-   The dishwasher will not fill, but the light is on but you hear no motors until 5 minutes later, or until I cut the dishwasher off then the motor hums. -   goodvsmith
Jan 23, 2009
-   Dishwasher starts, but doesn't fill with water and intermittent alarm noise comes on, F7 is indicated. -   MargWG
Jan 23, 2009
-   light is on, engine runs but water is not coming in
-   vladab
Jan 12, 2009
-   turn the machine on it makes all the right noises but there doesn't seem to be any water going into the machine. the hose that fills it is ok and water is coming through it . i just dont know where its going once its supposed to come out of the wash bars as they seem to remain dry please help
Try checking the drain pan underneath (normally behind front bottom cover) There is a float switch inside which stops operation if you have a water leak.
Hi I use a wqp8-9239as dishwasher and I have a problem. the wash light is blinking and the process...
(More)
Hi I use a wqp8-9239as dishwasher and I have a problem. the wash light is blinking and the process to finish the program is stoped. Im not able to reset the program. What can I do. Thanks
E1 Fault on Kenwood kdw12st3a? Help please: I have a brand new Kenwood KDW12ST3A, we emigrated to...
(More)
E1 Fault on Kenwood kdw12st3a? Help please: I have a brand new Kenwood KDW12ST3A, we emigrated to Australia and took it with us. We have never used the unit but when we arrived and plumbed it in it shows E1 fault. I have tested water inlet pressure and its ok. The unit fills and empties three times then faults. The wash pump never starts during this cycle. Any help would be greatly apprieciated thanks
