Question about Brother MFC-8860DN All-In-One Laser Printer
Fuser replacement on Brother MFC 8860DN
Saw your post about fuser replacement on Brother MFC 8860DN. How much did it cost and did you do it yourself>
Thanks
  • Anonymous Mar 13, 2014
    fuser brother mfc-9340
Yes I did it myself, however I am savvy with most hardware, I wouldnt suggest it for the novice. It cost around $NZ245 for the fusing unit, which from doing a quick search online is about the same in most countries.
Posted on Sep 03, 2008
I replaced the fuser. How do I reset the fuser?
Replace Fuser Message and Reset Brother MFC 8480DN ...
? 0:46
www.youtube.com/watch?v=quGzXnDsZQA
Jun 27, 2012 - Uploaded by Kevin Gumpp Instructions on how to reset and replace the fuser on a BrotherMFC 8480 ... V?deo Recarga Toner Brother TN 580 ' MFC 8860DN ' DCP 8060 ...
Oct 01, 2015 | Brother Printer MFC L8850CDW Wireless...
What is the code SC546 mean?
search error code . Brother MFC-8860DN Printer
Jul 10, 2014 | Brother MFC-8860DN Printer
My brother MFC 8860DN printer has an error showing: Rplace fuser. Does it have a fuser and where can I get it?
Open it up from the back of the machine. Try reseating the fuser first. If that does not help, then you need to replace it. Probably the ceramic fuser element is going bad? It is either not heating up fast enough or heating up too fast. If you can print test sheets, and the text is too shiny, it would be a fuser that is too hot. If you can rub the text off the test sheet, it is not fusing fast enough and there is not enough heat.
Try ebay for a fuser. They are fairly simple to replace.
Oct 13, 2010 | Brother MFC-8860DN Printer
How to remove fuser from a brothers MFC 8860DN and reset the counter
WRONG! Press 2 and 8 at the same time to reset the counter.
Apr 20, 2010 | Brother MFC-8860DN Printer
Brother mfc 9880 fax/copier makes grinding noise and has paper jams
Probably a broken Hot Roller gear in the fuser. The fuser is the section in the back, that presses the print between a pair of hot rollers to melt the powdered toner into the paper, making the image permanent. That combination of heat and pressure makes the fuser vulnerable to breakage in any laser printer or copier. The HR (hot roller) gear is a ring around one end of the heated roller, and it sometimes breaks apart.
The MFC 9880 isn't listed on Brother's US service website, so I can't tell you whether you need to buy a whole fuser assembly or just that gear.
Mar 31, 2010 | Brother MFC-8860DN All-In-One Laser...
Getting black line down center of page
A vertical line down the page is almost always related to the fuser. Unfortunately, with the Brother printers at $200-$300 a fuser the cost of repairing a fuser often exceeds the cost of the printer itself after you consider the time and effort that will go into installing it.
But I linked you a site that says it has the kit for $179, I don't know if that is a refurbished one or what, the price seems really low to me. But it might almost make it worth trying to replace.
Mar 11, 2010 | Brother MFC-8860DN All-In-One Laser...
How reset fuse Brother MFC-8860DN Printer
fuser counter reset
press MENU - START - 088
LCD shows "PARTS REPLACEMENT"
go down with arrow till reset fuser?
press "SET"
done
Nov 21, 2009 | Brother MFC-8860DN Printer
Problem for Brother MFC-8860DN Printer How do i reset fuser count after replacement
press menu 7 3 2. this will bring you into the parts reset, and reset the fuser
Follow this procedure:
Enter maintenance menu by pressing:
Menu,*,2,8,6,4
8,8 for parts life
scroll down to fuser
hit start for yes
9,9 to exit
Oct 23, 2009 | Brother MFC-8860DN Printer
How to change the fuser gear in Brother MFC 8660DN Printer
I recently changed the fuser gear on my MFC-8840DN (a similar machine) and type up detailed information. The pdf file of the instructions has been posted at:
http://www.sharperminds.net/downloads/instructions_for_changing_a_fuser_gear_on_a_brother_printer.pdf
Hope you find this helpful.
Ed
Sep 07, 2009 | Brother MFC-8860DN Printer
Brother MFC-8860DN All-In-One Laser Printer Logo
2,250 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
