Question about Toys
I need a replacement part for funrock giggles entertainment centre
I need a replacement octopus part for the fnrock giggles entertainment centre, urgently
    Scholar:
  • 125 Answers
Best bet is to call GRACO Customer service and see if they have that part for sale as they sometimes carry replacement parts on some products. I have ordered parts for another GRACO entertainment center before when my daughter's fave broke! Here's the number: 1-800-345-4109 P.S. If they do not carry it, the only thing you can do is check ebay as someone might be selling it on there (You really can find ANYTHING on there!) And if not, ask the Graco associate if this model is one that uses the interchangable toys, so at least you can have another toy in it's place if you can't get the exact one! :)
Posted on Sep 02, 2008
For a 10ft radius octagon, how long should each side be?
There is probably a formula for this or other ways of doing this, but I will give it a shot.
An octagon has 8 sides (octopus has 8 legs). To make an octagon, we effectively have 8 triangles joined at the centre. In the centre, we have 8 equal angles. Since a full circle is 360 degrees, each of these angles must be 360 / 8 or 45 degrees.
Now we can just focus on one of these triangles. We have an angle of 45 degrees at the centre and two arms extending out 10 feet.
At this point, we can use the cosine law to calculate the length of the side or we can recognize that it is an isosceles triangle and work out the other angles and determine the length of the side.
Using Cosine Law, a^2= b^2 + c^2 - 2xbxc Cos A
In this case, A = 45 degrees, b = 10 feet, c=10 feet.
Good luck.
Let me know if you have any questions.
Paul
Aug 25, 2015 | Miscellaneous
My octopus leaks from the head (not the hose). Could it be an internal problem?
A rebuild or simple adjustment can make it stop leaking if it is coming out of mouth piece if it is leaking from anywhere but mouthpiece or hose connection it needs service.
Mar 26, 2012 | Oceanic Swivel Octopus, Scuba Diving...
Who services Dacor Viper scuba regulators
Depends really where you are in the world, but most reputable scuba service centres should be able to help you.
Aug 26, 2010 | Dacor Viper Tec Scuba Regulator
Genesis "S.K.O." Octopus GS060 The above product is constantly leaking, not much but pretty much all the time, it does help depending how I position it but that should not really be the answer, It has been...
Hello, there are a few things that may have happened. Often octos pick up sand and grit when they get dragged on the bottom. Try a good vigorous shake in fresh water. After that your moving into badly seated diaphram, split diaphram or slight hole, badly adjusted spring etc etc etc. Would recommend that perhaps you get it serviced. Especially important if you have been using Nitrox. Hope that helps
Jul 17, 2010 | Genesis Scuba Regulator Octopus S.K.O....
Bubbles leaking from my back up mouth piece on my zeagle ranger bc
Sounds like it needs a service. Any Scuba centre or shop that services scuba equipment will be able to sort this for you. Hope this helps
Jun 06, 2010 | Zeagle Ranger Ltd Bcd
Repair manual for HP Pavilion dv6 1245 dx
Go to hp.com. Click on support and drivers tab. Select "See Support & Troubleshooting Information." Enter your laptop model number. dv6-1245dx. Click on "GO". See: "What Type Of Support Do You Need?" Choose MANUALS. Scroll down the page and select "HP PAVILION DV6 ENTERTAINMENT PC - MAINTENANCE AND SERVICE GUIDE". Download that PDF format. It is relatively easy to get to the ribbon cable that connects the touchpad to the motherboard. It is connected via a ZIF connector. I had a dv1331se and the touchpad stopped working. I just reseated the cable in the connector and all was well. Hope your solution is as easy as mine was. You'll have to remove the trimplate just in front of the keyboard. Be careful with the connectors there. The manual is well laid out and the diagrams easy to follow. Good luck. HP Pavilion dv6 Entertainment PC - Maintenance and Service Guide
Mar 16, 2010 | HP Pavilion dv6000z Notebook
How do I make the connections with the main valve, I am buying a new octopus not yet assembled,
If I understand your question properly, all you need to do is remove one low pressure plug from the first stage regulator, then screw the hose end in from the new octopus.
Feb 04, 2010 | Aeris A1 Octo
How to use safe second with a Scubapro full face mask
Yu only need the octopus adapter kit to put on an octo and you can swap out should your primary reg **** out.
Feb 18, 2009 | Scubapro Full Face Mask, All
Scuba Tank Setup Question
Ideally, you should have someone who is certified in regulator servicing to do this for you. Otherwise, you may be endangering your life.
Dec 01, 2008 | Aeris A1 Octo
What side does the octopus go on? left or right?
The reason to have it on the right is because that is "standard". I dive with a long hose (7') and an octo around my neck on a 22" hose. So long as you explain it to anybody you dive with and talk about your plan for air sharing in advance, it shouldn't be an issue.
Toys Logo
324 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Toy Expert? Answer questions, earn points and help others
