Noisy fan - Computers & Internet
  • smorison Aug 11, 2008
    This is a Gateway laptop model W340ui
  • Anonymous Jan 14, 2009
    fan will run fast at startup only way to slow is to restart i have all up to date drivers and the fan and all parts are cleen
  • 13,433 Answers
Clean the computer from dust, use canned air to blow the dust out, as the airflow increases the fan wont have to run so loud.
if the fan is really loud, it needs to be replaced.
Posted on Aug 11, 2008
How to fix a noisy evaporator fan in a frost free refrigerator
The ice usually makes a fan noisy by filling the cavity it needs to move the blades in. check if this is the case, if there is no obstruction and the fan motor itself is noisy it needs to be replaced or serviced, servicing parts is trickier to find than the little motor it self.
To clear the ice just let the fridge stand for a few hours and to help the process speed up you can spray the evaporator with luke warm water.
Feb 26, 2015 | Frigidaire Refrigerators
Noisy fan and no heat
Kitchen aid is made by Whirlpool. There is a very good chance the then thermal fuse on the back of the oven has tripped. Whirlpools are very prone to this fuse tripping after a clean cycle. The noisy fan is just that a noisy fan it will probably need replacing. I have replace a couple of them over the years. When you pull the oven out to replace the thermal fuse replace the fan motor at the same tiome.
May 06, 2014 | KitchenAid KEBC207 Electric Double Oven
Noisy fan on n6010 life book
fujtsu lifebook's tend to have a noisy fan
Dec 20, 2011 | Fujitsu LifeBook N6010 Notebook
How do I fix a noisy fan for a 2008 Altima.
You will probably have to replace a noisy fan. Trying to fix a noisy fan will can tricky.
Jan 26, 2011 | Nissan Altima Cars & Trucks
Creda Cordialle fan assisted oven is so noisy what can I do?
If it is the fan that is noisy, check for loose fan or the fan blades catching the cover, if all o/k, then it will probably be a worn fan bearing, only solution would be to replace the fan motor.
Nov 07, 2010 | Hotpoint Ovens
Noisy evaporator fan
A noisy fan is caused by several things. The fan can have the blade touching something behind the shroud (the back wall in front of the fan). It could be the bearings on the fan are no good - try oiling with Triflow oil. The fan blade could be out of balance. Try cleaning any dirt or grime off the blade. Fans are cheap (relatively). Tried a new one?
Some fans are just noisy. Try thin rubber between the fan and the screws that mount it (bicycle tire patches work good for this).
Mar 28, 2010 | Kenmore Refrigerators
Fan has become noisy. Does the fan need to be cleaned? Can I take it apart to vacuum the inside?
if the fan is noisy it can be two dirt or grit affecting the propeller or the baring on the motor shaft
Aug 23, 2009 | Honeywell Dryers
Noisy fan in Smeg oven SA398X
Does the fan sound like a squeling or rumbling?Is the fan blade itself scraping on something?
Apr 18, 2009 | GE JGRP17 Gas Single Oven
Noisy fan
I believe your laptop needs to be serviced. if you see dust and fluff, it might damage the fan and would need replacement
Mar 05, 2009 | Acer Aspire 4315-2963 Notebook
Computers & Internet Logo
373 people viewed this question
David Payne
David Payne
