Philip TV - Cable connection on back of TV broke off. How do I repair it?
  • 36 Answers
If the rf input is broken off you can usually get the rf input replaced pretty cheap from a tv repair store, if it is the component or composite inputs then you have to replace the Small signal Board which is a way more expensive fix
Posted on Aug 11, 2008
Cable connection in TV broke off
That part is soldered into the TV circuitry. Chances are that a TV repair professional will need to open it up unless you know someone that knows how to desolate and solder in a new plug. If the circuit board is damaged, then you will have to source a new part.
Oct 20, 2014 | Seiki 32" LED TV - SE321FB
Cable connection broke off bake of unit
if i was u id take to expert as i have had same problem once found cable was incased inside box very had to open so took to repair shop didnt cost alot
Nov 27, 2012 | Panasonic TH-42PX60U Television
Is the 42" philip plasma
If you really want, you can use an old CRT TV as a monitor provided you get it connected.... so your plasma... YES. If your PC has a DVI port, you could use a DVI - HDMI cable to connect. If your PC does NOT have a DVI port, you could install a video card that does... better yet, get a video card that has a HDMI port. This way, you'll only need a HDMI cable to connect the PC to the TV for audio and video.
Aug 05, 2011 | Televison & Video
Componants in back don't seem to work, HD cable,
Projection TV sets have two very common problems listed below.
Problem #1) Convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 22, 2009 | Philips 55PW9363 55" Rear Projection...
Cable connection in rear of TV broke off.
This problem will have to be taken or shipped in to a service center for repair or replacement of the cable connector on the main board. The telephone number for Insignia customer support is 1-877-467-4289. and the website is www.insignia-products.com. You can also call the Best Buy customer support telephone number. 1-888-237-8289. Give them you make and model number of television and the problem you had with the broken cable connection.They will be able to tell you how you can get service for your television. I hope this information helps you with your problem.
May 02, 2009 | Insignia IS-LCDTV32 32 in. Television
Cable connection part broke off in back
Are you talking about the part that connects the cable from the wall to the tv? I do not really understand which part on tv or vcr. It is true you can use the vcr as the tuner. You still have to connect the cable from the wall to the input cable jack on back of vcr. Then you hookup the R/W/Y rca plug- in cable from the back vcr output jacks (which are also color coded) to the tv's jacks. If you only have two jacks on the tv they will probably red and black. It doesn't really matter. Go from your video output on the vcr to the video input of tv, then use one of the audio outputs on vcr and go to the audio input on tv. It should work like that.
Jan 14, 2009 | Philips Magnavox DVD/VCR Dual Player
Cable connection in back of tv broke.
part name -tuner -u can buy from electronics spare part market
Dec 26, 2008 | GE 27GT271 TV
Broken cable tv port on Mitsubishi CS-27209
Yes but repair shop charge alot
for this , and it's easy repair .
You can buy some solder , 40 watt soldering iron , Male coax plug from Radio Shack and
resolder two connections and save 100.00
RADIO SHACK HAS THEM
IT ,
Dec 16, 2008 | Mitsubishi CS-27209 27" TV
it can be repaired.otherwise replace tuner
Nov 25, 2007 | Sanyo DS25390 TV
Televison & Video Logo
65 people viewed this question
Top Televison & Video Experts
