My system is brand new, however, I have been unable to use it. First my monitor had to be replaced, now my keyboard is defective. I can't use the last two rows on the keyboard. The information will not input. Also, I can't open the cpu(dvd drive)Where is the open button?
    Problem Solver:
  • 35 Answers
To start with get it changed. if its new u should have warranty. The dvd there should be a button somewhere close to the tray. But make sure that you have A DVD.
Posted on Aug 11, 2008
Toshiba L675 left shift key has converted into an enter key. How can I change it back?
Buy a brand new keyboard and replace your keyboard. Please notice that you may get a defective keyboard, so please buy it from a trusted seller.
Feb 17, 2014 | Microsoft Computers & Internet
Aging message appear on samsung syncmaster 910mp
This message is generated when the backlighting tubes have aged so much they no longer are capable of operating normally - it's not a defect, your monitor has just worked too much.
You could replace the tubes, but new ones will cost you more than a new monitor. So either get them from a defective monitor sold for parts or just get a brand new monitor.
May 04, 2011 | Televison & Video
My Keyboard is brand new. We have replaced batteries, and pushed the reset button for 30 seconds, the indicator does not register new batteries or any batteries at all. Reset was synchronized with reset...
Possible reasons for no power to keyboard...
Batteries in wrong direction. Check orientation of each battery.
New batteries are actually bad. (replace)
Positive terminal is obstructed by packing strip (remove packing strip from batt compartment)
Positive nipple is too short and cannot reach terminal. (try a different brand battery)
New Keyboard is defective. (return to store for exchange)
Mar 08, 2011 | Computers & Internet
Typing multiple lettters
If it really is "brand-new", it could be defective.
Get it replaced.
May 07, 2010 | Dell 0Y3740 Keyboard
Unable to log onto computer keyboard double spacing and double ch
Try a different keyboard, if a different keyboard works properly then your original one is defective. If another keybaord does the same thing then its a setting in the operating system for the keyboard that needs to be changed.
May 01, 2010 | Dell Wireless Keyboard Optical Mouse w0147
I the keyboard lights up and will do all functions
You may want to remove the keyboard and reboot your unit without the keyboard connected.
After the unit restarts, plug in the k/b and allow your operating system to reload it required drivers.
Also, if you have the original driver installation disk, it would be helpful to load your k/b from the install disk.
Nov 24, 2009 | Dynex Multimedia Keyboard
The color on my monitor is not working. I purchased a brand new monitor it still does not work
Try fiddling with the settings on your monitor and see if it changes anything. Or maybe you got a defective monitor, I suggest bring it back whereever you purchased it and have them take a look at it so they can replace it right away if its defective.
Dec 18, 2008 | Computers & Internet
Trubleshoot Motherboard
More than 70% of all computer problems are related to cabling and connections. Ensure all cables are connected and connected firmly. IDE and floppy ribbon cables and power cables can often go loose. Ensure microprocessor, memory modules, and adapters such as video card are inserted correctly and didn't "pop-up" due to vibration.
System has no power at all. Power light does not illuminate, fan inside the power supply does not turn on, and indicator light on keyboard does not turn on. PROBABLE CAUSE DIAGNOSIS SOLUTION
Power cable is unplugged. Visually inspect power cable. Make sure power cable is securely plugged in.
Defective power cable. Visual inspection, try another cable. Replace cable.
Power supply failure. Power cable and wall socket are OK, but system is still dead. Contact technical support
Faulty wall outlet;circuit breaker or fuse blown. Plug device into socket know to work and test. Use different socket, repair outlet, reset circuit breaker or replace fuse.
System inoperative. Keyboard lights are on, power indicator lights are lit, and hard drive is spinning. PROBABLE CAUSE DIAGNOSIS SOLUTION
Expansion card is partially dislodged from expansion slot on the motherboard. Turn off computer. Take cover off system unit.
Check all expansion cards to ensure they are securely seated in slots. Using even pressure on both ends of the expansion card, press down firmly on expansion card.
Defective floppy disk drive or tape drive. Turn system off.
Disconnect the cables from one of the floppy drives. Turn on the system, check to see if the keyboard operates normally. Repeat until you have located defective unit. Contact Technical Support.
Defective expansion card. Turn computer off.
Remove an expansion card. Make sure expansion card is secure in expansion socket.
System does not boot from hard disk drive, can be booted from floppy disk drive. PROBABLE CAUSE DIAGNOSIS SOLUTION
Connector between hard drive and system board unplugged. When attempting to run the FDISK utility described in the HARD DISK section of the manual you get a message, INVALID DRIVE SPECIFICATION. Check cable running form disk to disk controller on the board. Make sure both ends are securely plugged in; check the drive type in the Standard CMOS Setup (in your motherboard manual).
Damaged Hard Disk or Disk Controller. Format hard disk; if unable to do so, the hard disk may be defective. Contact Technical Support.
Hard Disk directory or FAT is scrambled. Run the FDISK program, format the hard drive(See HARD DRIVE section of manual). Copy your backup data back onto hard drive. Backing up the hard drive is extremely important. All Hard Disks are capable of breaking down at any time.
System only boots from Floppy Disk. Hard Disk can be read and applications can be used, but booting from Hard Disk is impossible. PROBABLE CAUSE DIAGNOSIS SOLUTION
Hard Disk boot program has been destroyed. A number of causes could be behind this. Back up data and applications files.
Reformat the Hard Drive as described in the Hard Drive section of the manual. Re-install applications and data using backup disks.
Error message reading "SECTOR NOT FOUND" or other error messages indication certain data is not allowed to be retrieved. PROBABLE CAUSE DIAGNOSIS SOLUTION
A number of causes could be behind this. Use a file by file backup instead of an image backup to backup the Hard Disk. Back up any salvageable data. Then do a low level format, partition, and high level format of the hard drive( see Hard Disk section of your manual for instructions). Re-install all saved data when completed.
Disk formatted on IBM PS/2 will not operate with this system. PROBABLE CAUSE DIAGNOSIS SOLUTION
The IBM PS/2 uses a different format than other computers. IBM PS/2 disk format will not work in an AT type computer. Format disk in the AT type computer insert disk into the IBM PS/2 and copy the files you wish.
After install an expansion card (network card, tape drive card, etc.) the system no longer works properly. PROBABLE CAUSE DIAGNOSIS SOLUTION
No power to monitor. All or part of the system may be inoperable. The new card may work but a mouse or COM port may not work. Change the interrupt or RAM address on the new expansion card. See the documentation that came with the new card in order to change pin settings. many expansion devices come with proprietary software that will assist you in doing this.
Screen message says "Invalid Configuration" or "CMOS Failure." PROBABLE CAUSE DIAGNOSIS SOLUTION
Incorrect information entered into the configuration (setup) program. Check the configuration program. Replace any incorrect information. Review system's equipment. Make sure correct information is in setup.
Screen is blank. PROBABLE CAUSE DIAGNOSIS SOLUTION
No power to monitor. Power connectors may be loose or not plugged in. Check the power connectors to monitor and to system. Make sure monitor is connected to display card, change I/O address on network card if applicable.
Monitor not connected to computer. See instructions above.
Network card I/O address conflict. See instructions above.
Problem PROBABLE CAUSE DIAGNOSIS SOLUTION
Memory problem, display card jumpers not set correctly. Reboot computer. Re-install memory, make sure that all memory modules are installed in correct sockets. Check jumper and switch settings on display card. See display card section for information of settings.
Computer virus. Use anti-virus programs (McAfee/PC-cillin, E-port, etc) to detect and clean viruses.
Screen goes blank periodically. PROBABLE CAUSE DIAGNOSIS SOLUTION
Screen saver is enabled. Disable screen saver.
Keyboard failure. PROBABLE CAUSE DIAGNOSIS SOLUTION
Keyboard is disconnected. Reconnect keyboard. Check keys again, if no improvement, replace keyboard.
No color on screen. PROBABLE CAUSE DIAGNOSIS SOLUTION
Faulty Monitor. If possible, connect monitor to another system. If no color, replace monitor.
CMOS incorrectly set up. Call technical support.
Floppy drive lights stays on. PROBABLE CAUSE DIAGNOSIS SOLUTION
Floppy Drive cable not connected correctly. Reconnect floppy cable making sure PIN1 on the Floppy Drive corresponds with PIN1 on floppy cable connector.
Error reading drive A: PROBABLE CAUSE DIAGNOSIS SOLUTION
Bad floppy disk. Try new floppy disk.
Floppy disk not formatted Format floppy disk(type ENTER)
C: drive failure. PROBABLE CAUSE DIAGNOSIS SOLUTION
SETUP program does not have correct information. Boot from drive A: using DOS system disk. Input correct information to SETUP program.
Hard Drive cable not connected properly. Check Hard drive cable.
Cannot boot system after installing second hard drive. PROBABLE CAUSE DIAGNOSIS SOLUTION
Master/Slave jumpers not set correctly. Set master /Slave jumpers correctly.
Hard Drives not compatible / different manufacturers. Run SETUP program and select correct drive types. Call drive manufactures for compatibility with other drives.
Missing operating system on hard drive. PROBABLE CAUSE DIAGNOSIS SOLUTION
CMOS setup has been changed. Run setup and select correct drive type.
Certain keys do not function. PROBABLE CAUSE DIAGNOSIS SOLUTION
Keys jammed or defective. Replace keyboard.
Keyboard is locked, no keys function. PROBABLE CAUSE DIAGNOSIS SOLUTION
Keyboard is locked. Unlock keyboard
If a problem persists, please search for a solution or post a question in our tech support forum in our Help Desk.
Oct 19, 2008 | Computers & Internet
Dell 5100 laptop
if you can hear the one beep sound when booting that means your laptop's system is in good condition. try putting it in the external monitor if still you cant see anything both in external and the LCD just install the old keyboard and press the Fn then external monitor... hope this helps...
Jan 20, 2008 | Acer Aspire 3610 Notebook
Monitor defect - Menu will not disappeard...
Your probelm si made by menu keyboard (one or more of the micro switches is defective) so you have to change them or cable that interconects keyboard and main board is damaged.
Good luck.
Sep 21, 2007 | Samsung SyncMaster 173V 17" Flat Panel LCD...
Computers & Internet Logo
26 people viewed this question
David Payne
David Payne
