Question about Miele 24 in. G665 Built-in Dishwasher
G892-SC Miele water intake/drain light blinks
Have a 3 year old G892-SC Miele Touchtronic dishwasher.
Salt light came on, needs salt. Filled salt. After that dishwasher worked
but last rinse was missing. Water intake drain light blinks. Checked water intake. Reset start & now dishwasher refuses to even start. No water
enters & light now blinks 4 times, blinks 5th time and holds for one second,
then back to pattern of 4 times blink, 5th time holds for a second longer.
  • 1 more comment
  • sifujim Nov 21, 2008
    I have the same problem described. I went through the main. procedures cleaning filters etc. I even pulled the drain hose and oured about 2 gals. of water into cabinet and then started machine, it cleared the drain obstruction an ran one cycle. on the attempt on the second cycle we are back to flashing light, no run condition???
  • Normand Saurette Oct 15, 2011
    dont have no voltage at coil on intake when it on drain cycle
  • Anonymous Mar 28, 2014
    Water won,t drain
The intake/drain light blinks. How do I fix this problem?
Posted on Sep 18, 2008
Miele dishwaher G638 Sc,,,,Salt PC light is on?
Hi - if its flashing rapidly then there a unrecognized hardware issue -if on permanently - it could be the float switch inside the salt container is not working/jammed - of course theres no salt in the dishwasher container..
Cheers
Jul 20, 2011 | Miele 24 in. G638 Plus Free-standing...
Miele G892 dishwasher stopped working. No lights at all. There is power from the outlet to the block behind the kick plate. According to manufacturer, there should be lights even with the door open so this...
This seems to be a failure of the main program controller unit.It needs to be confirmed that the unit received power, if so the controller is faulty.
Check if there is any fuse , check if there is line break to the unit.
Mar 12, 2011 | Miele Touchtronic G892 Built-in Dishwasher
White film on dishes and still dirty.
Check rinse aid is actually dispensing - turn it up to max for a while to clear it, and check level is going down after a week.
If you suffer with hard water - your heating element may need replacing as it is probably furred up.
Jun 06, 2010 | Miele G892SC SS Dishwasher
Where do I put salt into a G665 model
Salt and rinse aid are low if the indicator light is on.
Salt is placed in a compartment in the bottom of the inside of the dishwasher. It has a round approx 10cm diameter screw cap.
Rinse aid goes in under a flap in the inside of the door near the powder dispenser
Dec 02, 2009 | Miele 24 in. G665 Built-in Dishwasher
Do you have a meile g892 dishwasher?
Yes,
a G892SC - for over 6 years now. It's so quiet that many a time I've opened the door to put something in it, only to discover it'd been running (rinsing, etc., not drying!) the whole time! Despite 3 years in the Army and lots of Rock concerts, I have no hearing loss ;-)
One year ago, the little orange plastic detergent lid latch broke. And considering how well-made the rest of the unit is, it was not as robust as the rest of the DW. I Emailed Miele, and they sent out a repairman who replaced the entire soap unit on the door for FREE, even though it was well out of warranty. You pay more, and you get more.
Brad Wolff
Dec 15, 2008 | Miele Touchtronic G892 Built-in Dishwasher
Miele G892 SC Touchtronic
check drain pump impelar is free, it can be found under the non-return valve below filter. also make sure drain hose and S trap is clear.
Mar 29, 2008 | Miele 24 in. G638 Plus Free-standing...
Miele G893
you should have a dispenser on the door to add salt,regardless get c.l.r. calcium lime rust remover from a supermarket,lowes,home depot.put a cup in the unit ,run for 15 minutes and then put a cup in again.let the unit complete its cycle.if you still smell the odor repeat until its gone.you could also use baking soda,flour or vinegar.
Jan 05, 2008 | Miele Touchtronic G892 Built-in Dishwasher
Miele Touchtronic G892 SC Water leak at base of door
check the rubber seal around the door to see if its torn or smashed. if it is replace it, could someone have set somthing heavy on the door while it was open that would have stressed the hinges. it is most likely one of these problems take a nail file and slid it gently between the door and the body of the dishwasher if it slides in easy where it leaks you know the seal is bad and replace it.
Dec 09, 2007 | Miele Touchtronic G892 Built-in Dishwasher
Miele G892 SC dishwasher not heating/cycle won't stop
Miele have cold inlet only. Either element is open circuit, or the relay that switches the element has failed. My money would be on the element first, then the relay. The machine will sit in that mode forever as it is waiting for the temperature of the water to reach a certain temp before telling the electronic unit to move to the next part of the wash. If you need assistance in how to test & how to get to these parts just let me know. But you will need an ohm meter to test the element. Regards
Aug 20, 2007 | Miele Touchtronic G892 Built-in Dishwasher
Dishwasher ran with wrong soap
add some salt in the cabinet and a bit of water. salt acts as a foam suppressant
Feb 18, 2007 | Miele Touchtronic G892 Built-in Dishwasher
Miele 24 in. G665 Built-in Dishwasher Logo
6,241 people viewed this question
Top Miele Dishwashers Experts
mpservices
Craig Butler
Craig Butler
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
