Question about IBM ThinkPad T60 Notebook
T60 will not boot up
Error message:
ERROR
2100: HDDO (Hard Disk drive) initialization error (3) I dont know where to start?? I did go into the BIOS...that was a big mistake since I have no idea what im doing. Please help.
  • Anonymous Oct 08, 2008
    using win xp sp2
  • IBM Master
  • 13,433 Answers
Seems the harddrive has failed, and needs to be replaced.
Posted on Aug 11, 2008
How do I correct Error 2100:HDDO Hard disk drive initialization error 1
I would remove the corrupt drive and connect via USB to another computer running Win7. See if the computer sees the drive. If it does, put it back in the laptop and try booting again. If not, go to Control Panel, disc management and create a drive letter. Doesn't matter what it is. It should then boot OK. If not, replace the drive.
Aug 01, 2015 | Lenovo ThinkPad Computers & Internet
Thinkpad T60 hard disk drive error, cannot boot from any device
First - re-seat the hard disk and reboot the computer. If the computer does not boot up then reboot and go into the BIOS configuration to see if the BIOS detects the hard drive. If it doesn't detect the hard drive then it could be faulty.
Then the hard drive needs to be replaced in the computer/laptop, Windows installed and the computer or laptop's device drivers plus your programs etc. to get a functioning computer/laptop again.
Feb 21, 2013 | IBM ThinkPad T60 Notebook
Acer aspire will not start. get message check cable connection! PXE-E63 error while initializing the NIC PXE-M0f Exiting Intel PXE ROM No bootable device - insert boot disk and press any key. Netbook has...
1. It seems that the hard drive is not bieng detected by the computer 2. and from the error message that you are getting it seemed like windows is not loading up 3. I would suggest that you take out the hard drive and put it back in 4. the reason for that is the hard drive that connects from the mainboard is
May 29, 2011 | Computers & Internet
Wen i start my laptop it says no bootable device please insert a boot disk and press any key. it also says to check cable connection and error while initializing the NIC so i want to know where the hard...
Hello - The message is telling you that it can't find your hard drive, which is your boot disk.
You didn't give any info about what laptop you have so I can't tell you what more to do except to find out how to boot into your system BIOS and see if the system sees any hard drive at all. If not it's most likely your hard drive has died, but there can be less dramatic reasons for the error.
So look in your manual and find out how to get into the system BIOS or come back here and give more info about your laptop (make and model and operating system) and someone will take your further along in troubleshooting the problem.
Regards,
Mikeywaf
Apr 16, 2011 | Computers & Internet
Error Code: 1000-0146; MSG: Unit 0:DST Log contains previous erro
Code 0146 is hard drive read/write failure.
Replace the hard disk drive
Jan 27, 2010 | Dell Inspiron 6000 Notebook
PXE-E61 Media Test Failure Check Cable on compaq presario 2100
A PXE-61 error message is most likely a faulty hard disk.
Try reseating the hard drive first and if you still get this error message again then you need to replace the hard disk.
To boot up with the CD you maybe able to press the F12 function key when you power up the laptop, this will bring up the a menu option to select an alternate boot device. If this option is not available then go into the BIOS configuration and change the bootup order and make the CD as the first boot device and the hard disk as the second device. You can can it back later.
Sep 14, 2009 | Compaq Armada E500 Notebook
2100: HDD0 initialization error (2)
same prob on my IBM LENOVO T60
did anyone found the solution?
please contact me
i need to recover my DATA
my pc can't start no more
Aug 11, 2008 | Computers & Internet
There appears to be a BIOS update or two available for the Lenovo TP T60. One of the updates makes reference to this error code, but the verbage afterwards is a little different to that posted here. Mind you, my recommendation is that you should stay on target with BIOS updates because they are fixing problems with the computer, even if you don't realise you are having those problems!
Please go here: http://www-307.ibm.com/pc/support/site.wss/MIGR-64462.html
Press Ctrl F and search for 2100. This tells you which update fixed a problem with ERROR 2100: At the bottom of this page you will find that these updates are for all regions. You will also find the link to the BIOS update utility.
My experience of BIOS updates on the Thinkpad range is that you have to undock the laptop prior installing the BIOS update, and ensure the laptop has a constant power support - NOT BATTERY. Ensure you read the on-screen notes carefully.
Hope this helps.
Jan 14, 2008 | Lenovo Thinkpad T60 Notebook
IBM ThinkPad T60 Notebook Logo
466 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
