My cinedash media console is not working the mute and volume controls are both lit up but no response from either
  • karl_oziri Aug 22, 2008
    my cinedash media console is not working.the volume and the mute controls are light up.
I've had the same problem with mine and the solution is rather simple. Unplug the AC supply and remove the battery for 10 seconds or more. Next time you'll boot, you'll see everything works just fine. Oh, and it's possible that this problem might reappear.
Posted on Aug 23, 2008
I have an acer8930g with cinedash media console. however when using the next track button with spotify it often skips 2 or 3 tracks instead of just skipping the current track.
It sounds as if you should re-install the program. Or you may just have a sticky keyboard. or the key repeat time is very fast. Try looking in the control panel for your operating system and adjust it from there.
Apr 12, 2013 | Acer Computers & Internet
The CineDash Media Console doesn't react
Yes!
Acer has a few known issues with the CineDash technology. Please call their technical support and they will do some troubleshooting with you to determine if it a hardware issue or not. If it is, they will likely repair it free of charge as there are known issues with it.
use the force!
Jul 31, 2009 | Acer Computers & Internet
Unlock volume console
Hi, Try doing the following:
1. Turn of your laptop 2. Remove the battery and the power cable for about 15 seconds 3. Reinsert the battery and the power cable 4. Turn on your laptop.
Your Cinedash Console should be fully functional again
Good luck. Cheryl
May 28, 2009 | Acer Aspire 6920 Notebook PC
My cinedash media console touchpad has frozen on mute and high volume
Shut off your laptop. Pull the power cable/supply plug out. Remove battery. Wait 15 seconds or so, then put it all back together and boot it up. Should be fine after that.
May 11, 2009 | Computers & Internet
Cinedash touchpad
Try taking the battery out for 10 seconds, put it back in and boot as normal.
Worked for me on my Aspire 6920G! I think it must be a power-ratio problem.
Mar 29, 2009 | Acer Aspire One PC Notebook
Volume touchpad has frozen on mute
This happened to me.
Power down (shut down) and then remove battery for a few seconds.
This fixed my CineDash Media console.
Jan 17, 2009 | Computers & Internet
My cinedash media console is not working the mute and volume controls are both lit up but no response from either I have Acer aspire 6920 frist my cinedash used to work, but now it stop out of the...
Hmmm just found solution to the cine dash volume control problem.
You need to shut your laptop down. Remove the battery for 10 secs. Replace battery. Boot up and all should be okay.
I have tried this on mine and it worked fine. If this does not work straight away someone else said something about LaunchManager but I didn't have to do that so can't give any info on that.
Jan 05, 2009 | Acer Aspire 6920 Notebook PC
I have an acer aspire 6920 laptop.the cinedash media console isnt responding
Functions are activated by simply tapping
the function with your finger, while you can adjust volume by sliding your
finger around the volume meter.
CineDash reacts on commands with a little “lag”, if you use it carefully you can expect no problems, but for nonchalant usage CineDash will not react on every touch. You also have to make sure that it's turned on for it to work.
Jul 21, 2008 | Computers & Internet
Computers & Internet Logo
651 people viewed this question
David Payne
David Payne
