8 speakers were introduced..I think the sound was interfering with itself.. Try it !!
Jan 18, 2009 | Audio Players & Recorders
JVC Car stereo with cd shuts off when volume is turned up
Hi Ithink , you are trying to push too much power to your speaker setup. Your cd, tuner, player, is only go as loud as the volume at half way setting. Your speakers are , probally good ones that want more power, and making your player overheat and making circut protection cut power. I would say, you should use it at 15, and that is as loud as it should be played to aviod distortion and overheating.
I'm guessing max is like 25 or 30, Is that so? You can listen to louder tunes by installing an amplifier. Or if you have an amp in your system it may be overheating, I would really like you to let me know if you have been trying use it at volume higher than half the maxium volume setting, so I know I helped, and you can start looking into power amp's. You can crank it up for good parts, but most players were not made to send alot of juice to good big speakers at high volume level.
Tell me what you think, tooldoc
Dec 05, 2008 | JVC AM FM CD DET FACE CAR STEREO
JVC AM FM CD DET FACE CAR STEREO Logo
3,312 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
