Question about HP PhotoSmart 7550 InkJet Printer
HP Photosmart 7550--"double vision"
I have the above printer that I bought specifically for printing pictures. When I print, I get a "double vision" effect. Typed words end up with an echo-like effect, faces are not clear at all. It's like one image prints slightly to the side on another. It's not too bad in the middle of the image, but get progressively worse as you approach the left and right sides of the image. I suspect that the cartridges are not alliged correctly, but I've alligned and realigned the blasted things. Help!
  • Janet Cassady Aug 11, 2008
    Guru: This printer is not a fax, so I there is no # or 6 to press while plugging in the power cord.
    techexpert12: Last week, I did try printing a test page directly from the printer (not from the computer) and all tested fine. However, I could not find a problem with the computer settings. I have a HP "workhorse" printer that I use for most of my printing, and the picture printed fine on it--just not on the HP Photosmart 7550.
    So--I tried this just now:
    Went to: Control Panel/Printers/Photojet 7550/Printer/Printing preferences/services/"calibrate the device". After calibration, I printed out a picture on the HP 7550 and the picture looks much better. I can actually read the type! So, I fixed the "double vision" problem. But I found another. Under "services", I can also "Calibrate Color". Sounds like a good idea, right? When I hit this, I get a message saying that both the tricolor cartridge AND the photo cartridge must be installed to do the calibration. But I have both of these cartridges installed!! Ugh! I cleaned both cartridges and reinstalled. The printer still does not recognize the installation of both colored cartridges.
    Master:
  • 521 Answers
Try giving the selt test copy from the printer only not from the computer.if its proper than the picture setting must be not proper in your pc. and if the test page does not come properly and shows the same problem remove the cartridges and clean it with moist tissue and fit it properlyas it was.
Posted on Aug 11, 2008
  • 659 Answers
On the printer’s control panel press the MENU button.
2 Press the DOWN arrow to highlight
Print a diagnostic page, then press the
OK button.
A diagnostic page prints with
information regarding your printer and
print cartridge ink levels.
  • Wesley Gardner
    Wesley Gardner Aug 11, 2008
    The print cartridges
    may not be
    properly
    calibrated.
    Windows PC
    • Go to the Device Services tab of the HP
    Photosmart Toolbox and click
    Calibrate the Printer.
  • HP Master
  • 13,433 Answers
There are known issues if you are not using geniue hp cartridges.
Can you try the printer in another computer to see if its a issue with your computer or a internal printer issue?
  • Ekse Aug 11, 2008
    your printer is not a all in one, but you can try if this works
    A semi-full reset will do the following:
    The user settings to the
    factory defaults, Language and country settings on some models, Fax
    logs, Fax headers, Fax speed dial information.
    Reset the All-in-One to the factory default settings by using these instructions:
    1. Unplug the power cable from printer when the printer is powered on and wait for 20 seconds.
    2. Then, press and hold # and 6 while plugging in the power cord.
    Continue holding until it displays Semi Full Reset message in the front panel of the All-in-One.
HP Photosmart 2575 All-In-One, "memory card error", can not scan, only print. Please help!!
Hello, please try the "HP image zone" software that you can install form the CD included in the printers box, in order to scan. About the memory card, have you plugged a memory card to the printer?
Jul 29, 2009 | HP PhotoSmart 7550 InkJet Printer
What does the print spooler service is not running mean?
Things You'll Need:
  • PC computer running Windows XP or Vista
  • Logged in with the administrator account
  1. Go into the Start Menu and click on the "Control Panel" icon.
  2. Double-click on the "Administrative Tools" icon in the pop-up window.
  3. Double-click on the "Services" shortcut icon, which will open a full list of all available computer services
  4. Use the scroll bar on the right side of the window to find the "Print Spooler" options.
  5. Click on "Start the Service" to turn on the printer spooler and allow printing to begin again. Regards
May 02, 2009 | HP PhotoSmart 7550 InkJet Printer
Hp photosmart 7550 says carriage is stuck
print cartrigeis cradle is stuck clear jam then press ok in hp photosmart 7550.
Apr 04, 2009 | HP PhotoSmart 7550 InkJet Printer
HP Photosmart 7550 - Full Page Photo Printing Jams at end
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this, is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 17, 2009 | HP PhotoSmart 7550 InkJet Printer
WONT PRINT CALIBRATION PAGE
Take out the cartridges and turn off the printer. Turn it back on, and THEN put the ink cartridges in. After that, try to print the calibration page.
If this does not work, clean your printer using the cleaning maintenance from your HP printer software
Jan 06, 2009 | HP PhotoSmart 7550 InkJet Printer
Picture crops strange
HP Photosmart 7550 printers
  1. Ensure that the memory card has been removed from the memory card slot.
  2. Make sure plain white paper is loaded into the In Tray.
  3. On the control panel, press the Menu button. Using the directional arrows, select Clean Cartridges .
  4. Press the OK button.
  5. After confirming that paper is loaded into the paper tray, press the OK button.
  6. Once the level one clean cartridge test page has printed, examine the printed page. If the print is not clear and/or there are lines in the color bars, continue to Step 7. If the print quality is acceptable and there are no flaws with the color bar, select No using the directional arrows, then press OK .
  7. Press OK to print the second level clean cartridge page.
  8. Once the second level clean cartridges test page has printed, examine the printed page. If the print is not clear and/or there are line in the color bars, continue to Step 9. If the print quality is acceptable and there are no flaws with the color bar, select No using the directional arrows, then press OK .
  9. Press OK to print the third level clean cartridge page.
Dec 08, 2008 | HP PhotoSmart 7550 InkJet Printer
HP 7550 PhotoSmart Printer prints photos with an unpleasant green hue.
If it's a B&W or sepia photo, and you wanted to print B&W or grayscale anyway, pull the color cartridge (assuming a 2 cartridge system). I did that with my HP DJ 5440 and it works perfectly.
May 14, 2008 | HP PhotoSmart 7550 InkJet Printer
There are some print head cleaning modes you may want to try.
In your menus , look around for those and run the print head calibrations and cleaning procedures.
Also with the printer unplugged. Dampen an cloth with some rubbing alcohol and remove the print cartridges, lightly clean all the contacts with that damp cloth.
They may just have some ink on the contacts giving you a false failure message.
Hope this helps you out. They can be fickle.
Dec 14, 2007 | HP PhotoSmart 7550 InkJet Printer
Cartridge cradle is stuck
I have had this problem with my 7550 for a while now and I finally found this on the HP website and it seems to have fixed my problem, I also replaced all of the cartridges:
Issue While printing from an HP Photosmart printer, the printer screen displays Print cartridge cradle is stuck / clear jam and then press OK . The printer may also make grinding sounds. This can occur after a paper jam when another printer part blocks the cradle. Solution Follow these instructions to adjust the clutch on the printer.
  1. Disconnect the USB cable.
  2. Press the printer power button to turn off the printer.
  3. Disconnect the power cord from the back of the printer.
  4. Open the top cover of the printer.
  5. Remove the print cartridges from the printer.
  6. Slide the cradle to the right side of the printer.
  7. Locate the clutch on the left side of the printer.
    NOTE: The clutch is a flat, white, plastic component that rests just above the white roller gear wheel. In the HP Photosmart P1000 and P1100 printers, the clutch is black metal. Figure 1: Printer clutch c00020494.jpg
  8. Remove the rear access door from the back of the printer.
  9. Press the clutch firmly towards the back of the printer, while rolling the wheels in the back of the printer upward two full rotations.
  10. Release the clutch and roll the wheels up two more rotations.
  11. Reinstall the rear access door.
  12. Reinstall the print cartridges and secure the latches in place.
  13. Close the top cover and reconnect the power cord.
  14. Turn on the printer.
  15. Print a test page.
Nov 27, 2007 | HP PhotoSmart 7550 InkJet Printer
HP PhotoSmart 7550 InkJet Printer Logo
172 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
