Question about Dell Latitude D505 Notebook
Inspiron Laptop won't turn on
I closed my laptop last night without turning it off, and returned this morning to find it was off, and would not turn back on. Any suggestions?
  • 44 Answers
R u chk battery? wirh or without battery connected?
Posted on Aug 11, 2008
Toshiba Satellite C655-S5082. Won't power on. Worked fine last night. Today it won't turn on. Plug it it and no power light. With power cord plugged in when I push the power button the light for...
Hi.
Take out the AC power jack and then remove the laptop battery. Plug AC power back in and see if the laptop will turn on. If it turns on let it boot the operating system and then shut down as normal, remove the power cord and reinsert the battery and again see if it will switch on. If it does then there has been a glitch with the battery. If it doesn't then there is a problem with the battery.
If the laptop won't switch on either with or without the battery then there is a possibility that the motherboard has developed a problem.
Good luck.
Jul 16, 2011 | Toshiba Computers & Internet
Dell 1737 laptop won't turn on (A/C or battery powered). Last night I tried for 15-20 minutes then it worked. This morning it didn't work again (from stand by mode). I held the power button to shut down...
you have a BIOS bug when hibernation , leave without battery for few days try to turn on with the charger, and if turns on go to the battery settings and disable the hibernation option, later go to dell website and update your system BIOS.
please rate me
Aug 13, 2010 | Dell Studio 1737 Laptop
Dell inspiron 1525 won't turn on
Try to take out the battery and just use the adapter to power it on,
If your done with that then try just using the battery to turn it on, if it still won't give a single light.
If you can borrow an ac adapter for that laptop try it ,
If it still doesn't work. You'll need to replace the motherboard. Just make sure the ac adapter your gonna use is working good.
Feb 12, 2010 | Dell Inspiron 1525 Laptop
Dell Inspiron 700m won't start
It sounds like there is an issue with the system memory.
Remove both the power adapter and the battery. Turn the laptop over and locate the RAM (memory) cover and remove the holding screw.
Take out the system memory and clean the brass contacts, also clean the slots that the memory sits in.
Re-seat the memory making sure it clips into place nice and tight and replace the RAM cover.
Return power to the laptop and turn it on to see if that has helped.
If it still won't boot up then you may need to purchase new memory for the laptop.
Good luck.
Sep 28, 2009 | Dell Inspiron 700M Notebook
My compaq presario c500 doesn't respond to the start button
try to turn on the laptop without the battery and only the power cord plug in.
if your laptop works with this you need new battery or update bios ( there might be fix for battery monitor)
if not, call service support, might be motherboard issue
let me know an update
Apr 03, 2009 | HP Compaq Presario C500t Notebook
Cutting down power to my dell laptop while left for downloading
Donot worry the computer and laptop are build to work 24hr, and here the people doesnot know that putting off and on the pc always is bad , coz this with time destroy the cpu or board,putting off and on the laptop effects the heat pipes on the laptop and this leads with time to cpu damage or board damage.
Turning a Windows system "OFF" (from 'Start> Turn Off Computer...' button) is not the best way to put your system away for the night (or extended periods) and forcing a shutdown with the power button is NEVER a good option; only a last resort.
It prevents Windows from 'housekeeping' system files to get ready for the next start-up, and may, over time, cause file corruption; slow down; even break Windows.
Best Regards
Mar 02, 2009 | Dell Inspiron 1525 Laptop Jet Black (15.4"...
Dell E1505 not turning On
Sorry, I do not have experience with computers , only televisions. Please try submitting your request to one of the other techs that specialize with computers they will be able to help you out.
Jun 30, 2008 | Dell Inspiron E1505 Notebook
Try starting without the battery. If the battery has developed a short or is going bad they are notorious for causing a no start with Dell. If it still won't start, then a memory chip may have gone bad, this also will cause a no start with Dell. Dell's machines will not start with no memory, so check it with at least one memory chip in it. Then lastly, the power management chip on the motherboard. It's rare, but they do go out and without warning. This will have to be checked by a tech.
Dell Latitude D505 Notebook Logo
Alun Cox
