Question about Brother Office Equipment & Supplies
MFC-5860CN Print Unable 50 - Brother Office Equipment & Supplies
  • lethalr1 May 05, 2009
    I loaded more paper into the printer and it said unable to print error 50
    Problem Solver:
  • 11 Answers
I had this same problem and it is an easy fix.
Lift the lid on your printer and at the back you can see the opening where the print head is.
With the power off, use your finger to move the print head into the middle.
Now feel under the lip of the cover at the front of the gap and you will find a plastic strip that runs from one side to the other. This is the encoding strip and it what the print head uses to read where it is. This encoding strip is easily pushed out of position when a paper jam occurs and all you need to do is to get it back into position. Using both hands use a finger on either side of the print head and lif the encoding strip upwards slightly and towards the back of the printer. This will locate it back into the correct position in the print head when you release. Power back on and the problems will be gone!
Posted on Dec 23, 2010
I have a network printer--Brother MFC-5860CN. When I want to print an album cover on iTunes I get an error message saying there is a problem and Windows 7 needs to close iTunes. If there is a soluti
can you download the cover you want to your computer first then print it? http://www.freecovers.net/ try here you can usually get all the covers you want for free
Sep 23, 2014 | Brother Office Equipment & Supplies
Print unable 30 error
The print unable is an error caused by build up of dust on the encoder strip. Unfortunately there is no easy way to reach the encoder strip to clean it without taking the machine apart and putting the machine back together after you take it apart is not easy.
Paying to repair the unit is a little over priced and not usually worth it. On the bright side, Brother's new line up of ink jet machines allows easy access to the encoder strip to clean it without hassle.
Thanks,
Pat
May 11, 2010 | Brother MFC-5860CN InkJet Printer
Brother MFC-5860CN printing issues after switch Win2k to WinXP
Are the settings in the print driver set to the highest quality setting? If so, this will slow the print speed down tremendously. Try changing the default settings in the print driver to a lower quality (or resolution) setting.
Dec 20, 2009 | Brother MFC-5860CN InkJet Printer
No imprime y el mensaje en la pantalla LCD es Printer unable 50
This is error in purge unit.You can't fix it by yourself and your printer need service.
Nov 25, 2009 | Brother MFC-5860CN InkJet Printer
Message unable to print 50
Machine Error 50 either means that there is a loose object inside the machine (usually piece of paper), or that there is a mechanical error which would need you to have the machine sent to service.
Jun 02, 2009 | Brother MFC 240C All-In-One InkJet Printer
Brother MFC-5860CN print unable 51 error message
Normal 0 Could have a corrupt driver.
Disconnect the printer or at least be sure it is turned off. I'd do both and when the CD software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Dec 31, 2008 | Brother Multi-Function Center MFC-240C...
"Unable to Print 50" BROTHER MFC-440CN
my brother mfc-440cn printer says, "unable to print 51" on the screeen after if off (which it woudn't let me do. I had to unplug it. It just won't work.
Aug 26, 2008 | Brother MultiFunction Center MFC-440CN...
Product info
yes. It can fax and copy in b/w or color without pc.
Apr 08, 2008 | Brother MFC-5840CN All-In-One InkJet...
720 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
