Televison & Video Logo
Anonymous Posted on Aug 11, 2008
DVD Recorder LVW5101. Unit records ok but will not play back material it has just recorded
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jan 21, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
64
Points
Make sure you finalized the disc before playing on other dvd players or computors. chk out on menu.
Anonymous
Level 1:
  • Posted on Aug 12, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
64
Points
At present, I assume I hard several defective Discs. I use DVD-RW and have had good results. I also think I am having problems with Erased Discs. I need to do more experimenting. Thank you for your respoonse. I will keep you response in caseof further problems.
Why does not the philips dvdr3480 record?
I would start with the dvd format used for recording, the simplest being dvd+r and dvd-r. Does the unit play a pre-recorded dvd and/or cd? If not, the laser assembly would be the first suspect. The delay in reading discs can be a sign of a borderline laser. Is your record overwrite function turned on, this overwrites previous material when starting each new recording when using +-rw discs. Verify if a format is required for the type of disc used for recording, page 45. Is the correct country/region selected?
My Magnavox Digital Disc Recorder & Video Cassette Recorder will not play DVD-RW discs. How can I solve this problem or get a replacement unit.
It claims to play -RWs finalized in DVD-VIDEO format, not VR. If a disc is recorded/finalized on a different recorder, not all players can play it. This is the price we pay for the convenience of the digital system.
Disc say cant record,what disc do i buy
This model (PY90DG) DVD recorder supports the following disc recording formats: DVD+RW/DVD-RW/DVD+R/DVD-R for everyday video. These should record fine. The RW discs are for repeated recording/erasure while the R discs are once-only recording types - the R discs must be finalised in this deck to make them playable on other DVD players. DVD-RAM discs are NOT supported by this unit. This recorder will play MP3 files on a CD-R or CD-RW (not DVD-ROM) just fine as well, but will not record them.
Best discs to buy for this type of recorder are DVD-R (recommended brand - Verbatim or TDK if you can get them, but not Memorex). These are OK.
Philips DVD recorder, records dvds but won't play them
possible playback head damaged
Please rate my help++++Thanks for using Fixya
4helpful
4answers
Samsung DVD-SH855 DVD Recorder 250GB HDD playback freezes
Samsung dvd sh-855 i have the same problem wiht freezes when recording on timer mode.Recording in timermode with TV on is OK. But only connected whit HDMI cable, Component is OK in all modes!!!
My recorder is a XXE model = scandinavian.
Do anyone have a solution Please
Magnovox Dvd Recorder closing out disk
Put the disc back into the recorder.
Goto the setup menu.
Select Disc Edit. Press OK
Select Finalise. Press OK
Your DVD player is made by Funai (for future reference)
The User manual can be downloaded HERE. You need page 38.
1helpful
2answers
Recordes but dont play back
before you can watch a recorded DVD on another DVD player you must finalize the disc. to finalize the disc put the recorded disc into the DVD recorder, when the DVD loads it will show the titles that are recorded on the DVD on the screen
push the stop button it is the button with the square on it. the screen will go blank or it may let you watch whatever tv channel you are on if you have your tv ran through the recorder, push the setup buton a new screen will come up, with the arrow down button scroll down and highlight disc edit, press ok another screen will come up, with the arrow down button scroll down and highlight "finalize", press "ok" it is the button in the middle of the arrow keys
scroll up and highlight "yes" press "ok" the recorder will finalize the disc and it can be watched on any DVD player, just remember when you finalize a disc you cannot add anything else to the disc.
1helpful
3answers
SAMSUNG HR733 DVD RECORDER WILL NOT PLAY ANY REGION DISCS AT ALL
On page 45 of the user manual it says this:
Both the HDD & DVD RECORDER and the discs are coded
by region. These regional codes must match in order for the
disc to play. If the codes do not match, the disc will not play.
The Region Number for this HDD & DVD RECORDER is
described on the rear panel of the HDD & DVD RECORDER
If you changed the region codes on your player it will not work. They should be set back to 1 or whatever your model says on the back of the unit.
If this unit was purchased outside the United States, it may not work in the United States.
Here is a copy of the manual if you need it:
http://downloadcenter.samsung.com/content/UM/200506/20050618115856781_HR720-00758C-XAC-Eng_0519.pdf
Top Lite On Televison & Video Experts
Ngoro
ADMIN Eric
ADMIN Eric
August Brown
August Brown
Are you a Lite On Televison and Video Expert? Answer questions, earn points and help others
