Question about HP LaserJet 4250tn Printer
Grinding noise Hi, We have a 4250tn realitivly new. It starting making a terrible grinding noise any suggestions on how to resolve this issue? Much Thanks
  • 300 Answers
This is caused by the swing arm (the part that drives the fuser) HP have modifed this, if you contact them, they may replace it free of charge. A short term solution is to wedge a piece of card or folded paper under the fuser assembly.
Posted on Aug 11, 2008
After installing new front rotors and pads on a 07 Mercury Milan there is a bad grinding noise
Hi Julie, Check the back plates behind the discs. Some times after working on the brakes the back plates are bent and cause the sound you're reporting. The ABS rotors, if correct should not come into contact with the sensors. Are the brakes efficient when applied? If not make sure they have been installed the correct way around. I have known mechanics to fit them with the metal part of the pad rubbing onto the disc! Anything is possible. Regards John
Jun 24, 2012 | Cars & Trucks
Our volvo 850 makes an terrible loud grinding noise coming from front passenger side. Cannot pinpoint when the noise is made as it seems to happen at any time but is more persistent after turning full lock...
Hi! The problem will be the constant velocity joint on the driver's side. When its worn it makes a noise on turns specially when putting it back to straight direction. Have it replaced and you'll be good. HOpe this helps and have a good one!
May 20, 2010 | 1995 Volvo 960
Car pulls right, terrible grinding noise from front right.
TAKE IT BACK WHERE THEY DONE THE LAST LOT OF WORK and tell them to do the complete job again as it sounds like a con job to me as a wheel aligment should last for a year a least and the grinding is in the braking system and something must still be bent ,
Its still under warranty dont pay any more..
Oct 26, 2009 | 1993 Buick Regal
Grinding/Low Whining noise when turning
sounds like the power sterring pump check valve is failing because it only when you turn, try to turn the wheels standing still to verify the noise, if noise present, replace the ps pump.
Jul 09, 2009 | 2004 Chevrolet Silverado
Loud Noise
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
879dgyj
Dec 18, 2008 | LG DLE5932W Electric Dryer
Terrible noise when agitating
Your transmission has gone out. The reason the spin cycle works is because the transmission spins two different ways and you agitate way stripped the gear. Some places rebuild them. Try with your local stores maybe they can rebuild it or get you a good used one. If not you can order a new one from sears.com
Nov 12, 2008 | Kenmore 24032\24036 Top Load Washer
TV grinding noise
A grinding noise in that model usaully means the light engine is defective or it could be the color wheel. But light engine is most suspect as there have been some issues with the light engine assemblies
May 11, 2008 | Televison & Video
Grinding Noise
If it's metallic sound you are loosing teeth on a gear or two.  This is caused by lack of lubricant or simply fatigue of the material of the gears.  Don't use it, you can get metal flakes in your food.
Take it in to a repair shop and have it fixed.  The money spent is well worth it because if done correctly will last another 12 years.
Oct 21, 2007 | KitchenAid KSM90 Ultra Power Series Stand...
HP LaserJet 4250tn Printer Logo
213 people viewed this question
Ben Johnson
