Question about Western Digital Caviar SE 120 GB Hard Drive
External 120GB passport read failure
When i plug in the hard drive, it [powers up but my computer doesn't recognize it all the time. When it does, i cannot read the data off of it and when i go to properties, it says that i have 0 bytes free and 0 bytes used. I cannot defrag it or format it b/c it says that i cannot do these tasks to this item. What other suggestions do you have. Thank you for your time.
I have the same problem - I did get to access the files one time, but not now.
I haven't tried all of these, but did try a couple (that was how I was able to access the data temporarily) - try a different USB slot in your computer, try a different USB cable, and/or try a plugging it into a different computer.
I think I have all of my info backed up, but not absolutely sure.
Good luck
Posted on Aug 11, 2008
My toshiba external hard drive wont work in 360, the portable device option is not highlighted once it is connected, the external is getting powered from the xbox though.
When you first put in your External hard drive to your computer, did it ask you if you wanted to use as a sort of passport or did it not give you any options at all like Usb flash drive. you should not have any special program on for the External hard drive. It should just be set up to store data and nothing else. I had a similar dilemma with a WD passport. When i put it on my 360 it did not work. then i just made the drive like a plain storage device and the xbox could read and play my files.
Dec 29, 2010 | Microsoft Xbox 360 Hard Drive (120GB)
I have a WD USB External HDD (160 GB), when I connect to my USB port it detects the drive but not displaying in My Computer. Hope there is no issue with USB port. Then why the drive is not detecting,...
Your unit is detecting the electronics on your external case, not the internal hard drive it contains. If that is not being recognized that usually indicates a failure of the hard drive logic board, not a good thing.
Remove the drive from case and plug in directly into your pc. If still not recognized that confirms initial diagnosis. Your usb port is ok but the drive is fubar and since the logic board is toast data recovery will have to be done by the pros and be expensive, very expensive.
Always a good idea to have multiple backups!!!!!!!!!
Sep 20, 2017 | Western Digital Passport 120GB External...
Device is not recognized
Probably not the right answer for your problem. Mine is an external 1 TB Simple Drive. Mine wouldn't respond at all. I unplugged the power cable from the back of the hard drive and replugged it in and instantly it worked. I had tried rebooting the computer, plugging/unplugging over and over into the computer and that didn't work.
Jun 22, 2010 | Western Digital Passport WDXMS2500TN 250...
My WD external hard drive does not stay recognized on my computer. When I first plug it in it makes the ding/beep noise and shows up on "my computer" but after a few seconds it makes the ding/beep noise...
Try the hard drive on another computer to see if it is the external or a laptop interface problem. There are EIDE/SATA to usb adapters that you can connect a hard drive to that the computer will then read as an external hard drive. The problem with external HDDs is the usb interface built into them, these are mounted on controller cards and that is ususally where the failure occurs.
Jan 10, 2010 | Western Digital Passport 320GB External...
WD Passport 250GB External cannot be recognized.
Go to BIOS (Press DEL or F2 to enter BIOS). Check if the Power state is in S1. Ensure that USB setting is in Hi-Speed.
Restart the computer and try using the device. this should fix. Let us know the result.
Thanx
Jan 16, 2009 | Western Digital Passport WDXML800UE...
My PC is not recognizing my WD Passport 120GB USB external drive. I used just few days ago and connected the usb cable to my computer and the WD Passport drive and not recognized on my 2 laptop and 2 other...
I had the same issue. Its not a power issue because it shows up in device manager. Heres what I did.
Right-click on my computer and click Manage>Disk Management
Your drive should show up there. Right-click on it. If explore is not grayed out, assign a drive letter to it and you should then be bale to see it in my computer.
In my case explore was grayed out. I had to click on the option to format the drive. After re-formatting the passport explore was available. I then assigned a drive letter to it and I have access again.
I guess somehow using it on multiple computers srcewed up the file-system on it. I was using it between windows and linux.
This fixed my problem.
Oct 28, 2008 | Western Digital Passport WDXML800UE...
My computor switches off the moment i plug in the wd passport.
Probably a power issue. Your new computer has less extra power capacity and the external drive is pulling from the USB port power.
What you need is a USB hub with an AC adapter that powers the hub and any devices that are connected to it from the external AC power adapter and NOT from the USB bus. In other words look for an external power adapter that plugs into the wall as well as into the USB port. Don't get a recharger for an iPOD as that will not do you any good. And don't get a hub that says "powered" or "external power" that does not have an AC power adapter because it is still sucking power off of the USB port.
Try shopping for a D-Link DUB-H4 High Speed USB 2.0 4-Port Hub. It is a good choice if you are not going to plug any USB 1.1 devices into it. Read the reviews for any device you choose.
Oct 26, 2008 | Western Digital Passport WDXML800UE...
I have the 80GB WD passport and it suddenly stopped working one day.  The unit lights up but nothing else.  Finally I cracked the case open and found, as I suspected, that the drive is simply a SATA laptop drive with a SATA-to-USB conversion card built in.  I suspected that the card was **** so I disconnected it and used a USB hard drive adapter (http://www.tigerdirect.com/applications/category/category_slc.asp?CatId=3770&name=USB_Hard_Drive_Adapter) and I can read/write to the drive just fine.  Best part is that the adapter I use has its own power supply so I'm not pulling juice through the USB cable for a SATA drive.
Even though mine "works" again I don't recommend these drives to anyone.  They're just not sturdy enough or well designed.
Sep 09, 2008 | Western Digital Passport WDXML800UE...
Does you drive make any sounds like these? If yes you have a mechanical problem and you should get a specialist to work on it.
If not - try to remove the drive from the enclosure and connect it directly to the computer to recover your files.
Jul 30, 2008 | Western Digital Caviar WD2500BB 250 GB...
Misreading as local disk
can you give more details
such as, what drive letter does it assign it, what error do you get when you try to read it, does it say 120GB when you look at it on "My Computer" and so on.
Jan 15, 2008 | Western Digital Passport WDXML800UE...
Western Digital Caviar SE 120 GB Hard Drive Logo
147 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
