Question about Dishwashers
Zanussi Dishwasher Model no DE6744 Not working
When door is shut main indicator light comes on to show power is there.
When program is chosen the light for the selected program comes on but also the spray light together with the drying light are flashing but nothing happens
HI. After me fiddling about with the machine,checkingto make sure water was available to it and trying to locate the float switch (whicu i didnt) .
Then i left it standing overnight aqnd the believe it or not it worked in the morning.
I let it run through the cycles of a program which it did ok.
Hoping it carries on ok. Kenethyorky
Posted on Aug 12, 2008
I have a SHU5305us/u12 and my front door lettering got erase. anyone have a picture or a manual that tells me what each button means.
Cycle Interruption
As a safety feature the dishwasher will automatically turn itself off whenever the door is opened. However, if the door is opened quickly while in a wash or rinse cycle some water may splash out of the dishwasher. For this reason it is recommended that the machine always be switched off before opening the door.
To Interrupt a Cycle
1. Press the on/off button to stop operation.
2. Wait at least 10 seconds (or until the water noises stop) before opening the door.
To Resume a Cycle
1. SHU/SHI models, close the door and press the on/off button.
2. SHV models, push the on/off button and close the door.
Changing a Cycle
For Bosch dishwasher models SHI 6800 and 4320, SHU 5300, 5310 and 6800 press the program button of the desired cycle TWICE. For all other Bosch dishwasher models, press the program button of the desired cycle ONCE. The chosen cycle button (or the light above it) becomes illuminated, showing that it has been selected.
* SHU 3030 and SHU 3130 models do not have program lights.
Cancelling a Cycle
Each control panel shows which buttons to simultaneously push to cancel a cycle. Refer to your dishwasher to find the cancel drain buttons on your particular model.
1. Press the indicated buttons at the same time and hold for approximately 3 seconds.
2. When the drain pump noises stop and the LED display or clean light indicate that the end of the cycle has been reached, the dish
washer is reset.
3. Press the on/off button to turn the dishwasher off.
4. The dishwasher is now ready to run a selected cycle. Add more detergent if necessary.
Dado
Oct 05, 2015 | Bosch Dishwashers
Amana dishwaser adb1100aww won't start is there a fuse in dishwasher
If you are able to set the wash program on the panel but the start does not produce any action, then the door latch is causing a problem. There is a switch behind the latch that detects if door is shut. If this switch is not closing then dishwasher will not start.
Check items 4, 6 and 9 in this diagram. Make sure the mains power is disconnected as high voltages come to the door panel.
http://www.searspartsdirect.com/partsdirect/part-model/Amana-Parts/Dishwasher-Parts/Model-ADB1100AWW0/1268/0130000/W1302287/00002?blt=06&prst=&shdMod=
Apr 19, 2014 | Dishwashers
My Zanussi dishwasher DE6744 leaks clean water during the wash cycle. The water appears to be coming from the plastic tank overflow holes, left hand side as you look from the front. Any ideas?
I have the same machine and I took mine outside and turned it on its side and removed the clean water feed and all the screws holding the white plastics off and then un-clipped them off and I saw that there was a blue tube that was leaking on mine, I cut the end off and reattached it with a new clip and hey prestow all working now with no leaks.
Dec 29, 2009 | Zanussi 24 in. DE6744 Free-Standing...
Zanussi Aquapulse DE6854 dishwahser programe lights not working
hi
got same probleme with my aquapulse 4744 slimline
Oct 07, 2009 | Electrolux Dishwashers
Zanussi ZSF 6161 Dishwasher error codes
i have got an zanussi des 959 and showing falt code 5 could u help me out
Jan 19, 2008 | Dishwashers
Dishwasher zanussi aquapulse
this sounds lie a door interlock, in most models this is a micro switch where the handle is inside the top of the door casing, i would start there, based on the info that you have given
Sep 19, 2007 | Zanussi 24 in. DE6965 Built-in Dishwasher
Won't work
I hant not seen this unit but what it sounds like to me is the control bord that controls the functions on the washer may be bad. you should try and find if there is a tech sheet somewhere in the cabinet or under the dishwasher. that will help you to also see if there may be a fuse or thermal fuse that may be bad. good luck
Aug 05, 2007 | Zanussi 24 in. DE6744 Free-Standing...
Humming noise
humming is the motor powered up but not turning. burning smell is the motor overheating. cause may be the motor capacitor which is a cheap part. try replecing it and hope thge motor survived. could also be a foreign object in the pump impellor
Mar 13, 2007 | Zanussi 24 in. DE6744 Free-Standing...
Still too long for a cycle
how long does cycle take? if program actually finishes there is unlikely to be a problem. factors which can affect cycle times are inlet water temp and rate water is entering the machine
Aug 15, 2006 | Zanussi 24 in. DE6744 Free-Standing...
Dishwashers Logo
171 people viewed this question
Top Dishwashers Experts
