Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Whirpool washer top load washer will go thru the wash cycle, but will not drain, rinse or spin should i look at the switch, pump, belt ????
  • checkittc Oct 21, 2008
    Washer goes thru the wash cycle and stops. I have installed a new circuit board in it. After putting in the new board it went into the drain and spin cycle when I did a manual start on it.
  • 639 Answers
Dear friend,
ngfam at you service!
You can not fix this problem your self!!!
This sounds like it will only fixed by service then you will be happy again!!
Yes sounds like you need service!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
PS. PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF!
Posted on Aug 26, 2008
I have a top load washer model LSR 8433 KQ0 the machine will not spin but agitates, rinses, drains fine but when it clicks to the spin cycle it just pumps out any water and does not spin. Would this b
Either the belt broke or the hood switch is not working. Sometimes it could be the contacts in the main control knob but if everything else is working correctly, then check the belt, and the hood switch first.
Jan 11, 2015 | Washing Machines
Hi I have a 5 cycle 2 speed top load whirpool washer and it all of a sudden will not go to the Spin Cycle and drain out the water. It stops in the rinse cycle. I need help!
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Jun 25, 2011 | Washing Machines
Washers fine but doesnt drain water and go to rinse cycle
Check the drain hose may be kinked. Washers have been known to eat socks, they go in to the the tub during the spin cycle and down in the pump. If you are so inclined to look dome pumps are clear and you can see the sock. There is a hose clamp to remove and you may be able to remove the sock. Reassemble and test. Remember as always to unplug the washer first before doing any work. This exploded view has a washer and if you hover over the bottom right it will show what the pump looks like.
http://www.repairclinic.com/Washing-Machine-Top-Load-Maytag-Style-Appliance-Diagram Good luck
Aug 21, 2009 | Kenmore 22422 Top Load Washer
Will drain but wont spin
Try these
  1. Test the lid switch
  2. Test the timer control
  3. Test the centrifugal switch
  4. Test the water level switch
  5. Inspect the motor coupler
  6. Inspect the drive belt (belt drive only)
  7. Inspect under the washer for soot (clutch)
  8. Test the motor
  9. Inspect the pulley
  10. Test the transmission
pls rate my suggestion......
Jul 23, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
GE Washer does not drain or spin
Inspect the drain hose for kinks
Test the lid switch (some models)
Inspect the water pump
Jul 15, 2009 | GE WDSR2080D Top Load Washer
Won't spin after wash cycle or rinse cycle
CHECK THE FOLLOWING---
1. Clogged drain line or water pump
Check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine).
2. Water Pump
If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Note: if you have a belt driven washer, check the belt(s) for cracks, as this would be a perfect time to replace the belt(s) if needed.
May 31, 2009 | Frigidaire ATF6000ES Front Load Washer
Washer won't spin clothes dry enough
Dear Langley,
please do the following checks.
This may be a spin problem or a drain problem
Drain:
  • Make sure the drain line is clear
  • Check the drain hose for a partial blockage
  • Inspect the water pump
Spin:
  • Test the lid switch
  • Test the timer control
  • Test the centrifugal switch
  • Test the water level switch
  • Inspect the motor coupler
  • Inspect the drive belt (belt drive only)
  • Inspect under the washer for soot (clutch)
  • Test the motor
  • Inspect the pulley
  • Test the transmission
please rate this solution.Thank You Langley
Dec 16, 2008 | Kenmore 15944 Top Load Washer
Rinse water fills the washing machine when the spin cycle starts
Check your outlet filter, most likely it is blocked, preventing the water from draining out. Chk your pump too. Before this disconnect from the wall socket; and also check the pipe coming from the tub to the filter. Siphon out the excess water from inside the machine before you open the pipes.
May 17, 2007 | Frigidaire FGX831C Top Load Stacked Washer...
Rinse cycle spinning... clothes still soaked
It sounds like your washer is not going through it's neutral drain. After agitation, your washer should pause and drain for around 90 seconds to pump out the water before spin. Check this out by starting a wash with a small screw driver holding the lid switch down. This will allow you to observe whether or not it's going through it's neutral drain. If not, it's a transmission problem. The trans is covered under warranty for 5 years. You may also want to check the pump to see if it's gunked up. Catriver..post back.
Dec 04, 2006 | Kenmore 24982 Top Load Washer
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
37 people viewed this question
Dan Webster
Dan Webster
Sal De
