Question about Maxell CD-R 80 Minute 700MB Media Recordable CD 100 PACK (Spindle)
How do I open a Maxell mini DV tape case? I have one cassette that is broken - tape is fine - I need to transfer the tape reels to a new cassette. Same brand of cassette.
Hello FixYa, I was able to find a post in the internet to help. While you service is convenient, the cost and my immediate need really dictated my continued search. Thank-you anyways for your time.
Posted on Aug 12, 2008
How can I manually rewind a mini DV tape?
Hello!
To manually rewind a tape you will need a flat head screwdriver.
Find a screwdriver that fits the "spoke" in the reels of the tape.
Turn the screwdriver toward the center of the tape. (i.e. Left side - clockwise, Right side - counter clockwise)
If this solution does not resolve your issue or if you have more questions please comment below in this thread and I will be more than happy to further assist you!
Happy New Year!
Feedback is appreciated!
Jan 01, 2010 | Maxell DVM60 Mini DV Tape
Erroe 02-355
02-355: Detected S reel FG during stop and Still.
if there is a tape in the machine , open the cassette compartment and remove the tape manually. the tape may be broken. Reassemble the machine and insert a good tape.
Luwangula
Aug 09, 2009 | Sony DSR-1800 DV/Mini DV VCR
I have a broken VHS cassette.
You can remove the 4 or 5 screws at the bottom of the tape, turn the tape over CAREFULLY pull the top off. If the tape pulled out of the end of 1 spool, you have to remove the clip in the tape hub, reinsert the tape and snap the clip back in. Holding the tape door open so as not to catch tape, put top back on and replace screws. Hope this helps.
Aug 08, 2009 | TDK T 120HS VHS Tape
Mini cassette tape is wrapped around one spool inside the casette
1). Remove the five screws from top half of cassette shell. If the cassette shell halves are glued together, very carefully split the shell with a Phillips-head screwdriver. Maneuver the screwdriver around the shell to break its seal. Avoid getting cut or damaging internal components of cassette.
2).Carefully lift off the top half of the cassette shell.
3). Pull the head if the tape from the left reel.
4). cut-off the damaged edge, and attached a peice of sctoth tape to the shining side of the tape, and leave about 1/2 inches of scotch tape beyond the head of the recording tape.
5). trim the sctoch tape using single edge of the sctoch tape razor or X-Acto knife to the same width as the recording tape.
6). carefully insert and tape the head of the recording tape to the right reel. and manually wind the tape till the recoding tape is flat to the front of the recoding pad.
7). carefully close the top shell, make sure not to pinch the tape. use your finguer trun the right reel, make sure the tape winds freely.
8). secured the top with screws.
Nov 24, 2008 | Maxell 179030 Microcassette 3-Pack (60...
MiniDV tape stuck inside
sounds like a defective cassette housing, but i have seen problems with jvc decks and camera when tdk or maxell tapes were used. the lids on these tapes seem to get stuck in the cassette housings in jvc equipment. jvc even recommends that tdk and maxell tapes be avoided.
May 24, 2008 | JVC BR-DV3000U DV/Mini DV VCR
Panasonic AG-DV2000 Mini DV loading problem
the "dv sensor"is actually a mechanical lever built into the cassette housing that moves the reel tables to match the reel spacing on mini or full-size DV tapes. check to see if this assembly is free to move. if it binds up, the reel tables may not move as far as they need to, and can cause problems similar to the one you're seeing. to inspect the mechanism, you need to remove the cassette housing. if you don't have a service manual, get a tech to help -- it's a delicate procedure for the inexperienced.
Oct 11, 2007 | Panasonic AG-DV2000 Mini DV VCR
DV tapes will not load
the "dv sensor"is actually a mechanical lever built into the cassette housing that moves the reel tables to match the reel spacing on mini or full-size DV tapes. check to see if this assembly is free to move. if it binds up, the reel tables may not move as far as they need to, and can cause problems similar to the one you're seeing. to inspect the mechanism, you need to remove the cassette housing. if you don't have a service manual, get a tech to help -- it's a delicate procedure.
Panasonic AG-DV2000 Mini DV VCR will not play large DV tapes
Aug 14, 2007 | Panasonic AG-DV2000 Mini DV VCR
Songy VX2100
I had the same problem when I reused tapes that I had recorded on before, but I don't have this problem when I use brand new tapes. I use Panasonic and Sony tapes and the odd JVC.
Oct 13, 2006 | Sony Handycam DCR-VX2100 Mini DV Digital...
Will Not Load Cassette
I have the zr850 which I have used less than a dozen times, and it does the same thing as you describe. Was told by canon tech people to try a maxell brand tape and a head cleaner tape. Have not tried their sugestion yet. camera is 3 months old.
Aug 07, 2006 | Canon ZR70MC Mini DV Digital Camcorder
Maxell CD-R 80 Minute 700MB Media Recordable CD 100 PACK (Spindle) Logo
264 people viewed this question
Top Maxell Electronics - Others Experts
 Grubhead
Grubhead
Colin Stickland
Colin Stickland
Are you a Maxell Electronics - Other Expert? Answer questions, earn points and help others
