Question about Whirlpool Washing Machines
I want an appointmont whit a technicien for my waghing machine
I am trying to install Printmaster Platinum 10 on a PC with Windows XP wihout any success. In the compatibility mode there is no option for Windows XP.
That program it's not compatible whit windows xp but you can try to install it on a machine whit windows xp whit thi istructions :
  1. mouse r-click on the installer
  2. select properties
  3. select compatibilites
  4. choose either Windows 98 mode or Windows 2000 mode
  5. click ok
  6. start the installation
if the installation process works fine follow this steps
  1. find the program directory under "C:\program files" or under "C:\"
  2. find the program executable (must be .exe )
  3. right click whit the mouse on the executable
  4. select properties
  5. select compatibility
  6. choose either Windows 98 mode or Windows 2000 mode
Aug 24, 2011 | Computers & Internet
Le master ne cop pas
tout d'abord vous devez indiquer le model de votre machine; Riso ou richo ou gestetner: si vous avez une erreur qui s'affiche sur le panneau de votre machine indiquer le; mais generalement si le master ne se coupe pas vous dever rmettre a zero la position du detecteur du master depuis le mode technique. si vous n'etes pas specialiste, laisser un un technicien vous faire ca. merci d'avoir choisir Fixya.
Dec 23, 2010 | Office Equipment & Supplies
Icemaker not getting water to it
check if the water is on, solenoid may be stuck or burned, may have jumped a thread(wire), the control of ice machine not activatinging the solenoid. if you have (and know to work whit it) a meter check if you have 220V (or 110V if you are in USA) or put a bulb whit soket instead the selenoid and turn on the icemaker, if the bulb wil light you must change the selenoid. or more simple, call a repair man, is more wise for a man who didn't know to work whit energy.
Feb 21, 2010 | Kenmore Refrigerators
On the imprimante screen there is written: Error
Remove all inks..clear all contacts whit wet cloth or alcohol then put inks back. if this is not helpful for you try also to change inks whit new
Jan 06, 2010 | Lexmark F4270 Plain Paper Inkjet Fax
Arr?t de la laveuse amana
Code 2E demande l'assistance d'un technicien. Remplacement du module de contrôle électronique. Problème réglé par le vendeur. Excellent service.
Jul 26, 2008 | Washing Machines
Moniteur ACER AL1917 Après une utilisation d'une heure le texte devient illisible. Pourquoi ?
c'est un condensateur au niveau du transiteur central de puissance qui est en faute,
1 option. (recherche le schematics du moniteur) et replace le condensateur qui controle le transiteur de puissance. OU
2 option (le mieux) faire le examiner/reparer par un technicien electronique.
Esperant t'avoir aider, merci
Jun 07, 2008 | Acer Computers & Internet
GE Front loader
My washer has the same issue. I am also looking for a manual.
SK
Mar 28, 2008 | GE Energy Star WCVH6260F Front Load Washer
Message Box problem
1st formate u r mobile
Sep 06, 2007 | Nokia 7610
Washing Machines Logo
16 people viewed this question
Dan Webster
Dan Webster
Sal De
