Dell Inspiron 530s Desktop Computer   Logo
Timmy Buggy Posted on May 02, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What is the best video card that is compatible with my Dell Inspiron 530s?
  • Timmy Buggy Aug 09, 2011
    Can this video card work with my Dell Inspiron 530s?http://www.amazon.com/VisionTek-Radeon-E...
Anonymous
Level 3:
  • Master 961 Answers
  • Posted on May 02, 2011
Anonymous
Master
Level 3:
Answers
961
Questions
Helped
273660
Points
3003
You can use any PCIe X16 card you want, the only restriction being the power supply. Most of the high end gaming cards require minimum 400w supply with 600w for crossfire. The 530 comes with a 300w supply so, if you were looking for a card with out upgrading power supply you would have to stay within the 300w supply. I personally like the ATI/AMD Radeon HD cards because you gain sound and video through card but thats just me. If you are a light to moderate gamer and want HD video for tv monitor, etc. a midrange card, probably in the price range of $80.00 would ne good for you and could be done without upgrading power supply.
Testimonial: "Thanks! :)"
  • 7 more comments
  • Anonymous May 02, 2011
    Another advantage to the Radeon HD cards with the 530 is if you wanted to upgrade your power supply, and go with a bigger card the 530 has plenty of room but will cover your other PCIe sound slot but, it won't matter because you will gain sound from your graphics card.
  • Anonymous May 03, 2011
    http://www.newegg.com/Product/Product.as...
    GeForce GT 520 1GB latest and greatest (well not Greatest, but a good upgrade.)
    Wow! That looks like a good one! :D I'll look into that one. Do you think I can play Guild Wars if I use that card?
  • Anonymous Aug 10, 2011
    This card is 2.1 x 16. Some say you can make it work but, your board is not designed to use this card. If you could get it to work, it wouldn't run to full capacity. It also requires a 400w power supply so, you would have to upgrade your power supply as well.
  • Timmy Buggy Aug 12, 2011
    oooh ok. if i downgraded the OS from vista to XP, am I still able to run the graphic cards u suggested?
  • Timmy Buggy Aug 15, 2011
    Actually, I just found out that my PSU only has 250 watts. Not 300. it's not a regular 530 model. it's a 530s (slim). :/ So what card is good for 250 watts instead of 300 watts?
What is the best SD card to use in the Dell Inspiron 15 5000 series laptop?
there is no best. unless you stated.
what it is to be used for.(application, job, what?)
1: works (sure they do) but some huge ones do not work on really old PC or camera's.
2: or speed.
3: sizes, no job stated (usage) so no guess.
what you need we have no idea at all.
if saving video files speed matters?
if saving say only email, then small slow works ok.
your usage or applications, matter what you need.
they sell these at walmart, just buy one and be happy.
buyone $5, if not work take it back get another until happly.
https://www.walmart.com/search/?cat_id=0&page=1&query=sd+memory+card&sort=price_low#searchProductResult
Would a Intel Core 2 Duo E6600 Dual-Core CPU 2.4GHz Socket LGA775 1066MHz 4MB be compatible with a Dell 530s?
you need to know what motherboard you have. If you download a free program called Belarc and install it it will give you all the information about your pc. Once you know what motherboard you have then just google it and see what cpu's are compatible.
Does the inspiron530 have a sd card slot
Media Card Reader is optional for Dell Inspirion 530s.
You can check for its availability by opening the Flexbay panel by pressing the button.
Here is a picture where you may check the position of Media Card Reader. SDCard Reader slot is usually under number 1.
What is the best video card with a 400 watt psu can i put in my dell inspiron 530s?
The best could be the most expensive one that will fit. 400 watts is plenty for all.
1helpful
2answers
Does This Graphics Card Work With My Dell Inspiron 530s Even Though My Power Supply Is Only 250 Watts? Will my computer work with this card even though the PSU is only 250 watts?...
I think you're asking for trouble. The specs at the link you gave recommend at least a 300-watt supply. By the time you figure in the normal load of everything else in the system, there probably won't be enough power from the 250-watt supply to let the card work reliably, and may affect overall system operation. One of the problems with small form-factor computers is that they often use a proprietary power supply to fit the case, and you can't replace it with anything larger. This limits expansion capability. I'd suggest saving your money.
I cannot find the sd slot for my dell inspiron 530S computer
hi
if you do not have a SDC slot (SMART MEDIA CARD) near the floppy drive area, then your model did not come with the SDC slot
see manual download , go to this link
http://support.dell.com/support/edocs/systems/insp530s/en/index.htm
Pink screen then hang on dell inspiron 530S
your motherboard has an video card? if it has an video card then try to check it maybe it is damaged or loose.. try to replace it with another vga card.. don't buy just borrow it to another pc. if u dont have any vga card check your memory or ram.. cheer
I have a Dell Inspiron 530S desktop. My card reader simply stopped working. Doesn't read any card I insert. I checked the drivers....all seem to be installed and working. Couldn't find any problems. Help!
Found another solution online that worked...tried it, and it worked for me. Checked for drivers that needed updating or reinstalling. Reinstalled the driver. Shut down computer...rebooted and it worked. Don't know if it will continue to read cards, but for now...yea!
carly
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
