Hello ive just purchased a technika television for my playstation 3 ive plugged in a hdmi cable to both the playastation and the television and i get no picture and i do not no how to tune it as it does not sya in the television manual please help
  • 36 Answers
Playstation 3 automatically defaults to 1080p resolution when you open the box, if your tv does not accept or display 1080p resolution what you want to do is plug it in using component cables and go into the playstation settings and lower it to 1080i then reconnect using HDMI and you should get a picture
Posted on Aug 11, 2008
SOURCE:
Does a 12 yr old technika 17-510 have hdmi port
It appears to have one HDMI input port.
https://www.gumtree.com/p/televisions-plasma-lcd-tvs/tv-dvd-17-technika-lcd-freeview/1289188649
It is said to require the use of the remote control to operate, so be sure that the remote control works if you are purchasing it.
TV DVD 17 Technika LCD Freeview in Chippenham Wiltshire Gumtree
Apr 10, 2018 | Televison & Video
I connected a sony playstation 3 and there is no sound while playing games. The video works and I can play the game, but there is no sound. I returned the playstation 3 thinking it was the console but the...
http://manuals.playstation.net/document/en/ps3/current/settings/audiooutput.html
Adjust the audio output on your playstation and the television depending upon how you're connecting it to the television for picture and sound.
For an hdmi cable between the television and the PS3 only then adjust the audio ouput to hdmi on the PS3.
You do not need to connect anything else between the television and the PS3 besides an hdmi cable.
If you are using the colored plug type component or composite cables then it is av.
If you are connecting with a fiber optic cable to a surround sound system then it is set to optical.
Depending on what television you are using you would also have to change the Playstation to 48khz/96khz
Jan 09, 2011 | Insignia NS-L32Q-10A 32 in. HD-Ready LCD...
Playstation 3 will not come on screen when I connect hdmi cable to tv. tv not recognizing hdmi. What do I do?
Try resetting the playstation and a hot swap. Turn off the tv and the playstation and remove the hdmi cable from the television. You should see a red standby light on the playstation. Press and hold down the power button until you hear two beeps. Now plug the hdmi cable back in. Turn the television on. Turn the playstation on. Hope this works.
Oct 08, 2010 | Sharp LC22DV24U 22 in. LCD TV/DVD Combo
How do you set up a ps3?
I would suggest you follow these procedures, hook up your PlayStation 3 to a television. You must decide whether your TV supports high definitions (HD) resolution or not. For HD resolution, you must use a HDMI cable or a component video cable. These cables also support standard definition (SD) resolution. If you only have an SD television, you can use an S-video cable or an AV cable. These two can't support HD resolution.
Connect the PlayStation 3 to any audio equipment such as a A/V receiver or home entertainment system. Connect using a digital audio cable or, alternatively, run an HDMI cable to your A/V receiver then another HDMI cable to the television set.
Plug in the Ethernet cable, then connect the other end to a 10Base T jack from your home network. This connects you to the Internet and the world of online gaming.
Attach the AC power cord to the PlayStation 3, and then plug it into a surge protected wall outlet. Don't plug in the power cord until all other connections have been made as a chance of shock exists.
Perform the initial set up of the system. Turn on the power of the TV and game console, and follow the on-screen prompts. The pre-installed software guides you through the set up process.
Take care.
Jul 18, 2010 | Sony Playstation 3 (PS3) Console
My hdmi plug in the playstation does not work i have set the playstation to hd but it dont work ive tried to cables and to diffrent tvs
Solution
Remove SCART leads, plug in HDMI from PS3 to TV HDMI 1 port.
Now......
Turn OFF TV, turn OFF PS3
Wait 15 seconds
Turn on TV
Press and Hold PS3 On switch until it has completed one recycle.
Now wait 2 secs and you should get the handshake and connection.
Jul 15, 2010 | Sony Playstation 3 (PS3) Console
I cnt get no picture from my playstation 3 ive bought a new hdmi
try to reset it hold down the power button and it will beep a couple of times repeat 3 times
Jun 06, 2010 | Sony Playstation 3 (PS3) Console
TELEVISION - PS3 AND XBOX HDMI COMPATIBILITY
You have to use the scart connector for on screen menu settings. Go to the video option and enable HDMI and/or match resolution output to your set.
You did not mention the model of the TV so here is another scenario,
Just because the TV is 1 year old doesn't mean that it is a 1080p capable, you could have set the HDMI resolution settings to 1080p and you will not get any picture if your set cannot process the information.
Jul 03, 2009 | Televison & Video
Playstation 3 HDMI No signal
You have to go into settings on your ps3 and change the output signal to hdmi
Nov 04, 2008 | Sony Playstation 3 (PS3) Console
PS3 no longer communicating with TV
All: Try this -
P
erform the following steps to reset the Video Output Settings.
  1. Make sure the HDMI cable is connected to the [HDMI OUT] port on the back of the PLAYSTATION 3 system. Connect the other end of the HDMI cable into the [HDMI Input] port of the TV or display monitor.
  2. While the PLAYSTATION 3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive On/Off button on the front of the system until the system goes into standby mode again . (So the light cycle would go from: red light to --> green light --> then back to red light) This will ensure that you have held down the On/Off button long enough to reset the Video Output Settings.
  3. Turn ON the PLAYSTATION 3 and once the system finishes powering up, the Video Output Settings will automatically reset to the standard resolution (or detect the current display output settings of your TV/monitor). [If resetting does not auto-detect your HDTV, see next step below.]
NOTE: As of system software update version 1.60, the PLAYSTATION 3can automatically detect an HDMI connection to a TV. If the PLAYSTATION 3 is turned on with an HDMI cable connected, the screen for switching video output settings will be displayed automatically. (Does not function unless the TV that is connected by the HDMI cable is turned on.)
As of version 1.80 of the system update for the PLAYSTATION 3, the PLAYSTATION 3 can upscale the video content of PlayStation® format software, PlayStation®2 format software, and DVDs to HD resolution.
If Resetting the Video Output Setting Did NOT Detect Your HDTV Automatically (Certain TV's Only)
With certain televisions, the PLAYSTATION 3 may not automatically detect the HDMI source (TV) which it is plugged into, even after resetting the Video Output Setting (as described above).
If resetting the Video Output Setting did not work, you may need to follow these steps to manually locate the HDMI source:
1. Connect both the AV Cable and the HDMI cable from the PLAYSTATION 3 to the corresponding (AV and HDMI) ports on your TV. 2. Proceed with resetting the Video Output Setting on the PLAYSTATION 3 again. (Follow these steps, then continue to step 3 below.)
3. Turn the TV channel to the corresponding "Input" or "Video" channel for the AV Cable connection.
4. Manually change the Video Output Settings to HDMI. (Follow these steps, then continue to step 5 below.)
5. Now switch the "Input" or "Video" channel on the TV for the HDMI port the PLAYSTATION 3 is currently plugged into.
6. Accept the display settings for HDMI before the timer runs out (30 seconds). Highlight "Yes" and press the X button.
7. You can now disconnect AV Cable from the PLAYSTATION 3 and the TV, as it is no longer needed.
Dec 16, 2007 | Sony Playstation 3 (PS3) Console
Televison & Video Logo
136 people viewed this question
Top Televison & Video Experts
Ekse
