Question about LG LFX25960ST Stainless Steel French Door Refrigerator
Ice door flapper does not open
I've got an LFX25960ST that makes ice just fine, however when you press the cup in to dispense it, the ice maker makes the noises to dispense the ice, however the little door that allows the ice to drop does not open.
Any one know how to fix this, or which parts are required to perform the repair?
  • 1 more comment
  • heidi_okc Apr 02, 2009
    I have the same problem. The flapper does not open. We looked at the solenoid and there was black stuff coming out the side of the solenoid body and the solenoid was burnt up. Why would it do that?
  • Bill Ostrander
    Bill Ostrander Apr 24, 2009
    Ice dispenser flapper does not open. I pried loose the front panel frame but can not remove it to see behind it because the ice shoot projects down into the front panel rear wall. HOW DO i GET BEYOND THIS POINT TO INSPECT THE SELINOID?
    PS I found that closing down on the water supply valve, restricting the water flow to the refridgerator solved my ice maker problem. But now the darn flapper won't open and let it out.
  • Bill Ostrander
    Bill Ostrander May 11, 2010
    I pried loose the front panel frame but can not remove it to see behind it because the ice shoot projects down into the front panel rear wall.HOW DO i GET BEYOND THIS POINT TO INSPECT THE SELENOID?
  • 489 Answers
It is possible that the solenoid wire connections may have come loose.  You will have to pop off the front cover of the display panel to gain access to the solenoid.  To remove the panel, look below the bottom of the panel to find 2 screwdriver holes.  Slide a screwdriver in one of them and gently pry open the panel.
Posted on Sep 30, 2008
After some research on this web site I found out that the ice shoot can be removed by pulling straight down. It snaps off. I then removed the display panel and the rectangular panel behind it to find the burned out selenoid that is suppose to open the discharge flapper. I removed the solenoid and placed two small pieces of Styrofoam packing sponge on the flapper movement to keep it closed until ice compresses it when dropped from the ice maker. This is not a perminate modification, but it should be OK until I can find a new solenoid and flapper mechanism.
Posted on Apr 25, 2009
  • GenoK1 Sep 02, 2010
    I have the same problem with my LG LFX25971ST I do not know how to get these panels off and check the Selenoid for the flapper. The ice maker is working fine the flapper will not open to dispense ice. Been using my fingers to hold open flapper and get my ice. Any help on how to check the flapper selenoid or where to get a Selenoid if I find it is bad would be greatly appreciated.
  • liammx5 Dec 29, 2010
    I just replaced the cooling motor in my 4 yr old lg side by side my ice maker quit before the first year
    i think i'm going to put a fishing hook thru the flap and a little string and a mini bobber to pull the ice door down
Trouble shooting LG french door ice dispenser
LG French Door Refrigerator - In Door Ice Maker Troubleshoot
? 4:41
https://www.youtube.com/watch?v=rA1DhfTwuwM
Feb 4, 2013 - Uploaded by ExperienceLG
Ice makers are great, but not if it means you can't fit all of your food in the fridge. The Slim SpacePlus Ice ...
LG fridge ice maker troubleshoot/ repair. How to fix ice ...
? 8:06
https://www.youtube.com/watch?v=arJpFgMnvPY
May 19, 2013 - Uploaded by spartacus1234567890
The ice maker quit working in my LG refrigerator so I decided to take it apart ... LG French Door Refrigerator - In Door Ice Maker Troubleshoot ...
LG Refrigerator Ice Maker Not Working - Model LFX25960ST
www.repairclinic.com/RepairHelp/...Fix...-/LG-Refrigerator-ice-maker-n...
LG Refrigerator Ice Maker Not Working. LFX25960ST. The part(s) or condition(s) listed below for the symptom Refrigerator ice maker not working are ordered ...
Jan 05, 2016 | LG LMX28988ST Refrigeration : Refrigerator...
Tip
ICAPP-4 - A Wiki Manual
Cuisinart ICAPP-4 – Iced Cappucino and Hot Espresso Maker – A Wiki Manual
By Tha Mp3 Doctor (who also loves Cuisinart)
Since I am not well-versed in the copyright laws regarding reprinting copies of standard user’s manuals online, I am writing this Wiki Manual for the ICAPP-4. My unit is 12 years old (in 2009) and continues to run strong through two different owners.
General Directions for Making Iced Cappuccinos
- Place carafe on top of drip/tray grate with handle touching right front of ICAPP – the ice fill lines should be visible when looking at front of unit
- Turn “milk knob” to OPEN position, and open lid of ICAPP
- Remove milk container, espresso collector, espresso spinner cup and cover
- Put espresso collector back in place with two plastic teeth facing front of machine
- There is a stepped fill line inside water reservoir that measures off 1,2, and 4 cups
- Fill water reservoir with either 1,2 or 4 fill line cups – do not overfill to avoid damaging the electronics
- Add espresso grounds to espresso spinner cup
- Line up teeth of spinner cup cover with spinner cup so that the cover locks into place
- Fill milk reservoir with 3 oz of milk per cup of iced cappuccino that you plan to make – there is a fill line that measures off 2 cups or 4 cups
- Fill carafe with either 2 cups worth of ice or 4 cups, depending on how much iced cappuccino you plan to make
- Press down on lid and turn milk knob to HEAT postion
- Turn ICAPP on using the ON/OFF button – it will begin to heat – takes about 5-6 minutes (HEAT light will stay on during this process – doesn’t make noise or steam for several minutes)
- When READY light turns green, turn the milk knob to the DISPENSE MILK position – your espresso and milk will start dispensing
- Unit turns itself off automatically when ready – takes several minutes
on Feb 25, 2009 | Cuisinart ICAPP-4
Water and ice dispenser does not work---the switch clicks when you press it but there is not response, also the ice maker just quit working
Three things could be wrong:
Solenoid switch where the water comes into the unit has gone, this control the flow of water into both the ice maker and the water dispenser.
If the switch is good and then you need to check your filters, sometimes inside the door top right. or on one of the corners on the bottom front.. You should be able to unscrew them with you hands.. make sure water is off behind unit or where ever your shut off is at.
One last thing.. check for kinks in the water line behind the unit if it was pulled out lately.
Aug 10, 2015 | LG LFX25960ST Stainless Steel French Door...
How do I remove ice dispenser from samsung rfg297aars
here ya go.
https://www.ifixit.com/Guide/Samsung+French+Door+FRG297HDRS-XAA+Ice-Water+Dispenser+Microswitch+Replacement/66568
Grab the black dispenser port with a strong hand and hold the door from opening with another, or your shoulder. Firmly pull the assembly away from the door. It will take a quick, firm pull to do the deed. The assembly is held in place by several plastic lock tabs. These will give way without breaking.
pushing the fridge back will be easier than pulling it around.
Best of luck and hope this helps you.
Jan 18, 2018 | Samsung Refrigerators
I have a LG 3-door french refrigerator that will not dispense the ice. It makes the ice just fine and it dispenses the water just fine. PLEASE HELP!
the most be a chunk of ice stuck since this refrigerator cool way much it freezes the water in the dispenser area i have cleared wit a bit of hot water and emtying the ice bucket
Oct 05, 2009 | LG LFX25960ST Stainless Steel French Door...
No water, no ice-LG LFD21860ST
Sound like a water supply problem, as both get water from the same source. Both valves are connected to the water line that supplies water to the frig, in the back, bottom, behind the cardboard cover. Make sure the water valve is on for that line. The noises indicate thew valves are probably working, but are not getting any water.
Sep 19, 2009 | LG LFX25960ST Stainless Steel French Door...
Ice Maker stopped making Water Whirlpool model (ed5phexnq00)
Pour about 1/2 cup of water into ice maker . If it dumps , replace the water valve . If doesn't dump , replace the ice maker . Also make sure the coils are clean of dust , lint , etc...
Aug 15, 2009 | Refrigerators
No ice
IPour about 1/2 cup of water into ice maker . If it dumps , replace the water valve . If doesn't dump , replace the ice maker . Also make sure the coils are clean of dust , lint , etc...
Aug 12, 2009 | LG LFX25960ST Stainless Steel French Door...
LG LFX25960ST Stainless Steel French Door Refrigerator Logo
789 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
