Question about Jensen VM9510 Car DVD Player
Hooking up the parking brake sequence
I got a Jensen VM 9311 TS-J DVD player and in the manual it just says to hook up the parking brake sequence but doesnt say how or where to hook it up do you have any ideas? I'm not trying to bypass it i just want to hook it up so it will play dvd's period i tried the bypass codes and nothing works i can get to the screen where you can turn it off but then it goes right back to the blue screen please help
  • 1,586 Answers
There are no "bypass codes". Making the unit work without the handbrake is a wiring issue, and it's easy. I highly suggest doing it this way to make the player much more useable.
DVD head units have one extra wire in their wiring harnesses, compared to a standard CD head unit. On my Jensen, it's a peach-colored wire, and is the activation wire for the DVD feature. During the installation, the instructions call for this wire to be tapped into the emergency brake indicator light wire. The reason is this:
The e-brake indicator light is what is called a "ground complete" circuit. That means that the bulb always has power applied, but when you pull the brake, that puts a ground to the wire and completes the circuit, allowing it to illuminate. The head unit sees this ground, and activates the DVD player.
In my Jensen unit, I simply ran this wire to a ground (I used a screw near the fuse box), and I put a switch on the wire, so I could break the ground contact at will. Jensen calls for a procedure to activate DVD playback. In their instructions, they tell you to select DVD from the option menu, and when the "lawyer screen" comes up (the one warning you to park before you watch a movie), you release the e-brake for 3-5 seconds, and then reapply it. To simulate that with the switch I used, I leave the switch closed (activated), and select DVD. Then I flip the switch "off" for 3-5 seconds, and flip it back "on". This tricks the head unit into thinking I put the e-brake off for a few seconds and then put it back on, and the movie will start. Then I can drive away.
Basically, ground the wire that is used for DVD activation, and put a switch inline on it. Then you can break and reapply the ground in whatever manner is required by the manufacturer of your head unit. If there is no off/on sequence with yours, as there is with mine, simply ground the wire to a screw inside the dashboard and you're done.
Posted on Aug 15, 2008
My vm9510 wont play the dvd with out saying parking and screen blue
You have to connect the park wire of the Jensen to your hand brakes that gets a negative signal everytime you engage it or you can try to put in series the park wire to a switch and any ground. Then read your manual how many times you got to switch it on and off until the picture appears when your dvd is playing. Same thing if you connect it to your parking brakes you got to engage your parking brakes on for 1 or 2 secs then back off then back on again for 1 or 2 secs keep doing this varying the secs till you get a picture. That will be the sequence to turn off that blue screen and on the dvd to watch the movie. Read your manual very carefully it will tell you the same thing but you definitely have to hook up the brake wire or else you will never see the picture. Check the manual for the color of the brake wire or just find the longest wire on the harness and thats usually the brake wire.
Apr 07, 2010 | Jensen VM9510 Car DVD Player
My jensen in dash dvd player keep asking for parking brake sequence
there's a wire from the dvd player that is supposed to be hooked up to your parking brake switch to keep you from viewing during driving. i have a pioneer unit and i ran the parking brake wire to a switch and ran another wire from the switch to ground. then when it asks for the parking brake sequence, (with my unit) i flip the switch from off to on then off then back on. this makes the dvd player think that you've applied, let go of, then applied the parking brake.
Feb 16, 2010 | Car Audio & Video
How to disable the parking brake sensor on lx470
simply hook it to a togle switch. Hook one end of the switch to ground, hook the other end to the jensen, then you can flip the switch off and on to make the jesen think you are using the parking brake
Aug 16, 2009 | Jensen VM9510 Car DVD Player
When i turn my jensen 9311 on i get no picture but it plays sound and the touchscreen works just no picture what is my problem
do you have the installation manual,if you have it you are mising to conect a pink wire which is the parking brake wire,follow the sequence step to get the me i can help you remind me about your problem,
Mar 08, 2009 | Jensen VM9511TS AM/FM/CD/DVD/SD Player/7"...
VM 9212
I don't think you can. I have a Jensen multimedia head unit as well (VS 9311 or VM 931) and it isn't capable of playing two different features at the same time.
Jul 21, 2008 | Jensen AM/FM/MP3/DVD/CD iPod-Ready...
Jensen VM 9311 iPod Classic
You might need the jenson media module,that might have came with it.Mine did and I bought it 2nd hand.and a special ipod cable that hooks from the media module to your ipod.
Mar 16, 2008 | Audiovox VM9311TS
Trying to find the parking brake
Jan 15, 2008 | Jensen VM9510 Car DVD Player
is it the solid yellow wire if so that is the memory wire and it should be hooked up. if you are talking about the parking brake wire you either need to hook it up the the parking brake spring or bypass it
Nov 21, 2007 | Jensen VM9510 Car DVD Player
Jensen VM9510 Car DVD Player Logo
230 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
