Question about Sony FD Trinitron WEGA KV-32FQ70 32" TV
Sony FD Trinitron WEGA Tv KV32FQ86E two flashing led
Power on button pressed, relais is switching 2 times. Red LED is flashing 2 times, 3 seconds off, then again and againg until the TV's going well, sometime we have to wait for about an hour or more.
  • 1 more comment
  • Harrisbg Feb 01, 2009
    When turn on from the power button on Tv KV-32FQ86E, it only flashes RED LIGHT but does not turn on. I then have to keep pressing the power button on the remote for an hour or more, suddenly it comes on.
  • Anonymous Feb 03, 2009
    don't know how to hookup coverter box to tv
  • carlos_psa May 23, 2009
    I have a FD Trinitron WEGA KV32FQ86E Sony TV and when I turn on, the sound appear but no video signal, a power supply's relay cut some voltage and the standby led blink twice (Over current protection). These state on and off repeats until I have video signal and the TV works fine. When I turn on the TV, the process is repeat again and againg.
    Do you solved your trouble ?
Check 470 uF 450 V in the power supply. I don't know if the chassis is the AE-5, but I had a similar case and the capacitor was bad.
Please tell me if it worked.
e-mail: jlopes.electronica@sapo.pt
Posted on Jan 22, 2009
I have a tv Sony Trinitron XBR. It does not turn on; the LED red light blinks 7 times.
Common problem on those. It has deflection stopped. I.C. on deflection board. Need shop to repair.
Nov 23, 2014 | Sony FD Trinitron WEGA KV-34XBR800 34" TV
I have " Sony FD Trinitron WEGA KV-36HS420 36" TV
U have a soldering iron,desoldering pump or a roll of desoldering braids,a roll of solders?Can u do basic soldering and uderstand basic electronic?FBT- the flyback transformer,the big black block of a plastic with a red wire with a cap hook to a CRT-tv picture tube.Near the big block of a plastic with a red wire with a cap hook to a CRT picture tube.Inside to the right of the FBT,there are 2 power supply ICS,those 2 ICS are dead.Replaced these 2 power supply ICS near the FBT,will solved this tv LED power light indication blinking and will have stable tv power again,and tv will work.
Nov 29, 2010 | Sony FD Trinitron WEGA KV-36HS420 36" TV
Sony FD TRinitron WEGA, KV-32FS320... NO PICTURE/NO SOUND ...The red light flashes on the front of the TV. I have unplugged the power cord, and have allowed time to pass before re-plugging. Once I...
Just went thru the same problem with my sony kv-34. There are two IC's on the D circut board located on the left side looking from the rear. If you can solder 18 pin IC's without making a mess it is possible.If you have a friend thats real good with a pencil tip solder device. I recomend putting sockets in where the IC's were as you won't have to worry about overheating stuff next to the IC's.Do a google search: Sony led flashes ad select the second hit in the list.
Good luck
Rich
Jun 06, 2010 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Sony FD Trinitron WEGA Tv - LAMP blinking 11 times
Sony tv has self protection program. The red Led blinking light indicate the probable cause location. For this model it is either 2,4 or 5 flashes every 3 second. Please check the blinking again
Feb 09, 2010 | Sony FD Trinitron WEGA KV-27FS120 27" TV
Sony Wega KV-XF21M83 21" Color TV red LED flashing two times
mt sony trinitron power light is blinking from green to red twise and then pause for 3 seconds and then blinks again from green to red
Jul 05, 2009 | Sony FD Trinitron WEGA KV-32FQ70 32" TV
I have a 36" TV that won't work - Red LED light blinks 5 times
The 5 blinks indicates a White Balance Failure. This involves checking voltages and components tied directly to the CRT. I would not suggest any attempt for self repair. The cost for this repair should not be significant. Figure a parts cost in the $30-$50 range at worst.
Dan
Mar 06, 2009 | Sony FD Trinitron WEGA KV-36HS500 36" TV
The high voltage power supply is going bad on both units.. Pretty soon, it won't power up at all. For a fact.
Don't try to replace the power supplies, TV's are too cheap.
Feb 01, 2009 | Home Security
Picture tube not working
Please provide more info.
1. Does the TV stay on, if so,
2. Is the LED flashing, how many times stop same number of times again
3. If TV goes to stanby, count the flashing LED.
4. If LED comes on goes off , at firsdt switch on. does it make a thumping noise.
Jan 23, 2009 | Sony FD Trinitron WEGA KV-21CL10 21" TV
Sony FD Trinitron WEGA KV-30XBR910 30" TV Led flashing
6 blinks meens no horizontal and no raster check capasitor c515/c516/ jungle IC and IC206.
regards,
daniel.
Dec 28, 2008 | Sony FD Trinitron WEGA KV-30XBR910 30" TV
Kv-32s120 standby LED blinking no sound or picture
How many times does the timer light flash between pauses?
Sep 05, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony FD Trinitron WEGA KV-32FQ70 32" TV Logo
1,016 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
