Question about Panasonic Audio Players & Recorders
I have 2 Technics SA-GX390 stereo receivers, both go into overload when power is applied. Without a schematic or at least a block diagram it is impossible to troubleshoot. Does anyone know where i can get a schematic. These units are about7 years old. Ian Ladd E Mail, pearl1pearl2@rogers.com
    Genius:
  • Panasonic Master
  • 1,550 Answers
When go to overload always be the audio amplifiers IC damaged disconect the ic and then turn on the device it this stay replace the ICs.Good luck
Posted on Aug 11, 2008
Technics sa-dx1050 overload
if any one of the channels was shorted out, even momentarily, that channel's output transistors would likely be blown causing it to stay in protection mode. (or overload as you put it). Time to visit the repair shop.
Jul 23, 2012 | Technics SA-DX1050 Receiver
On switching my technics sa-dx750 it says switching off overload
The question is what is causing the overload? The power supply or the output devices on the heat sink?
If you have accidently shorted a speaker wire, then the answer will be output devices, otherwise it could be anything in the power section. You may find a burnt or damged device with either of the causes.
Mar 08, 2010 | Technics SA-DX750 Receiver
My Technics AV Control Receiver SA AX530 is in overload
An amplifier should never be turn on without speakers, it will overload internally.
make sure speakers work and try again.
Dec 04, 2009 | Technics SA-AX530 Receiver
Need wiring diagram I need a schematic for a Technics SA-EX140.
I became a member at http://www.free-service-manuals.com/ and downloaded the schematic I needed.
Jun 01, 2009 | Technics SA-EX140 Receiver
Overload at medium (4-6) volumes. Can you adjust or disable the overload protection on these Technics amps??
try this mate:
http://www.electronicspoint.com/googlesearch.php?cx=002919058480771089906%3A03mranmmdze&cof=FORID%3A10&ie=UTF-8&q=Technics+SA-GX550&sa=Search#862
May 23, 2009 | Technics SA-EX400 Receiver
Overload technics SA-GX390
It sounds like you have a wiring issue. Try looking for a bad wire or crossed wires between the positive and negitive jacks on the back of the unit.
Nov 06, 2008 | Audio Players & Recorders
Technics SA DA20
I have a Technics SA DA20 control receiver. I was given it by an electronics workshop and it has this same error of OVERLOAD coming into the display when switched on. I removed the plates from underneath and re-soldered as far as I could all the points along the stereo amplifier ICs and as far as access would allow. The unit then worked normally for several hours. I was very pleased, and went out shopping!. But on my return after it had been off for about an hour, the same problem has come back. But my boss at the electornics workshop thinks it it just a dry joint, or series of dry joints. The unit is complex to dismantle, so patience and care is required in taking it apart and making a note or diagram of how it comes to pieces and how to re-assemble it after the board has been re-soldered. It does not appear to be a component problem or fault with the SVI power amplifier ICs.
petertaussig33@hotmail.com
Feb 23, 2008 | Technics SA-DA10 Receiver
1,195 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
